Remember that read (MTK)
Posted: Tue Sep 06, 2016 14:44
Remember that read - download.
Are you familiar with this situation where you spend days and even weeks reading some books or other printed materials, and then discover that almost none of it can't remember?
Of course, note-taking read may carry some benefits, but in this case, you must rely on your notes and not memory. In addition, the notes may not give you the full picture. Because, when you access notes that you created during training, you may find that they do not make sense, as merely representing a photographic snapshot of what you were thinking.
So, of course, the notes you can do, but if you manage to boost the memory, so that all you want from reading reliable remember, you don't even have to think about the notes.
Memory is a whole set of complex processes of your brain. Basically, in order to reliably remember to put it in memory first. When you feel or learn something new, the "impression" first enters into short-term memory. This process takes place in the hippocampus. So when someone tells you their phone number, you retain it in your short term memory, it remains there for as long as you didn't write it down and not forgotten (erased from short term memory). If you use it often that in the end, it is recorded into long term memory.
From this example you can see that the repetition and concentration on something are the basis of learning. But how to use it when reading? One way is to read educational material several times. But sometimes you just don't have time for this. Another way is to place new information into long term memory more quickly.
There are a few practical recommendations on improving your memory. For example, trying to read and learn anything when you're hungry, thirsty, tired or worried about other issues that will block you from getting information stored even in the short term not to mention long term memory. This way, when you read is as important as what you read, if you want to remember it later.
It is important to remember and use the fact that Your memory works through your senses. For example, consider a party with your friends what you saw, heard, smelled, felt and experienced. The more senses you remember, the brighter Your memory about the event. People with excellent memory read, tend to really see and even feel or hear the material as if they actually experienced it, not just read. Thus, their memory works more like the actual memory of the event.
You can get multi-touch response, even at the technical information if while reading you have a good idea of what you're reading. Another way to remember what you read – to explain important ideas from the reading to someone else. In other words, the more you get used to the information, the better it is remembered.
Even the great Russian physiologist Ivan Mikhailovich Sechenov, at the time claimed that between real experience and imagined experience for the brain, in essence, no difference.
This session helps you master the skills of ultrafast absorption and of easy recollection read by multiple repetition of an imaginary experience on the background of hypnotic trance.
Around hypnosis and the hypnotic trance, currently, stranded a lot of different myths. In fact, a hypnotic trance, by definition is "only" focused attention, directed inward.
In a hypnotic trance, everything happens very fast and even too fast, so your mind can not catch, something to see and feel, as your subconscious mind works millions of times faster than we used to think your mind. Therefore, your main and only job during the session is to relax well on both physical and on the mental level, to ensure that your subconscious ideal conditions for work. The easiest way to do this is to focus on your breathing – just watch and observe the sensations in the body during the normal breaths, not trying to manage anything.
Thus, the posture for listening, you are free to choose any where you prefer to relax and unwind. Headphones are not required (without them even easier to relax), but the use of stereo is highly recommended. Rule 2-glasses of regular clean water (before and after the session) is very welcome, as it enables normal hypnotic work and absorption skills.
Standard cycle of listen – 21 times (any number of auditions in one day counts as one time), with a break of not more than 2 days (without breaks). It is recommended to repeat the cycle every three months during the year (i.e. 4 repetitions). It is advisable to update skills every 4 years.
Optimum time classes with 16 to 18 hours.
PS To hear the voice Навигатор1 should be pereproshit on version 1.2or above. Highly recommend version php?f=38&t=6404">2.11and the owners Навигатора2 version 3.12
Save a combined session in a special folder (SES_SPEC) on the drive in Pathfinder. To find and run a combined session in the Navigator, select:
Navigator 1: Training\extra modes\Combe. session;
Navigator 2(green): Player\Combe. session of the csp.
Before class and after it is helpful to drink at least half a Cup of clean water.
On the absolute the majority of your even not asked questions :) you can find satisfactory answers in "Guide to disks".<
