A free Program for creating and editing sessions.
Post Reply
Has thanked: 134 times
Been thanked: 556 times
Contact:
Post by Андрей Патрушев » Fri Sep 02, 2011 21:12
User avatar
Воффка
Has thanked: 5 times
Been thanked: 8 times
Contact:
Re: Program to create sessions.
Post by Воффка » Wed Aug 01, 2012 14:45
And write the instructions on how to use the program to create sessions for the Navigator :) At least how to create a session on tracing paper of the Nova Pro 100.
Алексей Крячко__
Been thanked: 17 times
Post by Алексей Крячко__ » Wed Aug 01, 2012 15:04
The program has a very good context help, I think it is much easier learning of the user.
Contact:
Re: Re: Program creation sessions.
Post by Андрей Патрушев » Sun Mar 22, 2015 9:22
Влад Ярушевский
Post by Влад Ярушевский » Wed Jul 29, 2015 23:21
Good day!
When you try to load a session, I get an error (on the screenshot).
Net installed, tried on two machines with XP.
https://www.dropbox.com/s/ns2yq9gv0qvwv ... 5.jpg?dl=0
There is an older version to try?
Contact:
Post by Андрей Патрушев » Thu Jul 30, 2015 11:45
Vlad Jaruszewski
Hello.
Please copy the full error text and send me by e-mail along with the session.
All session give this error? Try to do some short session (from"bulldozer"), save and load - does this error?
Влад Ярушевский
Post by Влад Ярушевский » Fri Jul 31, 2015 3:39
Андрей Патрушев wrote:Vlad Jaruszewski
Hello.
It gives an error just when clicking open, to select session does not reach, that is session independent.
While trying to run through a click on the session file simply launches the program with an empty session.
Full text
Code: Select all
error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.MissingMethodException': Method not found: 'System.String System.Windows.Forms.OpenFileDialog.get_SafeFileName()'.
 at Navigator.Form1.LoadSessionToolStripMenuItem_Click(Object sender, EventArgs e)
 at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
 at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
 at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
 at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
 at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
 at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
 at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
 at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
 at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
 at System.Windows.Forms.Control.WndProc(Message& m)
 at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
 at System.Windows.Forms.ToolStrip.WndProc(Message& m)
 at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
 at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
 at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
 at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
 Assembly Version: 2.0.0.0
 Win32 Version: 2.0.50727.42 (RTM.050727-4200)
 CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Navigator
 Assembly Version: 1.1.12.0
 Win32 Version: 1.1.12.0
 CodeBase: file:///C:/Program%20Files/Navigator/Navigator.exe
Microsoft.VisualBasic
 Assembly Version: 8.0.0.0
 Win32 Version: 8.0.50727.42 (RTM.050727-4200)
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Runtime.Remoting
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Navigator.resources
 CodeBase: file:///C:/Program%20Files/Navigator/ru-RU/Navigator.resources.DLL
System.Configuration
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
ExtIO_Navigator
 Assembly Version: 0.0.0.0
 Win32 Version:
 CodeBase: file:///C:/Program%20Files/Navigator/ExtIO_Navigator.DLL
msvcm80
 Assembly Version: 8.0.50727.6195
 Win32 Version: 8.00.50727.6195
 CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86/msvcm80.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
 <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Contact:
Post by Андрей Патрушев » Fri Jul 31, 2015 11:05
Vlad Jaruszewski
This happens in both cases: both when clicking on the icon on the front panel and selecting "load session" from the menu "file"?
Влад Ярушевский
Post by Влад Ярушевский » Fri Jul 31, 2015 11:48
Exactly.
Contact:
Post by Андрей Патрушев » Fri Jul 31, 2015 12:02
Vlad Jaruszewski
And when the installation had no problems? Especially with the addition of Visual C++ ?
Have you tried to uninstall (required) and re-install?
Влад Ярушевский
Post by Влад Ярушевский » Fri Jul 31, 2015 12:43
Everything in the archive was established.
Will try today in the office for 7 Windows.
Влад Ярушевский
Post by Влад Ярушевский » Fri Jul 31, 2015 12:46
Navigator I actually need to print combined session and to adapt them to innerpulse. So somehow get out.
You unsubscribed only for debugging errors. So if this is an isolated case not worth wasting time on it.
Thank you, as always, for efficiency.
Contact:
Post by Андрей Патрушев » Fri Jul 31, 2015 12:48
Vlad Jaruszewski
There are all automatically installed...
So it is with any session occurs, or only combined?
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Post by мимоходом » Fri Jul 31, 2015 13:04
this method works for NET3.0 and above, but not for NET1.1 or NET2.0
maybe you have an old computer with an ancient never updated Windows XP, as this framework is included in modern versions, starting with Vista
with a probability of 99% you need to install .Net Framework latest version (currently 4.x) or at least version 3.0
you can download it here
https://www.microsoft.com/ru-ru/downloa ... x?id=17851
Влад Ярушевский
Post by Влад Ярушевский » Fri Jul 31, 2015 13:37
With any newly created too.
Влад Ярушевский
Post by Влад Ярушевский » Fri Jul 31, 2015 13:39
Windows sp3, even put new updates on май2014. Net comes with the 2.0, like 3 and 4 are not necessary. I will try 7 today.
мимоходом
Post by мимоходом » Fri Jul 31, 2015 13:41
This software works only with the NET3.0 not working with a NET of smaller versions. Can Google the error and see her reasons
Влад Ярушевский
Post by Влад Ярушевский » Fri Jul 31, 2015 13:45
мимоходом wrote:This software works only with the NET3.0 not working with a NET of smaller versions. Can Google the error and see her reasons
Thanks, I will consider!
Влад Ярушевский
Post by Влад Ярушевский » Wed Aug 12, 2015 19:36
Thanks, do install 3.0 version helped!
Under 7 also started.
You might want to add in the readme file this nuance.
Contact:
Post by Андрей Патрушев » Wed Aug 12, 2015 19:37
Vlad Jaruszewski
Definitely.
User avatar
Кипер
Post by Кипер » Sat Jul 06, 2019 16:06
The program complains to initialize MSI when opening an mp3 file at the touch of a button
Post Reply
