Page 1 of 1
The fractals. BR-Disk. Flame.
Posted: Thu Jul 20, 2017 18:35
by Шалтай Балтай
Flame.
Re: Fractals. BR-Disk. Flame.
Posted: Mon Jul 24, 2017 19:03
by Шалтай Балтай
On pofleymit
who will offer:
- simple
- cheap
- easily accessible
- legkomotorny
device for activation of the disk with the fractal rotation.
So that anyone could always if you want to make, without skills, without tools.
by the way, the same can be done with rings, I even wrote about it (
viewtopic.php?t=6469) Oh and the combination.......
ideas?
Posted: Tue Aug 01, 2017 16:47
by Шалтай Балтай
the Magician
Smile....
Posted: Tue Aug 22, 2017 10:56
by Шалтай Балтай
Шалтай Балтай wrote:the device according to the activation disk fractal rotation.
it seems to me that rotation is a key element for working with structures in General, fractal in particular.
Posted: Tue Aug 22, 2017 14:47
by арте:м
the disc in the drive after spinning. install it in the drive and run any test on reading, or multiple up and so he takes off with no effort?
Posted: Tue Aug 22, 2017 16:32
by Шалтай Балтай
Arte:m
and so, the problem is that the drive usche and the computer is necessary
Posted: Tue Aug 22, 2017 16:34
by Шалтай Балтай
Humpty, as always, did not invent the wheel, it shares the centuries:
https://duckduckgo.com/?q=buddhist+spin ... ages&iax=1
Posted: Tue Aug 22, 2017 16:36
by Шалтай Балтай
ACC is the same (in Principe), only nano-tech
thought -> fractalization -> commit on the BR -> rotation
+ crystals
+ nodes
+ organic
+ etc., etc.
Posted: Sat Sep 23, 2017 17:46
by Шалтай Балтай
by the way:
Tibet Tech "Two-In-One" Electric Table-top Prayer Wheel - 8-DVDs with 84,348,750,000 prayers and 1 DVD with 16,003,200,000 Medicine Buddha prayers
it's a revolving podium with DVD drives.
Price: $298.00 & FREE Shipping—or get FREE Two-Day Shipping with Amazon Prime
300 tanks - not weak
although declared 100 mil prayers too, sounds official......
Posted: Sat Sep 23, 2017 17:49
by Шалтай Балтай
Weaklings, the Humpty - cooler, I Blyurey
I went to Amazon
Yes and cheaper I Cotag....
Posted: Sat Sep 23, 2017 17:53
by Шалтай Балтай
Шалтай Балтай wrote:On pofleymit
who will offer:
- simple
- cheap
- easily accessible
- legkomotorny
ideas?
while the leadership of the Amazon
Posted: Sun Sep 24, 2017 1:58
by арте:м
in the next topic similar to the issue decided, gluing the stick to the blade of a regular desktop fan..
Posted: Mon Sep 25, 2017 16:50
by Шалтай Балтай
Zarobotka to think
- randomization Algorithm fractal. Jacket from here:
Randomness
The last thing I'm going to talk about is the fact that randomness
By itself, the randomization thing is interesting, but I would generalize the word Modulation of a fractal.
- Just the rotation of the fractal is good, but the rotation of the rotation increases the dimensionality of the torsion field. It's to think....
Posted: Mon Sep 25, 2017 16:55
by Шалтай Балтай
арте:м wrote:in the next topic similar to the issue decided, gluing the stick to the blade of a regular desktop fan..
saved.
- flash a little something. Blyurey - tougher media, more sturdy footprint, trace "clean" (so to speak) of torsonce will be higher. IMHO, deserves attention.
- How to construct the track (track) Blu-ray Disc is clear. ACC clear as borne data (fractal) on disk. And how does the structure of the flash drive? IMHO, it is necessary to know the structure of the medium, to generate the fractal. "Broken" structure will give the ACC. field.
this is all IMHO, of course
Posted: Mon Sep 25, 2017 20:46
by Шалтай Балтай
Шалтай Балтай wrote:. And how does the structure of the flash drive?
https://duckduckgo.com/l/?kh=-1&uddg=ht ... tn2919.pdf
Not so simple...
Posted: Tue Sep 26, 2017 0:01
by арте:м
But what prevents exactly also pin the rotor to the impeller (or even instead) of improvised means?
Posted: Tue Sep 26, 2017 10:00
by Шалтай Балтай
арте:м wrote:But what prevents exactly also pin the rotor to the impeller (or even instead) of improvised means?
do let me see.
If You want to talk about it - You losing me, I'm not interested in talking.
If You have a specific device that YOU have MADE with your HANDS, then I'm first in line to view.
I am respectful, both to themselves and to those with whom you are speaking, I post something that I made by hand. And I would like to chat with people who also have respect for yourself, to ensure that they do svimi HANDS and have respect for others and to what others are doing.
What to speak - maybe it's just noise?
Posted: Tue Sep 26, 2017 10:20
by Шалтай Балтай
Notebook knizhka:
A couple of moments to think
- Alignment of the disk. If we manage to exactly center, it will be possible to build momentum
- The revolution counter. If you take the power supply with a smooth output voltage setting and the Rev counter, it will be possible to achieve the necessary frequency of rotation of the disk. This is interesting.
- All the same for rings. Rings only one problem - the alignment. They are heavier
Posted: Mon Dec 11, 2017 16:25
by Шалтай Балтай
Had the opportunity to review the technology and process, a couple of points more in the notebook:
- TB: Structures in General, fractal in particular - delay, it is necessary to keep the situation the second attention, otherwise there is apprehension... As an example, the allegory, I would venture to give an empirical school of thought in General. This structure, of fractal type. Typical mental trap. Most people got into it, confident that the other way of thinking does not exist. Sometimes it is not treated
- The real magic starts if structure/fractals rotating. I have a suspicion that the rotation should be done in two carriers facing each other. This creates a funnel.
