SP. from Logik
- Шалтай Балтай
- Разработчик
- Has thanked: 125 times
- Been thanked: 263 times
- Contact:
- Логик
- Has thanked: 2 times
- Been thanked: 21 times
I did not used a lot. So, don't expect anything supernatural.МерКаБа wrote:Bronze powder will increase the resistance orgone, but the stimulation of the EM field, will give much more energy, so that, indeed, careful. By the way, the range of operation of the device due to the bronze, also needs to be more.
By the way, where did you get this information about the bronze?
With translations of foreign sites. In particular John Logan. http://www.littlemountainsmudge.com/
In fact, the nuances of a lot! From metal orgonite to its density and the size of the pieces. Will work in any, but the impact will depend on the factors described above. If the density of orgonite higher for the release of energy will require high power EM, but the number of energy will increase significantly. If you use a steel (wool), organic will also have a higher resistance than if you used aluminum or copper. Better mix.
Bronze, an alloy of several metals including copper, sootvetstvenno and range of operation of the device will be more.
And you kind of frequency filed?
- Логик
I read it.МерКаБа wrote:If the density of orgonite higher for the release of energy will require high power EM, but the number of energy will increase significantly.
The couple, as I remember, all the way around.МерКаБа wrote:If you use a steel (wool), organic will also have a higher resistance than if you used aluminum or copper.
15hzМерКаБа wrote:And you kind of frequency filed?
- Шалтай Балтай
- Разработчик
- Contact:
In in in.....Логик wrote:head began to grow heavy.
All about the same.
PralnoЛогик wrote:But, bearing in mind the written above - well, it nafig will have to wait.
1-2 hours a day to begin with - more than.
A couple of words.
Very good as far as there is the practice of working with energy.
Anything
Qigong, Norbekov, anyone.
It gives the feeling flows, vortices (Chakras), meridians call it what you want - all are one and the same.
When You put in the flow artificially (device) - then starts training something that has never worked. It can be Kryne not accustomed to.
Imagine that a man came to the gym the first time and gave him a big load. How he will feel?
So not in a hurry - IMHO it's the training.
And in training, known as the secret is in the system.
- Логик
So a new device was constructed from quartz "cobblestone"
Here take this stone (about 350g)
Uploaded with ImageShack.us
Winding wire
Plus "amplifier"
And get ready device
it was drenched in a bucket of 0.65 liters.
Metal -bronze powder, metal sponge.
Haven't tried it yet. Not yet.
Winding wire
Plus "amplifier"
- Шалтай Балтай
- Разработчик
- Contact:
- Шалтай Балтай
- Разработчик
- Contact:
- Шалтай Балтай
- Разработчик
- Contact:
