Page 3 of 3
Posted: Wed Feb 16, 2011 12:13
by Практик
Humpty Baltay
There is interest?
There! but a lot of questions:
-Issue price?
-What companies and what exactly can they turn?
As an example on e Bay the guy put a couple on sale at 30-50 Baku(for my personal feelings, some of them more than workers:
http://cgi.ebay.com/SPIRAL-CRYSTAL-ORGO ... 19c31774d2
http://cgi.ebay.com/LIFE-FORCE-REJUVENA ... 1c1944c634
http://cgi.ebay.com/HARMONIC-HEALING-CO ... 19c3177128
Such will be able to twist?
Posted: Wed Feb 16, 2011 12:59
by Шалтай Балтай
Практик wrote:Humpty Baltay
There is interest?
-Issue price?
well done man,
made and sells.
we - the country of the Soviets. sense - ZERO.
maybe he'll take it. saved for the link.
Posted: Wed Feb 16, 2011 14:06
by Практик
Humpty Baltay
Well so is Russia :)
maybe he will. saved for the link.
Always please I am going to order this:
JV can get to adapt as you)))
WELL, actually it would be very best to order it also but only somewhere in Russia
Posted: Wed Feb 16, 2011 14:29
by к-13
no, it's not necessary, sorry.
the spiral is not flat, monogram not clear destination
and form, Hz. what to do with it
and besides counterclockwise
For plants, such a thing couldn't be better(this is the stand for the barrel with flower, I have it 6 times altered before the result). Monogram only circuit with two parallel rods in a strip of conductor. Besides, I never proposed, just gave an example. I think I posted somewhere a photo of a large balloon twisting and a few small...
From springs on the links, in my opinion, only one works correctly the other do not understand why(a good bluff more than money). As for the country of Soviets, with Your material I will bend...
Posted: Wed Feb 16, 2011 14:37
by Практик
K-13
From the springs on the links, in my opinion, only one works fine
I wonder what? :)
Posted: Wed Feb 16, 2011 20:14
by к-13
Практик wrote:K-13
I wonder what? :)
Well, there are two similar and on testing respond equally feebly - closed center spring is quite a weak device, something like a capacitor Naumkin - field condenses a little bit, and it was mostly due to a program to produce human. Accumulates next to a field, depending on the direction of the twist. The same coil at the globe works even worse(maybe due to the smaller amount of turns, maybe because of this fashionable taped, I would have tried in the cardinal directions to Orient and stand to make in the shape of a pyramid, as the emblem of Mercedes is in this sense besolatni - just as the egregore, but maybe due to the fact that the axis is not perpendicular to the ground, who knows with her...).
But "sweetie" is very interesting - it pulls a bit in the center negative, and the edges emit a plus, and somewhere 160 degrees on each side. Rather cleverly devised. The only thing that suggests itself is to turn it vertically I am sure that the properties will increase(but then the radiation pattern is not so convenient to be located)...
Posted: Sun Mar 06, 2011 10:51
by ГаСС
Somebody Scarab Coil twisted? Share your experience torsion and application.
Posted: Tue Mar 08, 2011 20:45
by ГаСС
Campaign case no.
I then downloaded the English how to twist Scarab Coil and translated what they understood. I would be very grateful if someone will finish what I started.
Here is the link http://ifolder.ru/22291188
Inside are two files. The original and what I have aperiodic. Misunderstood pieces of my file were in English.
Re: SP. Nodes
Posted: Mon Jun 25, 2012 20:18
by Щялун
And what better than the Mobius knot or spiral these?
For homemade SP...
Re: SP. Nodes
Posted: Tue Dec 04, 2012 3:08
by Саин
Guys, the closer to the crystal the higher should be the density of organite?
Re: SP. Nodes
Posted: Tue Dec 04, 2012 17:02
by Алексc3000
Саин wrote:Guys closer to the crystal the higher should be the density of organite?
Yes.
Re: SP. Nodes
Posted: Tue Nov 05, 2013 11:35
by Глюк
Lord, are you discussing the nodes on generator"mana") :) I hasten to remind you that this is just a colossal library of knowledge in the field of symbols, including spirals) If fumbled on the Internet it is easy to find information) should Not outright reject the knowledge of their ancestors. Though they were limited technically, but the head they were thinking.
For example, if my memory serves me, take Tibet. According to esoteric ideas there, spiral-clockwise-concentrates energy in the heart and makes it quicker to achieve enlightenment. A counter-clockwise spiral are also valued but less than hour.
In other cultures you will find similar performance.
Also refer to physics: everything I hope you know what an electric current and the "rule" of the right hand?about a gimlet?))) who does not know Google)
Assuming that the torsion field is at least something similar to magnetic (such as the fact that you can create with wire :lol: ) we get a very intelligible reason to do a spiral clockwise.
So I ran the main theme to something someone says in a clockwise and counterclockwise twist is similar to the principle of Yin and Yang.....vacuum pressure...not exactly but very close) I would, on the basis of the esoterics, called it concentration and radiation..
in the first case, all of the plane is concentrated in the center and radiates out,in most cases, to the bottom, and so the flow comes from the top :aa ..I do not know why esoteric so..for me so in both directions goes... :wiz
in the second case there is a dispersion in the plane, and the energy is drawn from the top and bottom in the center.. :evil:
just want to add that it is better to use copper and silver(ideally) because of their conductivity, not gold. Gold on the physical and other properties inferior of both.
Even if we consider gold as a symbol of the sun(Yang) and silver as the symbol of the moon(Yin), then gold and then not pull as easily replaceable by copper(Yang) which by the way is often added to the impurity to gold. The effect is the same if not more.
Glad if my information was not just consumer goods. :)
Sincerely, Glitch.<
Re: SP. Nodes
Posted: Tue Nov 05, 2013 13:09
by Логик
Glitch it is not necessary to post the same thing in two threads at once. Or the next time. I will delete your posts.
