Page 2 of 3
Posted: Fri Oct 29, 2010 18:43
by _Алекс_
Well, of course I saw it and I know that the coil is placed below the SP, I'm talking about the top guys!!!)
just above, parbattya wheel
and net of Kalesija, a large touchpad on the mac all the time to have all hands to do...))) waah)
Posted: Fri Oct 29, 2010 18:49
by Шалтай Балтай
_Алекс_ wrote:is placed below the SP, I'm talking about the top guys!!!)
can and bottom can and the top
Posted: Wed Dec 01, 2010 15:13
by Ахмадинеджад
Yes, it is possible to head to break with these directions))! But what if you don't get the ends to bend and to solder to them...balls and the middle one to post Here..like this:-[/br]
by the way, maybe a direction here truevue..in General, all these cropcircle - thing-in-itself, no matter how badly
Here's an idea slipped: what if every complex structure(two-dimensional),to etch the foil on the Micarta, as the printed circuit Board, and then pour even packs?..Here, for the overall development
http://oldoctober.com/ru/lut-naoborot/.(a desired image can be developed in Illustrator or CorelDRAW(shtob in the vector).
Posted: Wed Dec 01, 2010 15:47
by Шалтай Балтай
Ахмадинеджад wrote:to etch on the foil Micarta, as the PCB?..
I too think about it, especially
Шалтай Балтай wrote:and whether the guys are so muddied that spiral it is necessary to shake anyhow and Golden ratio?
Posted: Wed Dec 01, 2010 15:49
by Шалтай Балтай
but the WTO's already thrown the idea of HOW to do it:
http://www.mindmachine.ru/viewtopic.php?p=57072#57072
Posted: Wed Dec 01, 2010 16:06
by Ахмадинеджад
OOO! Well, quite exhaustively, did not get back to this page)
About moju goldenratio to zaproponowali program PhiMatrix
http://www.phimatrix.com/
Posted: Wed Dec 01, 2010 16:10
by Ахмадинеджад
and the idea was to fill holographic dot-matrix applicator type "Ayres".
http://www.bio-lavka.kiev.ua/litairappl.shtml
Posted: Wed Dec 01, 2010 16:28
by Шалтай Балтай
Pour generally not necessarily
You can just put
So with the parlor doing.
Posted: Wed Dec 01, 2010 21:51
by АК
Шалтай Балтай wrote:Ахмадинеджад wrote:to etch on the foil Micarta, as the PCB?..
Do something of the sort...
http://www.quantumbalancing.com/vortex_antenna.htm
Posted: Thu Dec 02, 2010 17:13
by Ахмадинеджад
However.. Impressive!! Thanks AK, study..
Here a couple of pictures similar in the text:
http://fourthway.narod.ru/lib/rovner/gau4.htm
Posted: Thu Dec 02, 2010 18:44
by МерКаБа
here and there eneagrama. porazitelno.
Posted: Wed Jan 19, 2011 23:40
by Шалтай Балтай
Here's something about which so long spoke bolshiviki (in my face)
well, my axe-dimensional version:
resources:
cable - 150 p (I think, maybe 50, not all were used)
- plastikowy glass (10? RUB)
- half an hour of work
well Atlanta, tape
there is an effect?
Yes while shaking his head beginning to lead as the first time
not included more
session prepare, there was finally an idea how to do it better
IMHO
The nodes are the simplest and most effective thing you can do with SP.
and it costs almost nothing for resources.
very recommend
PS
The original photo of the "cake" here:
http://www.mindmachine.ru/viewtopic.php?t=3295
already months 9 to him. Potryasayuschaya thing
Posted: Wed Jan 19, 2011 23:55
by Маг.нет
The number of turns important?
Why the top sheet of paper?
Sincerely, MAG.no
Posted: Thu Jan 20, 2011 0:00
by Логик
Маг.нет wrote:Why on top of a sheet of paper?
I think this is a normal link.
Posted: Thu Jan 20, 2011 0:04
by Маг.нет
Thank you!
Then another question: the glass bottom is? And for what purpose the duct tape?
Sincerely, MAG.no
Posted: Thu Jan 20, 2011 0:09
by Логик
Маг.нет wrote: And the purposes for which duct tape?
I guess that the cable is not unwound...
Posted: Thu Jan 20, 2011 0:17
by Маг.нет
So it seems under the glass is not unwound...
What's with the wire ends? Simply cut off the "under spring"?
Sincerely, MAG.no
Posted: Thu Jan 20, 2011 11:26
by Шалтай Балтай
Маг.нет wrote:the Number of turns important?
if You think that it is Sacmi, so it may be so for You
Логик wrote:I think this is a normal link.
Yes
well, or the table of links
Маг.нет wrote:the glass bottom is?
no, there is a bar code
Маг.нет wrote:What's with the wire ends?
Simply cut off
Posted: Thu Jan 20, 2011 11:42
by Маг.нет
Thank you! Thought know-how),and found a review of efficiency:)
Шалтай Балтай wrote:bar code
Sincerely, MAG.no
Posted: Fri Jan 28, 2011 12:48
by ГаСС
Hatching, which is on the table quite unnecessary.
Posted: Tue Feb 15, 2011 14:07
by Шалтай Балтай
How interesting it would be to order the nodes at a third-party company? On the market there are services for the production of wire products. But as I understand it for 10-15 products, they will not take. ACC. right amount of several hundred pieces. If there are 10-15 people interested, we can try to place an order.
Are you interested?
I'd think about these:
pieces 15-20.
Posted: Tue Feb 15, 2011 14:48
by к-13
Are easier hands to turn with pliers... For ten minutes 6 pieces out of the wires in the elbow are long.
Posted: Tue Feb 15, 2011 15:38
by Шалтай Балтай
к-13 wrote:Are easier hands to turn with pliers... For ten minutes 6 pieces out of the wires in the elbow are long.
link Sachs
well, let's
Can the same smooth to do, but in a diameter of 20 cm, better 30?
Will take pleasure (not for free of course)
However it is better in PM...
Posted: Tue Feb 15, 2011 20:46
by к-13
Шалтай Балтай wrote:link Sachs
I'll fix that.
well, let's
Yes not especially it and even in the photo... I have an interesting result, and in payment I'm not really zainteresovan(especially because labor costs are minimal).
You can and here's a site to stir up(he is also a working flower the bloom began, and then almost dried up
[/url]
Posted: Wed Feb 16, 2011 11:32
by Шалтай Балтай
[/url]
no, it's not necessary, sorry.
the spiral is not flat, monogram not clear destination
and form, Hz. what to do with it
and besides counterclockwise
needs such as in the photo above.
if you want to complicate, it is better to take the wire to twist into a spiral (pigtail), and from this spiral - untie the knot.
that's interesting
