Page 11 of 12
Posted: Wed Mar 09, 2011 11:15
by Шалтай Балтай
I see you so thoroughly come to the point
Keep up to date with events...
if not difficult
Posted: Tue Mar 22, 2011 13:51
by ГОР777
Шалтай Балтай wrote:
not advised to run....
"- comrade Lieutenant, can I see it?
- you can.... just do not turn on"
Re: SP: Results, reviews, use
Posted: Fri Aug 26, 2011 12:27
by Шалтай Балтай
I share one Hinton
I use SP on the track diagram:
viewtopic.php?p=61540#p61540
ACC. the red piece of paper - the stage where klutse affirmations/beliefs.
How to make a thoughtform:
- take a small bamazhku and a pencil
- take the pencil in your left hand (for left - most to the right)
- think of the phrase, respectively. your thought-form. it should be fairly short, something like: "Buy a HOUSE"
- Begin each letter scribbling with a pencil, every line of the letters - many times
- And so the whole phrase
- Put the piece on stage.
Posted: Fri Aug 26, 2011 12:29
by Шалтай Балтай
to continue the thought.
If you know the runes - all super
Code phrase in renovasi
then - as it is written.
Posted: Fri Aug 26, 2011 14:51
by Логик
Шалтай Балтай wrote:to continue the thought.If you know the runes - all SuperModule phrase in renovasi
http://www.astro-stream.narod.ru/runes/ ... _runes.htm
Posted: Fri Aug 26, 2011 16:28
by Шалтай Балтай
not a bad toy. It's Futhark as I understand it.
saved.
but IMHO there is not so simple. Suggest Chudinov to read.
there is something to think about
syllabary, it is not the Cyrillic ("this is not lezginka and twist"
well, the script and so will have to collect....
if I need to.
poshukayte hindostani....
Posted: Sat Jun 30, 2012 11:38
by Темич
People, Hello. Cheto long time here nobody wrote. Where pozadovat questions you can use SP?
Posted: Mon Jul 02, 2012 10:25
by Шалтай Балтай
I would say here
Posted: Wed Aug 01, 2012 23:08
by Анечка
Yesterday I bought SP put under the bed, Turned on MM immediately felt cleansing , sleep was deep as a child without thinking, took a sinusitis from the air conditioner,clearer thoughts and more in the Morning felt a connection. SUPER!!!!
Posted: Fri May 03, 2013 1:39
by Саид
Dear Humpty.Need Your advice what to do next.Did Kulick put under the bed 2 weeks okay,sleep ,mood, and wherever felt It was just super.The cake is not where neoglacial link did not.Did the Type of subject table as you have with wire wrapped cake on the outside,the glass is not covered.And began the process of winding very bad begun to feel finished put under the bed,but the headache,the nausea did not pass 1 week while in the dream, came the answer of the Church to remove the amulet from her neck.Everything went but the cake such a depression as to the winding "of the table "no.Cake I'm not much podklyuchaetsya what to do next.How to make the link of how and whether to close the coil and what coil to Mobius to begin with.How it influenced me on stage and where on the table subject to read
Posted: Tue Jun 17, 2014 14:23
by АнастаГон
The tip on the SP in the form of a spring or spiral, called antenna. Some write that the effectiveness of it increases. Decides the diameter and the thickness of the wire, the more the better type.
_______________
blindirana lying,
mounting lying,
of the lattice
Re: SP2. Laser modulator
Posted: Mon Sep 26, 2016 17:29
by ЛИЛИЯ-Р
It is interesting, too.
Posted: Mon Sep 26, 2016 17:47
by мимоходом
I watched the video with laser - fun... Well, spring here, lasers, phasers, crystals... a question appeared - the ultimate goal is the activation of the crystal? And how to understand the crystal is activated or not? How to track that work?
Posted: Mon Sep 26, 2016 18:14
by мимоходом
to measure the ostsillogaf. one probe in the crystal, the other in the ground
A very good method!
That is, the oscilloscope displays a voltage on the crystal relative to the earth potential? That's great! By the way, AC or DC voltage? And can write the amplitude value of this measured voltage for the three cases:
a) to charge the crystal
b) during charging of the crystal
C) after charging of the crystal
and for AC voltage - frequency...
well, very interesting
Posted: Mon Sep 26, 2016 18:21
by Шалтай Балтай
мимоходом wrote:a Very good method!
I'm glad You liked it
You tell me:
мимоходом wrote:here is an abstract example: take the ring, connect the oscilloscope probe (a second probe grounded) and see the actual picture, bringing to the ring hand, telephone, TV antenna socket with 50Hz and so on... Maybe something interesting will be found, for example in the socket 50 Hz, and the ring is induced by transformation 67Гц (well, you never know).
viewtopic.php?p=157336#p157336
or have you forgotten?
Posted: Mon Sep 26, 2016 18:22
by мимоходом
Forgot. Very interesting what results happens in practice. Please write
Posted: Mon Sep 26, 2016 18:24
by Шалтай Балтай
мимоходом wrote:forgot. Very interesting what results happens in practice. Please write
Please remind me, Mr. in passing, since when Humpty was signed to carry out Your instructions?
If Your own ideas You yourself do not need, why do You think I care?
Posted: Mon Sep 26, 2016 18:26
by мимоходом
I wasn't given any instructions - just asking how you know that the crystal is activated ))) You said you can verify this with oscilloscope. I suppose if you did have written, what is the complexity what to write )))
Posted: Mon Sep 26, 2016 18:28
by Шалтай Балтай
мимоходом wrote:You said you can verify this with oscilloscope.
yeah, and even fotografa and crystallographer
PS
will carry in the flame
Posted: Mon Sep 26, 2016 18:31
by мимоходом
PS
well, what else to do, having infinite power ))) the question is very uncomfortable.
to measure the ostsillogaf, fotografa, a crystallographer. one probe in the crystal, the other in the ground
It's funny that the device is "crystallography" does not exist in principle. As "fazagraf" ))))
Posted: Mon Sep 26, 2016 18:43
by Шалтай Балтай
мимоходом wrote:Funny that the device is "crystallography" does not exist in principle. As "fazagraf" ))))
amazing!
Dear,
passingI hope You do not aim compromentation Club Self-development? You're it party. I could be wrong, but it nalegaet certain obligations. You can judge the Club as a whole. It is the responsibility.
Posted: Mon Sep 26, 2016 18:52
by мимоходом
I hope You don't aim to compromentation Club Self-development?
In any case. Really did not understand exactly how you feel about the club... Or to self-development...
I just wanted to ask how do you know that your devices are working. Was sufficient for any plausible answer with the evaluation criteria. For some reason you chose to write about the measurement with the oscilloscope, although not have them. And also invented two non-existent device...
Posted: Mon Sep 26, 2016 19:00
by Шалтай Балтай
Yes, I still have very much to learn.
Einstein once said: "I know two infinite things. First - the universe, the second is human stupidity." Then I thought, and added: "On account first - not sure."
Posted: Mon Sep 26, 2016 19:06
by мимоходом
And yet... the Answer will be something about how to understand what the crystal is activated? On what grounds? It's kind of an obvious thing and answer to this question is simple I guess
Posted: Tue Sep 27, 2016 10:08
by Шалтай Балтай
I apologize
I see no point in continuing the conversation.
good Luck
