The rotation energy and the floor of the crystal.
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Thu Feb 03, 2011 14:54
Eunician
Needless to say. The device on copper, produces about 95% of the Yang energy.
димыч
Been thanked: 16 times
Post by димыч » Thu Feb 03, 2011 18:52
well I came across this info - then better silver at the bottom of the cake and sides,
the crystal and top of cake copper or gold
to come out then that energy will be absorbed into the bottom and sides, and emitted a horse..
it's probably better without the passive coil to do so, will be the destroyer of chemistry and clouds...
as things get complicated, and the silver reluctance to spend without a predictable outcome...and the crystal mind.
by the way, I like crystal bisexual, he faces symmetrical on each side... what can I do with it?
I like man Yin if I should use Inskin crystal, we can actually become inhuman, or Vice versa, I don't have enough Yang
МерКаБа
Post by МерКаБа » Thu Feb 03, 2011 19:50
Silver is better near the crystal (as energy), the flow of orgone is better to direct density orgonite.
Two-headed crystal (real), have the Yang side and Yin, I put the Yang to the top of the device. It is not so much with the use of Mobius.
Inskin man you can be, only by having non-traditional sexual orientation.
An overabundance of one type of energy can cause energy imbalance in the body, so care should be taken to direct the device itself and to be guided by the advice of the unconscious, through dowsing.
димыч
Post by димыч » Thu Feb 03, 2011 21:04
and I thought that people Yin is introverts :)
I mean that crystal that is bisexual but not two-headed, due to the fact that faces the apex of the symmetrical and the left and right. on one level, really Yin side of the Cup like below a millimeter, I do not know whether this plays a role
this is judging on the floor in the picture on the first page of the topic
User avatar
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Feb 03, 2011 21:26
МерКаБа wrote:Inskip man you can be, only by having non-traditional sexual orientation.
Correct - among men of different sexual orientation is perhaps the most Yin of male, but not all Yin-men p-Sy...
Sincerely, MAG.no
MagicianII
Re: Rotation energy and the floor of the crystal.
Post by MagicianII » Fri Sep 30, 2011 13:39
Hello! Could somebody help to understand how to wrap the knot of the Mobius strip? Searched the net, nothing worthwhile is not found. Minijack connects to this node?
MagicianII
Post by MagicianII » Fri Sep 30, 2011 13:52
If instead of epoxy resin to use silicone glue?
User avatar
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Fri Sep 30, 2011 14:47
MagicianII wrote:Hello! Could somebody help to understand how to wrap the knot of the Mobius strip?
http://web.archive.org/web/201007120240 ... osknot.htm
MagicianII wrote:Minijack connects to this node?
Yes.
MagicianII wrote:is it Possible instead of epoxy to use silicone glue?
no.
Your questions have nothing to do with topic branch. Ask your questions at the SP in the relevant subject.viewtopic.php?f=32&t=3295
User avatar
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Fri Sep 30, 2011 22:47
MagicianII
Go there viewtopic.php?f=32&t=3937&start=50
You'll find the answer. :?
MagicianII
Post by MagicianII » Sat Oct 01, 2011 2:57
Lancelot, thank you!) Thought hopeless)
User avatar
Vinki bap
The rotation of power and crystal floor
Post by Vinki bap » Thu Oct 20, 2011 14:22
Link the first bone to another, which will be responsible for the rotation around the axis. Pristinity to it the mesh.
How is the twist of the forearm.
Or I misunderstood something?
Post Reply
