Uploaded with ImageShack.us
I did not used a lot. So, don't expect anything supernatural.МерКаБа wrote:Bronze powder will increase the resistance orgone, but the stimulation of the EM field, will give much more energy, so that, indeed, careful. By the way, the range of operation of the device due to the bronze, also needs to be more.
I read it.МерКаБа wrote:If the density of orgonite higher for the release of energy will require high power EM, but the number of energy will increase significantly.
The couple, as I remember, all the way around.МерКаБа wrote:If you use a steel (wool), organic will also have a higher resistance than if you used aluminum or copper.
15hzМерКаБа wrote:And you kind of frequency filed?
In in in.....Логик wrote:head began to grow heavy.
PralnoЛогик wrote:But, bearing in mind the written above - well, it nafig will have to wait.
