there is the link below, in tuesca from birch bark
and here too http://prorokrus.livejournal.com/7103.html
Very glad I found like-minded people
I use synthetic ultra-pure (optical quality) of the piezoelectric quartz. after a few comparisons from the natural crystals refused - not qualityЛанцелот wrote:If you read his blog, it is a battle crystal. I understand that locally is Gus Crystal.
solely on subjective feelings, and their users - natural quartz gives a soft energy. About "scrap quartz" mentioned in the answer to question human - where to find crystals. they are numerous, you just have to know where to look.Логик wrote:And how do you define "quality"? The sensations? Or to influence events?
I have one in SP. Works.MagicianII wrote:Can I take rauhtopaz based on if it is a bit darker than rhinestone?
Me too, but I didn't have synthetic quartz. Have not yet tested it personally, we can only speculate.MagicianII wrote:it seemed to Me that natural is much better synthetic....
Synthetic quartz cheaper for the same purity natural quartz. More precisely I can not say.MagicianII wrote: Cheaper synthetic quartz and is it possible that instead of quartz to use
Citrine and Amethyst are derivatives of quartz, but they are expensive.MagicianII wrote:is it possible that instead of quartz to use?
in principle, you can simply place the crystal in the coil box. then simply won't run in "passive" mode. because the crystal will not be squeezed with the resin. so pick up any (not magnetic ) from non-magnetic material - paper, aluminium-copper - put in her cap (so that the epoxy inside is not covered and make mud pies. then you can insert different crystals. I did - worked. in Towerbuster so, too, do crestally under or in tubes.MagicianII wrote:Yes it is interesting) I just never seen the magic of the ancient ways has become a technomage))
Today I rauhtopaz bought by you, it will just fill it with epoxy, then will not tear off if necessary.
Whether this gear-rope ways? For example to wrap the crystal in front of silicium resin - paligoy or something? Depends on whether the device's power to the immersion depth of the crystal?
Логик wrote:So it is necessary to compare similar purity crystals. Clear natural quartz to cost a lot of money.Prorok wrote:natural quartz gives a soft energy.
