Lenses
Алексей Швец
Has thanked: 2 times
Re: Lenses
Post by Алексей Швец » Sat Jun 04, 2016 6:50
The monitor emits on average with a frequency of 65-75 HZ visible to the eye. For example, 170 HZ monitor is not working and not showing. Also, there is no frequency less than 60Hz. Around here you can figure out what's what.
Rhinestone is used in the radio for receiving ultrasonic vibrations over 20,000 Hz.
http://www.jeland.ru/kamni-i-mineraly/g ... -bogov.htm
User avatar
Has thanked: 125 times
Been thanked: 263 times
Re: Lenses
Post by Шалтай Балтай » Sat Jun 04, 2016 15:55
Alex, I'm sorry, but to the lenses it has nothing
Let's try to respect those who are interested in the topic of lenses
Thank you in advance for your understanding
Алексей Швец
Re: Lenses
Post by Алексей Швец » Sun Jun 05, 2016 10:28
Шалтай Балтай wrote:Alex, I'm sorry, but to the lenses it has nothing
Алексей Швец
Re: Lenses
Post by Алексей Швец » Sun Jun 05, 2016 10:35
How do you know that the lens is the vibration changes in the space at 144 MHz?
User avatar
Re: Lenses
Post by Шалтай Балтай » Sun Jun 05, 2016 14:26
Алексей Швец wrote:how do you know that the lens is the vibration changes in the space at 144 MHz?
did I made such claims?
Алексей Швец
Re: Lenses
Post by Алексей Швец » Sun Jun 05, 2016 15:11
Common question ,to maintain the theme.
User avatar
Re: Lenses
Post by Шалтай Балтай » Sun Jun 05, 2016 15:23
if the lens on sacred standards to do, then Yes
I wrote about it viewtopic.php?p=155054#p155054
Алексей Швец
Re: Lenses
Post by Алексей Швец » Tue Jun 07, 2016 6:23
Humpty Baltay thanks for the tips on the subject will take into account.
If you go back to the lenses, you can choose lubuu. There probably has value as energy. If it was a 144 MHz wave from bricks or meteors,then you should think :) :(
Андрей Ка
Has thanked: 10 times
Been thanked: 1 time
Re: Lenses
Post by Андрей Ка » Sun Jul 31, 2016 23:41
Came today of the ring.
Stuck to the bottom of the bath. It is not clear how much time to charge a glass of water on the lens. Assume that the volume of water in the tub and a 10-15 minute multichange will not be an overdose of light.
Put in the sofa to sleep. Will follow state and reaction.
User avatar
Re: Lenses
Post by Шалтай Балтай » Sun Jul 31, 2016 23:52
Andrew Ka
Андрей Ка wrote:it is not clear how much time to charge a glass of water on the lens
I would say that for significant changes to the glass enough 3-4 min.
The pitcher in 2l, I would give six hours (overnight in the fridge)
a bath ... um... haven't tried is a very large amount of water for lenses :)
Андрей Ка
Re: Lenses
Post by Андрей Ка » Sat Aug 06, 2016 14:35
ЗОМБ wrote:
As I understand from the translated subtitles:
1. The spacing should be equal to quarter inch (0,64 cm)
2. The lens can be placed behind a picture, mirror, etc.
3. To the negative did not go in the opposite direction and not to harm people (neighbors, colleagues), must be earthed using foil. But I do not understand what is the area of the piece should be.
4. The lens lay in the pocket of paper, drawing a smiley face on one side to determine the correct position.
5. 6:41 About a hat with attached lenses. The translation is not made clear which side should be lenses. But most likely the smiley should look inside the skull.
6. In a plastic bag put a piece of steel wall (what is this? and whether there are analogs at the hardware store?) and stretch. It will be an absorbent material and put it inside the smiley face out. To put around the house, etc., and the stuffing will absorb the positive ions.
7. The author of the video sensed ions from the bag with a smiley face at the distance of half a mile and prodoljali separation of the ions up to 1.5 miles.
8. 9:03 How to position several lens: 2 inch (5.08 cm) between them, mouth lenses should not be directed into the next lens.
9. In the form of a washer taken from somewhere else, and adds resin and iron. The more iron, the more you absorb the positive ions and negative ions are expelled.
10. The washer attaches to the lens. She puts a gallon of water. 5 seconds and the water is charged with negative ions. Day the charge lasts.
Андрей Ка
Re: Lenses
Post by Андрей Ка » Sat Aug 06, 2016 14:43
Андрей Ка wrote: 3. To the negative did not go in the opposite direction and not to harm people (neighbors, colleagues), must be earthed using foil. But I do not understand what is the area of the piece should be.
3. It turns out that the neighbors below get negative from positive ions coming from owners of the lens on top?
Андрей Ка wrote: 6. In a plastic bag put a piece of steel wall (what is this? and whether there are analogs at the hardware store?) and stretch. It will be an absorbent material and put it inside the smiley face out. To put around the house, etc., and the stuffing will absorb the positive ions.
6. If I stuck to the metal bottom of the bath, the output of negative ions is blocked or is not, since we need metal back to the object from which to get negative ions?
User avatar
Александр Н.
Has thanked: 30 times
Been thanked: 50 times
Re: Lenses
Post by Александр Н. » Sun Mar 19, 2017 14:38
Humpty Baltay
Can share the graphic templates for the manufacture of printed circuit boards? Thanks in advance!
Or is it paid?
User avatar
Ольга К
Сотрудник mindmachine.ru
Has thanked: 1 time
Been thanked: 17 times
Re: Lenses
Post by Ольга К » Mon Aug 21, 2017 16:55
Lens appeared in the office.
Diameter 9 cm.
Prices:
1 PCs - 480 RUB.
2 PCs 880 RUB.
3 PCs - 1260 RUB.
http://www.mindmachine.ru/lenses/lenses.htm
User avatar
Re: Lenses
Post by Шалтай Балтай » Mon Aug 21, 2017 18:19
New lenses, for another pattern, now this:
144 is the measurement, details here: viewtopic.php?p=155651#p155651
and the size of the other - they are more.
Расторгуев
Has thanked: 6 times
Been thanked: 6 times
Lenses
Post by Расторгуев » Fri Jul 26, 2019 1:49
In the Original, the two ends merge in a common circle.
Post Reply
