Шалтай Балтай wrote:here is Mr. warlock, who claims that he has a design JV with two obiusly that it energizes the sine and binaurally, and it seems to work. If so, then the quality of such products, of course, more "noise" there must be minimised. But I have no data on the device.
If the warlock can share - love to hear.
There is so much construction! Surprised that few people have gone this route, most of the sources of the audio signal of the stereo, what good to disappear? Everything is simple, plain fruit cake (resin, shavings, zagibin all sorts of taste), only
two on-chip toroidal coil (two Mobius), respectively, come out 4 wires. The signal for left and right channels on separate coils. The signal generated in the app drive in the player and Bang... the Trick here it is, the common mode signal in both channels technically should be stronger than the same in a single channel. It turns out, but the power gain feels not very big, barely noticeable.
With binaurally I started experimenting for the sake of Osov and similar practices. It should be noted that the meander is perceived by the crystal is stronger in the sense that the square wave it reacts more readily than a sine. Don't quite understand what was meant by "noise", but part of adobovskogo sine wave in fact softer. The concept of "quality" I guess it's not the best way describes the situation, because each waveform has its own, clearly defined by a number of harmonics, and this can not be avoided. That is, feeding a sine wave or square wave, or saw, or a trapezoid, in addition to the fundamental frequency we send to the coil and even multiple frequencies. In the case of meander some more extended harmonics and odd it is expressed highly, and the sine wave - most "poor" harmonics option.
Sorry, but I have no oscilloscope, it would be interesting to see what's really going on, because the coil, even double, is still a inductance, still it has the capacity, and therefore the whole design is definitely the filter. Every filter affects the final waveform. And that's actually the filter is the same q-factor, i.e. width of the noise they bandwidth. The wider the bandwidth, the lower the quality factor, the less the effect of the filter on the waveform.
From observations. Binaurally we listen to the ears so that the valid range for this frequency is limited by the hearing and the air environment. In the case of the crystal the situation is slightly different environment from us silica and the surrounding ether/orgone, and the organ of perception the entire body. That is, the ears have nothing to do with it. Crystal turned out to be equally well translates into the environment as a high frequency, and Infranet. Using the binaural technology has managed to get it to work at frequencies from 20 Hz and below that in meditation practice was a great help. You can sleep next to SP not bothered headphones or even some devices that are in direct contact with the body.
It is possible to generate in one channel the right frequency, but it is not the same as two loved ones in different channels. Low runout, we call the difference between the higher frequencies which the crystal reacts more readily.
In the most General terms, is everything. There are more observations, but this is beyond the scope of the topic.<
