Ring. Empirical tests
Posted: Mon Jul 18, 2016 10:19
All good zdraveska
From Wiki:
in short, the Empirical means repeatable, regardless of BP, operator of the Besh
for example:
The second experience was shown in a video interview with slim. The difference can be seen VERY well. In fairness, it should be noted that not used ring, and Aku-Wack, even more precisely, Aku-Wacissa!
In a couple of Slimowski kulakoff (slim maybe skinny, but the fist he - Kuznetsk
). What is Aku-WAC third measurements I know for sure, that's what used slim, this is probably the seventh.
Thick wire somewhere treshka in gold. Generally a toy that still.
I mercuy that for good results the Empirical tests just need more powerful devices, or to hold water longer.
If anyone has entuzazizme - publish the results here.
Good luck!<
From Wiki:
that's bonkersEmpiricism, empiricism (from al-Greek. έμπειρία — experience) — the direction in epistemology that recognizes sensory experience source of knowledge and assumes that content knowledge can either be represented as a description of this experience, or reduced to it[1].
Opposed to rationalism and mysticism. For empiricism typical of the idealization of experience, of cognition, downplaying the role of rational knowledge (concepts, theories). As a holistic epistemological concept empiricism was formed in XVII—XVIII centuries (Francis bacon, Thomas Hobbes, John Locke, George Berkeley, David Hume); the elements of the empiricism inherent in positivism, neopositivism (logical empiricism).
for example:
- The water activated the rings, and frost resistant slower-than-not processed - Empirical
- The water activated the rings, has the best flavor - NOT Empirical
- The water activated the rings, and frost resistant slower than not processed
- In the water, activated the rings, clearly visible beam laser
- If using water, activated the rings, skip white/solar light, then the diffraction picture clearer
- If you put the fruit in the ring, they slowly deteriorate
- If you put the sprouts in the ring, they are faster prorostayut
Good luck!<
