Malika Yes, the candle you can even just close until the work is mentally all stuck under Kouakou off to send mentally there.
Re: Rings for slim, reviews
Posted: Fri Sep 30, 2016 12:08
by МерКаБа
Amethyst is conveniently in the middle of Kubaka stick. If I correctly spotted, at the entrance to the crystal every cocoa dissolves. There is probably more RF component is affected, as with other crystals is felt not so much.
Posted: Fri Sep 30, 2016 12:20
by ЛИЛИЯ-Р
МерКаБа wrote:Amethyst conveniently in the middle of Kubaka stick. If I correctly spotted, at the entrance to the crystal every cocoa dissolves. There is probably more RF component is affected, as with other crystals is felt not so much.
Just about amethyst noticed. Only I have the picture about the other device was with amethyst. But while the exact parameters are not given))) You and sherl, though vigorous , he himself cleans without all, although they are also different in structure.
Posted: Fri Sep 30, 2016 13:41
by Артфан
Шалтай Балтай wrote: trap
How to make or where to buy? Then kuvak on the candle, a trap too?
Posted: Fri Sep 30, 2016 14:24
by Шалтай Балтай
Артфан wrote:How to make or where to buy? Then kuvak on the candle, a trap too?
Good zdraveska, Artfan
I can't call myself an expert in the field of searchanyway the larva, as well as various non-biological cucinotta I have with them rather parity. But I would posoli myself to recommend "view" to the side:
Crystals. Not only Amethyst, as mentioned above. Although my personal IMHO that the combination of Host and crystal for the poor would be fatal
Aware of Mr. from Lujan city, I would say: Stone spheres of various sortoff and ratmiroff. IMHO, good enough to be used as "prison-traps" for larvae. There is the ethical aspect, of course, but I'm not rekomnduyu data technology, it's just talking about what And who is really every man for himself
Continuing the idea, I'd say that if the larvae don't need you can just plastikovye beads, and subsequent disposal.
Natural fillings, wool, grass, wood, stone, resin, incense... etc. etc.
Smoke, fire, water, sound.
Everything is better inside the node.
Hope I helped
good luck
Posted: Fri Sep 30, 2016 15:19
by Шалтай Балтай
Шалтай Балтай wrote:Everything is better inside the node.
uh... except fire, of course
Posted: Sun Oct 02, 2016 11:41
by ФилиНН
ФилиНН wrote:essence in her perceptions stuck in quake and took them out and push into the ground
... sat there that night, weak, but back.
So contrary machinery and TB, TB, TB...
Posted: Sun Oct 02, 2016 15:11
by Разумный
Tongue-tied and Aesopian language, my friends, or what?
Or is it just a high wind, is not available to the commoners?
Posted: Mon Oct 03, 2016 19:15
by ЛИЛИЯ-Р
Разумный wrote: translate and confirm below.
The aunt Kouakou tried it, took off and did not burn a candle. Saturday saw her some where...had on occasion, so they dejected was a little-a little force , but the flutter she said. I went to check, I have other goals were in the wrong place. But better as owl and writes TB-safety. If he is clean it is still a candle. If someone much more than one. Cleaned katagami HF -had seen ))) and Kawakami too but a bit less. Because TB and time TB is a candle.
Posted: Tue Oct 04, 2016 12:29
by *****
Cho-TA da! Branch becoming a closed club!
Throw off where-ever read about the enti "essence," and that candle autos.
Posted: Thu Oct 06, 2016 18:25
by ЛИЛИЯ-Р
*****When the alien program in the body is called on every depends on them. Things do not just let this go, because they are on a candle))) .There is no secret whatsoever.
Posted: Thu Oct 06, 2016 19:04
by *****
Where are the candle-and-so. And that may happen:"We have it on a barrel of gunpowder planted. Let him fly!"(C)
Posted: Tue Oct 25, 2016 2:43
by Шалтай Балтай
Posted: Tue Oct 25, 2016 10:14
by Шалтай Балтай
Add a couple of cents (all IMHO)
Now change formations. The old socialist (Yes, still, I misspoke) away. New generation is an Android, with highly klipovoy consciousness. This creates a lot of problems. For example, the main broadcast base for the policy was the telly, but this form does not support interactive mode, so do not fit into smartphones. Generation of Android Pro high a policy heard. Has been in the way, it's good.
Such are actually polar, a cognitive system must give conflict situations. Products 177й Measurements, Kuvak in particular intended to solve such problems.
And again: I believe that those who take up products 177й Measurements already have at least one product 144й. TB - our FSE!
Posted: Tue Oct 25, 2016 21:49
by Малика
Good evening, Humpty!
Glad to hear You and to read))) has Long been the range is not expanded... I would Like 144х 3 or 4ki..
I watched the video, for some reason, only one color is present, yellow-gold, but very beautiful shimmers, from the video sharp feeling of freshness, sometimes as much as breath
it may be due to the short 144ой powerful kuwaki ?..
I also drew attention to the fact that it is better not to tell anyone about the results..it is better to do in silence..
Again, which is great to wear kuwaki a bag..
Posted: Wed Oct 26, 2016 15:58
by Шалтай Балтай
Good zdraveska, Malik
Малика wrote:maybe it's due to the short 144ой powerful kuwaki ?..
it may very well be
Малика wrote:I also drew attention to the fact that it is better not to tell anyone about the results..it is better to do in silence..
here. in this context, I thought about making pendants.
Posted: Wed Oct 26, 2016 18:21
by Артфан
Шалтай Балтай wrote: in this context, I thought about making pendants.
The pendant will cylindrical. Ladies would not approve...
Posted: Wed Oct 26, 2016 18:51
by Шалтай Балтай
Артфан wrote:Ladies would not approve...
maybe You underestimate them?
Posted: Wed Oct 26, 2016 19:11
by ФилиНН
Шалтай Балтай wrote: new generation is an Android, with highly klipovoy consciousness. This creates a lot of problems. For example, the main broadcast base for the policy was the telly, but this form does not support interactive mode, so do not fit into smartphones. Generation of Android Pro high a policy heard. Has been in the way, it's good.
Bearing in mind the synergy of these measurements and not forgetting TB, followed by the sacral accordion-1 soon added her in the crowd and forgotten garmoshechka-0.5 with the corresponding kabusecha, all braided. Let harmonize TVs with androids in the area I don't really need - after the removal of the TV to the country 5 years ago, stuck in timelessness, neither the one nor the other
\Yes, there is a merc there were 67 Goss-minus an inch. It in a sandwich rings with the other three don't need - reduce the overall energy. Better to flow with products from the different parties directly on the client, and mixed. \
Posted: Wed Oct 26, 2016 19:18
by Шалтай Балтай
ФилиНН wrote:behind the sacred accordion-1 soon added her in the crowd and forgotten garmoshechka-0.5 with the corresponding kabusecha
Oh! respect! I'm on 177 harmonica and intentions do not build
Posted: Tue Nov 01, 2016 16:10
by Влад Н.
Hello! I worked with Rings Sliema - Sacral Merc (mental without products) for 1 month and for 2 months already with rings don't work, but left a strange feeling. It looks like a calm, doing nothing, a meditative state, feel the sweetness in your mouth, and what is the feeling, feeling that rings like joined with my body, and don't want to leave. With the rings I do not work for 2 months, and I have now gone physical. Since I have a big sensitivity, I previously represented figuratively the product, and felt it physically. So I could create some Rings and work with them and at the right time, turn them off. In General, at first I liked it, but then I realized that the feeling I felt when I was working with virtual products, it remained, but weaker after the cessation of work. And now still kept. And I don't want to!! I'm not comfortable to be constantly in this state. How to get rid of this as I don't know. a Manger who knows how to disconnect from the rings, please? Pandora and the COP light didn't help. Also tried to erase all traces of the mental ring, if they made a mark in the space when I worked with them. Not helping!
Tell me can anyone have any opinion about this, you may have encountered such a phenomenon! Thanks in advance!
Posted: Tue Nov 01, 2016 18:00
by ЛИЛИЯ-Р
Влад Н. wrote:Hello! I worked with Rings Sliema - Sacral Merc (mental without products) for 1 month and for 2 months already with rings don't work, but left a strange feeling. It looks like a calm, doing nothing, a meditative state, feel the sweetness in your mouth, and what is the feeling, feeling that rings like joined with my body, and don't want to leave. With the rings I do not work for 2 months, and I have now gone physical. Since I have a big sensitivity, I previously represented figuratively the product, and felt it physically. So I could create some Rings and work with them and at the right time, turn them off. In General, at first I liked it, but then I realized that the feeling I felt when I was working with virtual products, it remained, but weaker after the cessation of work. And now still kept. And I don't want to!! I'm not comfortable to be constantly in this state. How to get rid of this as I don't know. a Manger who knows how to disconnect from the rings, please? Pandora and the COP light didn't help. Also tried to erase all traces of the mental ring, if they made a mark in the space when I worked with them. Not helping!
All in your head . Your brain has built a relationship with fizicheskimi products and projected it on the body and mind. Find the button that enables and disable these feelings. And they also projection of your brain, like everything in this world for each of us. Do not flirt with his super importance and ability and the whole "feel" in the distance. If you could teach your brain to identify all the(test) distance mentally , to learn off, it's easier. Cut off toggle switch from an energy supply(the feelies) and all-Kina no))).<
Posted: Tue Nov 01, 2016 23:34
by ММ
[quote="Vlad N."]Hello! I worked with Rings Sliema - Sacral Merc (mental without products) for 1 month and for 2 months already with rings don't work, [b]but left a strange feeling[/b]. It looks like a calm, doing nothing, a meditative state, feel the sweetness in your mouth, and what is the feeling, [b]feeling that rings like joined with my body, and don't want to leave[/b]. With the rings I do not work for 2 months, and I have now gone physical. Since I have a big sensitivity, I previously represented figuratively the product, and felt it physically. So I could create some Rings and work with them and at the right time, turn them off. In General, at first I liked it, but then I realized that the feeling I felt when I was working with virtual products, it remained, [b]but weaker after the cessation of work. And now still kept. And I don't want to!![/b] I'm not comfortable to be constantly in this state. How to get rid of this as I don't know. [b]Manger who knows how to disconnect from the rings, please?[/b] Pandora and the COP light didn't help. Also tried to erase all traces of the mental ring, if they made a mark in the space when I worked with them. Not helping!
Imagine the fortune to work rings. Do it every day. As you felt your body then.Must go.
Tell me can anyone have any opinion about this, you may have encountered such a phenomenon! Thanks in advance![/quote]
Posted: Tue Nov 08, 2016 15:34
by Шалтай Балтай
Was given a bronze kuwaki, 144й and 177 Measurements 3.5 size.
I hope soon will be back in stock.
The bronze Kuvakov there is a difference in technology. I twist the wire before you cut.
I wrote about it here: viewtopic.php?p=162563#p162563
+ I became a "tempering" of the welding seam, just water (by the way is not easy, but from under the rings )
Posted: Wed Nov 09, 2016 13:21
by Шалтай Балтай
A few words about the bronze
In the passive variant bronze copper nodes are not efficient, although a slightly different aspect. But the difference I'm not really ready to describe with words.
So if you do not plan to activate the node and use it only in passive mode, I would recommend the copper.
In the case of sound activation, the difference is fundamental. Learn more about testing the products in sound active mode here: viewtopic.php?p=160543#p160543
I now eksperementiruyu with sound, I will try to upload videos later.
