Ring. Sacred measurements
Post by Шалтай Балтай » Fri Apr 29, 2016 10:47
the Main goal of a topic: to give work measurements to create the rings
Source: http://www.sacredmeasures.com/measurements.html
Types of Standards there are two: those that are ring and linear (no need to ring spinning, and so works)
Measurements for rings
Basic measurement
Frequency: 144 MHzlength: 523 mm
Basic use: Any problems 3D plan
Code: Select all
|Harmonica | Length mm | Diameter |
|part or | | ring, mm |
|1 | 523.2 | 166.6 |
|1 1/2 | 784.9 | 249.8 |
|2 | 1,046.5 | 333.1 |
|3 1/2 | 1,831.3 | 582.9 |
| 1/2 | 261.6 | 83.3 |
| 1/4 | 130.8 | 41.6 |
| 1/8 | 65.4 | 20.8 |
the Forgotten Merc
Frequency: 177 MHzlength: 596 mm
Usage: Work with intention, awareness, karma, past life regress
Code: Select all
|1 | 596.7 | 189.9 |
|1 1/2 | 895.1 | 284.9 |
|2 | 1,193.4 | 379.9 |
|3 1/2 | 2,088.5 | 664.8 |
| 1/2 | 298.4 | 95.0 |
| 1/4 | 149.2 | 47.5 |
| 1/8 | 74.6 | 23.7 |
Reinforced merc
frequency: 188 MHzlength: 733 mm
usage: the Pineal gland
(sorry, yet more information is not, recently used, jamahal ischo :?)
Code: Select all
|1 | 733 | 233.3 |
|1 1/2 | 1,099.5 | 350.0 |
|2 | 1,466.0 | 466.6 |
|3 1/2 | 2,565.5 | 816.6 |
| 1/2 | 366.5 | 116.7 |
| 1/4 | 183.3 | 58.3 |
| 1/8 | 91.6 | 29.2 |
to be continued ........
Linear measurements
PS
At first glance it may seem strange that a high frequency ACC greater length, kiczales it should be the opposite. Slim said in an interview. The bottom line is that this is not hormonal frequency and resonance, it has its own laws. To understand this it is necessary to read Hans Becker, whose writings I can not find. There is another person, bill Ryde, a friend of slim, he is not less in the subject than slim, maybe more, but if you believe Brian, which is Infinite, the bill is strongly encrypted. In General, it all looks like a detective story, so far is.... :?<
Смелый
Re: Sacred measurements
Post by Смелый » Tue May 03, 2016 2:37
Шалтай Балтай wrote:usage: the Pineal gland
Purely mechanical translation of the website says about the allocation of programs and beliefs. That is, it is about the realization of the goals likely?
And do you have an idea to start a separate thread where you can chat about assumptions and share experiences. So maybe it's time to start?
Post by Шалтай Балтай » Tue May 03, 2016 5:36
working with intention, radione almost starts with 177 MHz, the Lost measurements. 188 IMHO seems to be more on intuitive perception, viewing noumena, vision. It is clear that the control gives you control
if by the standards, then shoot the breeze here, I think....
Смелый
Post by Смелый » Thu May 05, 2016 15:55
The linear measurements. They have the same dimensions, not looped? Just two trim 11 cm, twisted, wire 4 mm. in any effort, of which the ring on your finger will not do. As well as a cut and carry little pencils in the pockets.
Post by Шалтай Балтай » Thu May 05, 2016 16:05
Смелый wrote:Linear measurements. They have the same dimensions, not looped? Just two trim 11 cm, twisted, wire 4 mm. in any effort, of which the ring on your finger will not do. As well as a cut and carry little pencils in the pockets.
no, no, that other linear dimensions:
a lot.
Sacred Cubit - 25.025” or 63.520 cm
1/3 of this length (21 cm) produces
the sine wave of the frequency
of the hydrogen atom.
Black Cubit - 21.352” or 54.153 cm
Both Cubits above are used in ourKeys and Starbursts, and work similar to Tensor Fields in their
elctro - and geo - magnetic restructuring.
The Remen Cubit - 14.583” or 37.441 cm
This is the Cubit Bill Reid uses in his version of the Starburst design
honestly, anything yet did not do with them :?
Brian is a Devas in the lab, able to cut with accuracy to the micron or something,
looks like it's about it t:
[youtube]http://www.youtube.com/watch?v=fUnb6aAYixE[/youtube]
Смелый
Post by Смелый » Thu May 05, 2016 16:16
Well, while leave! Thank you!
Смелый
Post by Смелый » Sat May 07, 2016 16:16
Шалтай Балтай wrote:Brian is a Devas in the lab, able to cut with accuracy to the micron or something,
A little peresmatrivat. Looked at this device they have to implement. Looks like a very useful thing, but it is not twisting. There wand, bearing and etc. In terms of workmanship, personally I don't bother. And then I was dreaming. Twisted, cut and enjoy.
Post by Шалтай Балтай » Sat May 07, 2016 19:27
Yes, linear measurement - just cut the wire
Офелия
Post by Офелия » Thu Jun 16, 2016 21:19
Hmm, I was thinking of trimming to attach, but here not all so is simple... So what's with the "linear products"? What are the dimensions what are harmonics?
Офелия
Post by Офелия » Thu Jun 16, 2016 21:22
Today slept with 523 and 596-m, and while they are glued with tape, great sleep, vivid dreams, relaxed the body.
Офелия
Post by Офелия » Fri Jun 17, 2016 23:03
Found... ( linear).
Боб
Post by Боб » Sun Jun 19, 2016 13:20
Hi Humpty!
Browse the site http://twistedsage.com/products/ Twistedsage Studios - a lot of interesting items offered, but here's a question... Say http://twistedsage.com/products/heavy_harmony/ - 9" Harmony Ring - 9" is 22.86 cm diameter I suppose. Such a diameter would not match the table of standards. And many such examples, so the question is this: what am I? or Brian Besco other measurements so famously uses or rounds?
Post by Шалтай Балтай » Sun Jun 19, 2016 19:30
Боб wrote:hi, Humpty!
Good zdraveska, Bob
Theme standards, as well as the theme nesterovskij length - semi-closed, those who have knowledge are not keen cestovatele
Brown uses the trail measurements: http://www.sacredmeasures.com/measurements.html
at least those that he exhibits openly
In General slim and brown talking about the 19 known nesterovskij lengths
About Accordion measurements - honestly, I didn't understand, while missing the fact that there is
On the other hand brown - adequate person and responds to emails, I ordered from him several goods, let's see how will come
The fact that he famously rounds may not be considered, for example, linear measurements viverette special device, it seems to microns
besides, you need to understand that 9" this does not mean 9.00" this is just the estimated size that the person would have provided dimensions that takes accurate measurements in the description
hope I helped :?
Post by Шалтай Балтай » Mon Jun 20, 2016 4:31
2 Bob
Looks like Accordion Ring this STU
Standard Teotihuacan Unit (STU)- There is much information about this cubit measure: where it came from, the creation of the etheric template, and what it can do. The Balance and Harmony Ring is the result. Here are the details.
The Rings cut from this Cubit can be used in 1/4, 1/2, etc., just as standard Tensor Rings,
as well as in the 1/3 increments to create a working Ring.
41.7086614" or 105.94 cm
This Cubit can be used in creating Straight-Line frequencies.
львёнок
Post by львёнок » Mon Jun 20, 2016 10:35
but the question is... Say http://twistedsage.com/products/heavy_harmony/ - 9" Harmony Ring - 9"
Hello, Humpty!
There, in this photo, there is no plot tinning, what is soldered so beautiful?
And you have not tried to do so?
Post by Шалтай Балтай » Mon Jun 20, 2016 11:03
Good zdraveska, lion
Thank you for your question.
Brown six years ring sculpt. He's got a lot to learn, ordered from him a few products. IMHO, I could be wrong, but twisting it doesn't look dense, but he makes a butt joint, argon welding I think. Perhaps, it looks more "nice", but perhaps at the expense of functionality.
All have their pros and cons :?
There is no target, he may be right :?
Боб
Post by Боб » Mon Jun 20, 2016 19:18
Шалтай Балтай wrote:looks Like Accordion Ring this STU
Thank you! It remains to understand what is the "etheric template" - the etheric template...
Пчела
Post by Пчела » Tue Jun 21, 2016 10:14
Шалтай Балтай wrote:but he makes a butt joint, argon welding I think. Perhaps, it looks more "nice", but perhaps at the expense of functionality.
Welded a couple argon. Standards one, 144 and 177. Somehow did not like. The connection is not so invisible was. Difference in the impact compared to copper solder didn't notice. However, I've talked to them for about twenty minutes and gave it to someone. Photos do not do because the rings are working.
Not to say that the best the enemy of the good, or Vice versa. But copper solder holds with dignity. Most importantly, carefully and accurately done. And that's enough.
No good deed goes unpunished!
Post by Шалтай Балтай » Tue Jun 21, 2016 10:41
Пчела wrote: Welded a couple argon. Standards one, 144 and 177. Somehow did not like. The connection is not so invisible was. Difference in the impact compared to copper solder didn't notice. However, I've talked to them for about twenty minutes and gave it to someone. Photos do not do because the rings are working.
Functional copper solder works 100%. Just to remove the excess during welding - not so easy, for this you need a fairly powerful torch, i.e., argon. If the blade is not very powerful, it can remain "excess" solder. Functionally is not affected, but aesthetically, of course there is a difference.
We will understand with time. While the rules, I'm happy.
Post by Логик » Tue Jun 21, 2016 15:51
Шалтай Балтай wrote: need powerful cutter, i.e. argon.
you probably wanted to write "acetylene". Argon is an inert gas. In gas cutting torches shall not apply. For welding only and how protective. Acetylene is that Yes, used for cutting, the flame temperature in tandem with the oxygen about 3000градусов with
Post by Шалтай Балтай » Tue Jun 21, 2016 15:58
Logik
Oh yeah! I could be wrong :oops:
although the search engine provides che: https://yandex.ru/search/?msid=14665066 ... 0%BE%D0%BC
dwuhvalentny welding for me until dark lezzzz :)
actually good need a workshop under the case, and one not always all hands to do.
Post by Логик » Tue Jun 21, 2016 16:24
Шалтай Балтай wrote:although the search engine provides che: https://yandex.ru/search/?msid=14665066 ... 0%BE%D0%BC
argon welding is a welding with an electrode with purge welded with argon space.
Brian (if video on how to do the ring shot it) there's an ordinary gas welding. And in that balloon of H. 3. Can a propane-oxygen, may acetylene-oxygen.
Post by Шалтай Балтай » Tue Jun 21, 2016 16:41
Yes Yes Yes Yes... sorry not special :oops:
Влад Н.
Post by Влад Н. » Sat Jul 09, 2016 9:18
Hello!
What is the amps. source http://www.sacredmeasures.com/measurements.html stated "144 MHZ Cubit~aka Sacred or Royal Cubit. Comes from the King's Chamber of the Great Pyramid. Slim Spurling''s Cubit. Known for its work in the Physical.
20.63 inches ~ 52.4 cm"and you write that, Frequency: 144 MHz length: 523 mm. A difference of 1 mm is permissible? . Now only that came across, another figure of 52.5 cm What is more correct value?
Post by Шалтай Балтай » Sat Jul 09, 2016 14:15
Yes, there are discrepancies as to the names and accuracy of the measurements depends on the source
more detailed info at this moment can not give :?
the measurements given above are those that used slim, precise working
