Page 24 of 27
Re: The Ring. Workshop
Posted: Wed Mar 08, 2017 23:38
by Мицкле
naughty wire ) -
Posted: Sun Mar 19, 2017 22:56
by Шалтай Балтай
not enough experiments with brass, heavy material, very fragile
only time takes away
Posted: Sun Mar 19, 2017 22:57
by Шалтай Балтай
Copper F5, A Half-Forgotten Measurements
Posted: Sun Mar 19, 2017 22:58
by Шалтай Балтай
It is the same in a different perspective
for those who watch remotely
Posted: Mon May 01, 2017 17:27
by Артфан
Шалтай Балтай wrote:Copper F5, a Half-Forgotten Measurements
Hello, dear Humpty. I'm a fan of loops. Whether You made the pendants loop continuous wear?
Posted: Sun May 07, 2017 15:16
by Шалтай Балтай
Артфан wrote: Hello, dear Humpty. I'm a fan of loops. Whether You made the pendants loop continuous wear?
Good zdraveska, Artfan
I think on the subject, there is the idea....
Posted: Sat May 13, 2017 17:18
by Шалтай Балтай
Spilo hot, still warm
this pendant in 1/4 merecki, F1.5, Three (triple wiring)
the above - 177, those that are bottom - 144
Posted: Sat May 13, 2017 17:19
by Шалтай Балтай
Posted: Sat May 13, 2017 17:20
by Шалтай Балтай
Kuvak, Basic, No. 308
by Шалтай Балтай
Posted: Sat May 13, 2017 17:21
by Шалтай Балтай
Colonel, 1 Scoop 144
by Шалтай Балтай
Posted: Sat May 13, 2017 17:22
by Шалтай Балтай
Oh, che is the magnifier dusty what :oops:
Posted: Mon May 15, 2017 12:29
by тундра
:) Humpty Baltay Thanks for your work !
you have begun experiments using enameled magnet wire - a question of how these rings worked in comparison with products manufactured by wire without insulation ?
should I remove the insulation ? or they have their additional effects
Posted: Mon May 15, 2017 12:40
by Шалтай Балтай
Good zdraveska, tundra
тундра wrote:you started the experiments using enameled magnet wire
accurate, is what was at hand
тундра wrote:how those rings worked in comparison with products manufactured by wire without insulation ?
emalirovanaya wire - better not to use. Better to do as slim.
Max diameter enameled wire - 2mm is not much.
Better to take 2.5 - 3mm f
тундра wrote:do I need to remove insulation
this is a very brutal operation, I would not have taken....
advice, don't reinvent leaped. Dalite like slim. Will make a certain amount of rings will have an understanding of maetrial, work with vibration, will get the return. Picture and going....
Posted: Sat Sep 16, 2017 16:42
by Шалтай Балтай
Link Linear Measurements
Information on them a little - don't torture me :)
Posted: Fri Jan 05, 2018 19:30
by Шалтай Балтай
Blank Aku-Waka: Ф4мм
Posted: Sat Jan 13, 2018 21:12
by Шалтай Балтай
I welded Kuvak F4:
The one that vinsu is a pendant, Pigtail F2, Kuvak New Dimension, 144 Main Measure, the First Size
Pendants is a good thing, always. It is very effective. If, for example, not in the mood for any person to communicate, the impression that the person is "flying" to a distance of a few miles, and completely can't see You 8)
Posted: Wed Jan 17, 2018 16:28
by Шалтай Балтай
Finishing transfer "TECHNOLOGY SLIM SPARLING"found an interesting paragraph:
In some of my last conversations with Slim, he told me that he had begun to
experiment with three and four twists of wire, instead of two. The idea came from
one of the men who worked in the shop with him. At the time, Slim decided to call
that ring the ‘Freedom Ring’ but his death interrupted its development and there are
very few reports on what it can do. Where that project will go is up to fate and time at
this point.
translation:
In some of the latest conversations of slim mentioned that he began experimenting with three and four wire strand wire, instead of two as obyachno. The idea came from one of the men who worked with him in the Studio. Slim decided to call the ring "rings of freedom", but his death interrupted his Razorback, and there is not enough material on the practical use of these rings.
Well, my otzyvaetsya To three Hundred Rings of Freedom on the slim :)
No, it sounds cool, but disappointing at the same time, well, no creativity, everything is already invented to us! :cry:
Posted: Sat Jan 20, 2018 19:06
by Шалтай Балтай
Not very successful attempts to increase the density of lay
Posted: Sat Feb 10, 2018 19:15
by Шалтай Балтай
Decided to use a pigtail yielded the following rings:
for sale of these products will not go, of course. This is for me... for the cobbler. :)
By the way, I'd say that Jola is funny, petal, like a flower of chamomile....
Posted: Sat Feb 10, 2018 19:16
by Шалтай Балтай
this "classic" 144, 177 and 188
144 - F3
177, 188 - F2.5
Posted: Sat Feb 10, 2018 19:17
by Шалтай Балтай
This seam 177, under a magnifying glass
Posted: Sun Feb 11, 2018 16:53
by Александр Н.
Hello, Humpty!
If not a secret, tell me where you take the wire with such diameters. Those wires are sold in elektrotovary, categorized by section. The diameter of the wire of the same cross section according to GOST and TU can vary greatly.
the cross section of the cable diameter table:
https://yandex.ru/images/search?text=%D ... source=wiz
Maximum cross section that I could find is a 16 - wire diameter of slightly more than 4mm. to Weld such thick rings turned out and want to try bigger diameters. Where you take the wire for example with a diameter of 5mm? Tell me, if not a secret, thanks in advance.
Posted: Sun Feb 11, 2018 17:53
by Шалтай Балтай
Alexander N.
that thicker F4 - it is called the rod:
https://nova.rambler.ru/search?query=%D ... dGVzdDs7Ow
that before choosing a particular vendor, this is determined by Your appetite :)
the wire comes in coils of 5kg. the rod piece. it can you chop length.
PS
Do not look for a cable, the Key words here are: Copper, wire, rod buy <your city>
Hope I helped. :?
Good luck
