Page 25 of 27
Re: The Ring. Workshop
Posted: Sun Feb 18, 2018 11:22
by Шалтай Балтай
Oh, Chago I did:
Harvest on Kuvak 144й Measurements 3.5 Size of Three-core Twisted
Posted: Sun Feb 18, 2018 11:23
by Шалтай Балтай
and it's 177, a half of Measurements
Posted: Sun Feb 18, 2018 11:24
by Шалтай Балтай
These products "will happen", Three-wire pigtail is a very capricious material:
Posted: Sun Feb 18, 2018 11:25
by Шалтай Балтай
To the pigtail of sufficient length the issue of overlap:
Posted: Sun Feb 18, 2018 11:27
by Шалтай Балтай
This time there are blanks for two kuvake. Someone else will carry (I wanted to say in this life
Shamanic tools
Posted: Sun Feb 18, 2018 13:06
by Александр Н.
I do so:
Drill (I have a punch more powerful) is rigidly and firmly fixed (grip, stand, Desk-clamp, etc. options). The Chuck clamped a hook-and-loop. To the opposite wall zakreplena three wire end. Each core first, try to straighten as much as possible. Then strongly pull it and attach(coil end) to the hook. And so each, so no sagging and Mercosul. If one fiber is stretched and SAG, you get torsion as per your photos.
When braid "started" exactly and went to shrink long, take a hammer and pull handles
Posted: Sun Feb 18, 2018 20:25
by Шалтай Балтай
Александр Н. wrote:I do so:
Effectively the same, but there is one detail.
Before the twisting of the harness, Every wire I twisted with a drill that would straighten. The same technique is used for kuvakov. This allows you to accurately measure the size of the Measurements for the Nodes.
This, incidentally, gives an additional aspect of products. I call it λП (lambda-P)
This significantly reduced the number of Perekrestov, but I could not fully get rid of them, but I think over time poreshat this problem. At the moment the risk looks acceptable.
Posted: Sun Feb 18, 2018 20:26
by Шалтай Балтай
Александр Н. wrote:take a hammer and pull handles
but it is respect!
Posted: Sun Feb 18, 2018 23:38
by Александр Н.
Can't understand how it is possible to twist I right?)
Today I tried to roll 7 conductor cross-sections 2,5-GOST. From 6m harness out high-quality period of only 1.5 m.) Probably have the copper core to podrazumevati on a strong spring ( like the old doors instead of door closers hung), so the other 6 around it(Central cores) encircles. Other options I don't have yet)
Posted: Sun Feb 18, 2018 23:52
by Шалтай Балтай
Александр Н. wrote:Can't understand how it is possible to twist I right?)
What's the problem? Just take the wire and twist her grelu it rectified.
Александр Н. wrote:Today I tried to roll 7 conductor cross-sections 2,5-GOST
Ah! You have a thin wire! 2.5 Section, I work 4.5 mm2, it's F2.5, it is not as soft, and therefore overlap more with F1.5 - it is easier, of course.
respect!
nice to speak on the case.
and then it got exotericism
already direct 9ые chakras open, but in fact the right with the left confused.
Mahatma Is A Genius. The wheel can't prate goodbye
Posted: Mon Feb 19, 2018 0:18
by Александр Н.
Just to spin along the axis of the wire??
Of slim just tried to twist 7-wire harness. And so, all products are slim from the wire diameter is less than 3mm I don't feel (as I already mentioned here), but who gave thinner, well speak about them. Use section 10 and 16. Although the cords of Merovingia I did wire f of 0.1-0.2 and I and all who gave from their felt) But that's not the topic))
Posted: Mon Feb 19, 2018 11:12
by Александр Н.
Welded 7-wire akavak. How does the photo to attach, I can't understand))
Posted: Mon Feb 19, 2018 12:51
by Шалтай Балтай
Александр Н. wrote:Just to spin along the axis of the wire??
yeah
Александр Н. wrote:Of slim just tried to twist 7-wire harness.
approx. Respekt
Posted: Fri Feb 23, 2018 17:15
by Шалтай Балтай
Cheh, I did it:
by Шалтай Балтай
Posted: Sat Feb 24, 2018 16:48
by Шалтай Балтай
Blanks for pendants, Н210, Н211, Н212
Posted: Mon Feb 26, 2018 23:15
by Александр Н.
Continue to experiment with wire cross section of 2.5 yet thicker))
144 and 177, size 1, 3X3, burning of the three for the three wires)
Posted: Tue Feb 27, 2018 15:18
by Шалтай Балтай
Alexander N.
Great twist, the seam is not very visible
Respect!
Posted: Tue Feb 27, 2018 22:31
by Шалтай Балтай
For those who are already familiar with the vibration 144й Measurements (solid pleasure, right?
) I want to draw attention to the Ring three Hundredth Series, 188й Measurements:
Posted: Tue Feb 27, 2018 22:34
by Шалтай Балтай
Three hundred Series means a Three wire Pigtail, more info here:
viewtopic.php?f=60&t=6181
Each lived Pigtails were twisted, ie is it a Three wire Lambda Pigtail
The data Ring that the photo - 188й Measurements of the First dimension (primary), is to understand the scale of the product.
Posted: Tue Feb 27, 2018 22:37
by Шалтай Балтай
I believe that Those Who take up products 188й (and 177й) Measurements has at least half a year experience of getting pleasure from the product 144й Measurements
chicag,
Posted: Tue Feb 27, 2018 22:40
by Шалтай Балтай
Rings, three Hundredth Series, should be available after the March holidays.
Posted: Thu Mar 08, 2018 19:07
by Шалтай Балтай
Oh, Chago naval...
Zagotovki under Kuwaki, Pigtail F3, Top-Down 144, 177, 188ая Measurements ACC. 3.5 Size
Posted: Thu Mar 08, 2018 19:09
by Шалтай Балтай
The approximate Weight of a Node 144й Measurements - 265g, Node 188й Measurements - 400g.
Impressive Products.
Posted: Fri Mar 09, 2018 23:44
by Шалтай Балтай
Welded Pendants, Top to bottom: 188, 177, 144 Measurements ACC.
