Ring. Activation sound
- Шалтай Балтай
- Разработчик
- Шалтай Балтай
- Разработчик
Re: Activation of the Rings sound
apparently, there are raznitza
Yes, Humpty, I guess You're Right.. in all the photos, especially closer to the right edge of a field flooded with a Golden-green (light), and do kubacki look different.. some especially gold or something..so to speak..more saturated look.. there's something else, but I'm not sure whether this is a manifestation of color, whether it shines so ... so white and fluffy light on the products, on a stick, on a stand..just the light is stationary and cannot understand what it is.. other colours are usually live like, and the like frozen..
- Шалтай Балтай
- Разработчик
Malika Thank you for your review!
It makes sense. The product high hardness, therefore the quality factor. This implies that the energy density is higher. Therefore, the aura is wider.
One thing farver, the other - the cumulative shell
Again, thank you, Malik.
Малика wrote:some particularly Golden or something..so to speak..more saturated look..
IMHO:Малика wrote:just the light stationary and can not understand what it is.. other colours are usually live like, and the like frozen..
Humpty, if possible, next time maybe try bronzes and even on a light background to see..I wonder how it would look..
another interesting "striped" or "checkered" background
- Шалтай Балтай
- Разработчик
and f Cvetochek?
just kidding, che thread out....
in flower, the main repeating pattern, and more or less contrasting )
Mariana Alves Soprano - Au-U Ur-Se-Ur Au-U / El Ka Leem Om
https://www.youtube.com/watch?v=Z67iQPB ... e=youtu.be
There is an ancient technique put fingers to temples with his eyes closed drawl pronounced su at . )) that is put on the output.
- Шалтай Балтай
- Разработчик
bumble bee pranayam
- Шалтай Балтай
- Разработчик
Re: The Ring. Activation sound
[youtube]http://www.youtube.com/watch?v=4WcRWAd-2Y4[/youtube]
a small correction
the session is not floor-Hz and Hz modulated
it does not matter
a small correction
it does not matter
Good day, Humpty!
Interesting session.. tight cool energy wrapped around and caused a feeling of peace, tranquility...listened three times the effect repeats. The aftertaste of listening: a slight rumble in the chest and shoulder blades, wanted to sleep.
Thanks))) Glad you didn't forget about us)))
- Шалтай Балтай
- Разработчик
Good zdraveska, MalikМалика wrote:Good day, Humpty!
Thank you for your review. Always read with interest!
In this device uses the natural oscillations/vibration of the node. The principle of a bell. It certainly is softer in comparison with forced oscillation vibrodynamic.
For each task - the tool.
PS
From the film "to Old men here not a place" (orig: No country for old man)
"Under each job needs one, but well done tool" (C) - accurate!
Mechanism noise generator - https://mynoise.net/
