Ring. Right, Left Spin
Post Reply
User avatar
Re: TECHNOLOGY SLIM SPARLING
Post by Шалтай Балтай » Sun May 15, 2016 5:53
!!!!PERSONAL IMHO!!!!!
Right and left Spin
preamble
Both twist — work, both a positive effect, but there is a difference
Terms
Right spin clockwise during
The left one counter - clockwise (so all devices are made of slim)
the Difference
The most sensible explanation of Dancing With Water
Conclusion
The right spin (clockwise in the course of braids) — removes negativity
Left Spin (counterclockwise in the course of braids, how made ALL the devices Sliema) gives a positive
Thinking out loud
I'd say that slim knew that, but feeling responsible for the invention made all the rings left spin. In combination, if misused, can and navredit. Use only the left back looks a more secure solution.
User avatar
Post by Шалтай Балтай » Tue May 24, 2016 10:41
!!! PERSONAL IMHO !!!
start here: viewtopic.php?p=153737#p153737
I must admit the chain of reasoning, only calculations
Terms
Negative, Positive
"THere is nothgin either good or bad but only thinking makes it so"(c) WS
There is neither bad nor good, just something that we think makes it one
Right-left; Sun-Moon; Day-Night; Male-Female
Where the bad guys are, where's the good?
the Right spin clockwise, the Moon, the Feminine TAKES the Negative
Left Spin counter - Clockwise, the Sun, the Male principle - GIVES a Positive
The negative and Positive, are also relative concepts. There are only Vibrations, Light.
With lensesthe same thing, One side Takes the Negative, the Other side GIVES Positive
Therefore, the treatment is better to start with the right back - removes negativity
BUT
This will create a vacuum, so it is necessary to use a Left Spin after that. This will give the Light a Positive.
I think slim knew it, and made a choice
But
The use from Left Back, can cause (and often is) the reaction of opposition from the "dark", "heavy" vibrations.
This is a very fine moments.
If you're not sure, use the left spin. If you feel that you can play with right and left spin turn.
Perhaps it makes sense to say that day is better left spin, the Sun, masculinity, and at night - right, Feminine. But it is necessary to test everything.<
User avatar
Пчела
Re: Right, Left Spin
Post by Пчела » Thu May 26, 2016 2:57
Шалтай Балтай wrote:If you're not sure, use the left spin. If you feel that you can play with right and left spin turn.
Ring with the right spin, are manufactured to the same dimensions as the left spin?
User avatar
Post by Шалтай Балтай » Thu May 26, 2016 9:54
Yes
User avatar
Post by Шалтай Балтай » Tue Jun 14, 2016 0:06
there is one friend of the young lady threw the idea right, left back
Nitsche not like?
BU said that the man to invent anything basically can not
what you need to do is collect a single pattern of the plurality of slivers
discover the simple, long-forgotten, or maybe just to remember ...
Gee, Humpty - poet :)
Post Reply
