MULTIPHASE CORRELATORS SERIES "PCI-E"
Posted: Tue Nov 15, 2016 21:01
Backstory opening.
Attempts of human exposure to electromagnetic radiation to produce an unusual and rare psychic abilities are taken for a long time and in many countries. On the Internet there are many references about the use of SHF and EHF radiation. The lack of widely available publications on this topic have generated a lot of myths, legends and horror stories: about psychotronic weapons, remote control zombie, slumber, turning people into super-soldiers, etc.
At the same time, the available data indicate that there is statistically significant evidence that SHF and EHF radiation can contribute to learning skills and techniques of lucid dreaming to change the dreams of people, to make those dreams more vivid, realistic, and faster entry into a meditative state and border States of the psyche, to achieve the accelerated development of psychic abilities and the ability to operate a stream of events, with the aim of imparting the specified vector.
In 2006-2007. in the process of working on a number of research projects in the field of electronics, there are several ranges of EMI frequencies which when integrated and simultaneous human exposure to give an unusual but well-repeatable effects that can be successfully used to treat a range of diseases and pathological conditions, as well as for the qualitative improvement and development of people available psychic and magical abilities.
On the basis of the detected effects of 2006, was developed almost 50 modifications of the devices that have been successfully tested by researchers around the world.
This series of devices has received the name of PSI-E.
How the devices in the PSI-E?
There are many different methods and devices generating electromagnetic radiation in the range of microwave and EHF from spark generators to generators on the basis of transistors of various types, electron tubes, gas discharge devices, impact avalanche transit-time and tunnel diodes, Gunn diodes, crystals pyroelectrical etc.
Regardless of the generation method of EHF extremely strongly absorbed by the surface layer of human skin with a thickness of only 0.01 to 0.1 mm. Therefore, as a rule, in medicine, the use of the devices of the millimeter waves is mainly limited to irradiation BAT (biologically active points). In fact, EHF-therapy has become the modern version of the Chinese acupuncture. Irradiation AMY NOR EHF (electromagnetic radiation of EHF low intensity) the entire surface of the human body ("squares") – it is considered virtually useless and ineffective.
However, the research was able to detect multiple combinations of frequencies in the field of microwave and EHF, the radiation of which can abnormally deeply into the tissue of the human body, including internal organs, brain, affect several body systems, including power structures and formations of the BAT class, meridians and chakras. In fact, we are talking about the same kind of effect Hutchison, but for very high frequencies and tissues of a living organism. What was the most enjoyable and interesting in the manifestation of this effect is the fact that it is easily repeatable at different power AMY from a few milliwatts to a few watts.
There is a real opportunity to influence deep, ancient brain structures of human electromagnetic radiation with a wavelength that is commensurate with the size of these structures. Naturally, with the amendment and taking into account the dielectric constant of the medium in which they are located.
Peculiarities of generation of microwave and EHF, generators and a series of PSI-E are such that the signals are generated with a set of phase shifts, the number of which reaches several million. But they are not just correlated, but have a functional link that allows the device to exert influence not only on the visible objects of the 3D world (reality), but their invisible (or visible only to the initiated) symptoms and parts that are in Higher Dimensions.
It should be noted that the device is used not just generators, but the generators are working simultaneously as receivers of signals that are generated by the human body, its energy centers, brain, consciousness and their manifestations, which are in the Higher, invisible (or undeveloped) in our Reality dimensions. The principle of operation of generators as receivers is not new, rather has long been known and is widely used in the so-called autodyne contactless fuses aircraft missiles, microwave motion sensors, etc., However, used in the devices PSI-E the principle of operation of such generators/receivers is fundamentally different from the known fact that the generators operate simultaneously and at different frequencies, while not creating mutual interference and false signals. In combination with the original information processing system, using digital filters, math and such used in the experiments of the Princeton laboratory for applied research of anomalous phenomena (PEAR) and the principle of "rabbits Maharishi", managed to implement a rather unusual system of biofeedback (biofeedback) devices PSI-E with a human operator. In fact, we are talking about the fact that there is a direct connection with the consciousness of the human operator. Moreover, this device is completely wireless, non-contact, parametrically adapted and adaptive changes under the influence of consciousness.<
