Meditation
Posted: Fri Mar 09, 2018 11:51
Hello, we offer meditation, it is not only the practical training of the senses, but also a strong practice of concentration. Designed to expand the possibilities of our perception. I would be glad if you share your opinion about its effectiveness and emerging experience. This meditation is the principle of universality, and does not require any special approaches or efforts. Originally it was intended for the study of new and expanding existing opportunities. Everything is described - it is nothing more than the simulator for the attention, generated all the images and sensations aimed only at increasing attention and increasing diversity of experience, as well as to increase the sensitivity of the body to energy processes(development of a high degree of sensitivity).
Better start to briefly describe the basic steps, and then write out the meaning that invest in it.
LEVEL 1.
1) Close your eyes, calm down, relax.
2) Focus on the surface of the head (or other body part), make it a bulk surface. You began to feel in the uncertain space. Nothing but those sensations.
3) Imagine a circle. This visual representation of your condition (both physical and mental). Remember this state (hereinafter called PP). It will be the benchmark that you will keep and be able to reproduce constantly.
4) You feel your body like a balloon (there are "borders" between you and the outside world). The globe is shrinking, at the same time you feel physical changes in the body. But "contraction" you can feel the permanence of the PP, and all changes are applied to the sense of PP. This will cause increased experiencing of sensations, and they will seek "discharge", but we try to keep them as long as possible. When "narrowing" do you feel that the PP becomes better, brighter, faster, livelier and this reflects positively on your body.
5) Further narrows (compacted) and PP, and obtained in paragraph 4. Endlessly.
6) If you can't condense, then expand the most dense PP in the centre, retaining its density and increasing coverage. Again and again (like item 5) until you reach the "border" (see paragraph 4).
7) Produce the seal (see item 5) and extension (see item 6) at the same time.
8) Due to a collision of layers (see paragraph 7) produces a field around PP. PP the radiant rays, make a loop and return to the PP by grabbing from the void (of space) something important. Feel the improvement in PP.
LEVEL 2.
1) PP is divided into several paragraphs.
2) are Formed of interconnected chain PP.
3) Energy of all PP enriches (enriches) surrounding the void.
4) Everything moves in a spiral, becoming more energetic, samodostatochna, eternal.
Etc.
_______________________________________________________
MEANING:
LEVEL 1.
1) Relaxation allows to get rid of concentration on the surrounding world and more uniformly perceive all experience physical sensations.
Same with vision and mental state (thoughts, etc.).
2) If you have trouble, do the following. Can touch the scalp and run your hand over the skin. Then reproduce similar feelings only through attention (without arms). Each "wave" sensations under the skin. Do a "wave" throughout the body (inside and outside). It is like the flow of air. Continue to automatism. Gradually these feelings will merge with your skin, penetrating deeper, becoming denser, brighter, more elusive. Therefore, improve them and maintain regularity (harmony). Until then, until it will become impossible to distinguish (separate) the feeling from each other, everything became homogeneous. And is perceived as "voltage" (power energy).
3) do Not have to see the circle in front of him, it is enough to assume that it exists and describes your current state.
Need to remember this state in order to have an endless source of sensations. Because all this is happening in your inner world, so you can imagine all you want.
4-7) If you can't find the "border", create it (collect all the sensations in one area, point, ball).
It is advisable that you imagined three-dimensional shape.
You bind your physical condition and the visual effects. Therefore, if you change images you have to change internal feelings that are typical gone. Compression = pressure, tension, compression of muscles; extension = freedom, ease, increase of perception.
8) Describes a system similar to the magnetic field (this is just a comparison). This seems like a lot of cold shivers on the skin, causing itchy and butterflies in the stomach.
Not necessary that all this was seen and perceived visually, the main thing - at least to assume that all works well.
LEVEL 2.
1-2) ideally, you need to perceive yourself as 2-4-8 etc. the same space as on level 1. To be in several places at the same time. This does not mean that you have to be two separate personalities. It's just a way to increase the available information, the perceived simultaneously. No matter how you do it. Choose what you think is right (typical for this action).
Although some PP will not even have common ground, but they will all be in your attention and will be forever linked to each other through you.. They are just a figment of your attention and imagination.
3) surrounding the void is perceived as something external, almost uncontrolled, is used to divide the available parts. (SPOILER: next will be all the one).
4) If there will be a movement, you will receive information about the movement and vzaimoosmotry. This will make it easier to keep the heterogeneity of the sensations and allow you to continue the movement of the system while consuming less of your forces, as the movement will become more familiar to you than the rest (with prolonged practice of this paragraph).<
LEVEL 1.
LEVEL 2.
Etc.
MEANING:
LEVEL 1.
LEVEL 2.
