Re: the Magic of biochemistry or biochemistry magic
Posted: Wed Oct 25, 2017 19:49
by ЛИЛИЯ-Р
сол wrote:It doesn't matter whom to ask. You always. In all cases. Without any options, ask only yourself and your subconscious, which is the driver to the philosophical "I".
It is important( my opinion) to ask your subconscious or someone , that is where the attention goes , the energy(not invented by me). Hence the difference is huge. Asked several specialists in this , trust them. Our opinions coincided.
сол wrote:And conversion to DNA, it is a very deep subconscious, if you do this in the boundary condition - maybe something interesting to be...
This is done in some methods the hypnosis .....LingvoGrammar -effect on DNA including.
сол wrote: But, agree, it's silly to ask for deoxyribonucleic acid, the psyche is not interested, she needs emotional shape.
WHO DECIDED that the subconscious mind separate from the body , if they are primarily fills DNA ?
Another important phenomenon of the human DNA - so-called junk DNA, hidden and inactive add-on to our base code. This is a smart, self-organizing, developing and correcting the program with a built-in relationship with the infinite energy and wisdom of the universe.
The active part of DNA that store generic programs, providing birth, is only 3-5%, while the rest is inactive. Here, of 97% and kept all the so-called superpowers, man.
What is meant by the term "superpowers":
a high level of awareness
vysokochastotnom vibration characteristics - the absence of fear, irritation, self-pity, apathy, depression, guilt and other depressing feelings
the adoption
undivided into good and evil
the vision of the situation from the position of past - present - future, i.e. the time of the birth situation, the time of implementation and its consequences in the future
intuition
vision own way and adjustment of
awareness of choice and destiny
unconditional love
the ability of cell regeneration, rejuvenation and healing
high adaptation to different radiation
the awakening or strengthening of creative abilities
inner freedom, independence from public opinion, the exemption from the need to follow established social cliches
increase personal power
Express plans and desires
a meaningful and purposeful life
Activating your junk part of the DNA of the individual reveals these and many other possibilities, freed from the family system loads, gets the choice.<
Posted: Wed Oct 25, 2017 19:51
by ЛИЛИЯ-Р
"Human DNA is About 8 percent of our DNA is composed of ancient viruses that once infected people. "
and it has research and ....under hypnosis including . As all the threads begin to merge into one.
Posted: Wed Oct 25, 2017 20:01
by сол
Important( my opinion) to ask your subconscious or someone , that is where the attention goes , the energy(not invented by me). Hence the difference is huge. Asked several specialists in this , trust them. Our opinions coincided.
The fact is that given the importance - it is the program. Attach importance to the word, and you made them yourself, good and bad. And a good start to fight inside of you with the bad. Attach importance to the artifact - and then there are good artifacts and bad artifacts with parasitic programs, and everything inside you. Attach importance to the hypnosis and you become hypnotizability, whatever you fear or want to master.
Any attach importance to is a prerequisite for creating beliefs. Persuasion is a block within you that separates you into two parts. This does not mean that you need to be a mindless vegetable without any opinion or belief... on the Contrary... they Just should not be static, they need to flow, to change, to transform. Fire, water and air static unknown, and knowing only the ground three meters deep... But the flow must not chaotic, and around the inner rod connection of the mind and subconscious. It flows the same, but remaining unchanged. Structure.
Little sense to cut yourself on, is taken into account for the hundreds of axes (hundreds of beliefs). You just get the collapse itself, and the internal dispute yourself with him... In that time, as all you need to do back - to produce a synthesis of all, to put all this together to form a single axis, but do not share, and connector polarity. Need to completely remove every fear. Where scary - there's your problem. Until you realize, until you decide, until you realize that you just made up fear on their own - this problem will not go away, as will not leave the internal contradictions, internal dispute and will the lack of integrity in itself is not going anywhere... So... feel free to go there, to your biggest fear for him and hidden the gold of the soul. And you'll never find him, until the fear dissolved.
Try allow yourself a different point of view. Albeit it will unlikely stand on your belief, but try for once to imagine what could be polar opposites to your belief. There will be a current, for belief transformation.
And without that... Without the fluidity and plasticity of consciousness, a person just biology... Mold the outer world in the form of neural networks Which... just remembered that someone said there, like a gramophone record.<
Posted: Fri Oct 27, 2017 23:00
by Слайдер
On most of these mages:
The strongest thing for a few minutes allowing you to feel inside the real magic of biochemistry and to understand what it is.
Posted: Fri Oct 27, 2017 23:56
by сол
Something like that... and walk on water )))
Posted: Sat Oct 28, 2017 23:29
by вотан
flow....nothing sticking.perception...changing the thinking...and slowly brings the mind and consciousness from the power of darkness.that and the opinions in the posts are pretty easy to see where, who and what.
Posted: Sat Oct 28, 2017 23:45
by сол
flow....
by the way, an interesting word to apply to the water, and to the current time, and even in psychology there is the notion of brain plasticity ))) In any dimension and layers...
Posted: Sun Oct 29, 2017 12:56
by вотан
earth also flows...moves..changes.Toko more slowly.she and all her hardness...lachey interpretation is not the plasticity of the brain...not the fluidity of consciousness
Posted: Sun Oct 29, 2017 21:48
by сол
very good author...
Posted: Sat Nov 04, 2017 22:27
by Логия
сол wrote:And male quality is a mindset, which you are not. When there is neither the one nor the other - emptiness inside to fill up non-stop, never stopping to accidentally suddenly see that there are actually inner emptiness...
which you have not....what was projected-and wrinkle yourself))))
Posted: Wed Nov 15, 2017 1:51
by Кона
Have a question about one practice (description below), if anyone has experienced similar, please share, how do you explain it.
In the book Borislava Cervista "the Magic of immortality. The book of secrets" in section 3.2.1. describes the following practices:
"... changes bring us closer to understanding the illusory nature of the objective world. But it is necessary to take the next step — to see the edge of what is behind it.
The secret is to change the object of perception. In the normal state, we perceive the sky as the background, and clouds as objects of observation. You just have to swap them. This is easiest to do when the sky is filled with lots of small clouds forming a kind of honeycomb structure.
Carefully looked at areas of clear sky, a smooth transition from one to the other, and then, raspolozivim sight just behold that part of the sky that fits in your field of vision.
If it doesn't result the first time, repeat again and again until, until suddenly the sky changed completely. In it there will be nothing familiar, it feels like it's the alien sky alien planet. At first it will be only a fleeting perception, then the picture will change rapidly, "flicker", but in the end, "alien sky" will be the only and frighteningly real.
This experience gives the impression is so strong and so powerful energy that even a single successful attempt may be enough. Something in depth you will understand or rather remember the multiplicity of reality..."
I have this periodically obtained. Experience strong, you don't forget.
But this "another" the sky is still something: when the concentration of opinion on any point of any clouds, this point begins to pulsate and glow, changing brightness depending on the pulsation. Carry the look to another part of the alien sky and holding him there some time later at another point begins the same ripple of light yellow light.
The sun is nothing, it generally can be in the clouds or in another part of the sky, outside the field of view.
It's all fiction - apart from the fact that looking at something strange and somewhat inhuman, alien begins to speak. On my scale it's not a glitch, because the experience is played repeatedly.
Silvestre explanation and model about this: we, the people, sleep all my life and immersed in a kind of illusion, made by the PARASITE, carefully hiding from us the real situation: who we are (very powerful in their potency), and what enormous power available to us (for those who can get out of the illusion).
To me this explanation satisfied - looked into the abyss, the spirit captured well, great!
Now, after diving into the topic of "the biochemistry of magic..." thought that everything could be much simpler:
these phenomena are interpreted by your brain as someone else's sky and flare in it, may arise from specific brain States, which in this period produces internal chemicals, whose effects on the brain is shown in this way.
I would like to hear from practitioners who are faced with this.<
Posted: Wed Nov 15, 2017 2:13
by сол
these flicker and unusual point - are called "phosphenes". It switches to the reptilian brain (the subcortex, brain stem). If you train the phosphenes, then, the idea is that eventually the humor of the situation and will be able to switch to another method of vision, to look through the subconscious. The phosphene appears normally if viewed from the depths of the brain in its center, slightly closer to the neck.
The difficulty here is that when it appears - immediately surprised, and all is lost. Theoretically, from this point unfolding then "screen" over the picture from the eye - that is, the TV in our head, which we all see, actually... But I Wake up never worked. But it was in a dream several times, so this really is the type of desktop Windows, which can be anything interesting to see )))
Overall, it's just switching to another mode of operation of the brain. Some part of our brain always sees reality. The one that around, the other does not. Just it can be taken so many ways.
But the reptilian brain is called because this part of the bulb of the brain was laid during the reign of reptiles. So they've seen everything, and probably see now. And it has nothing to do with "reptilians", which does not exist ))
Silvestra explanation and model about this: we, the people, sleep all my life and immersed in a kind of illusion, made by the PARASITE, carefully hiding from us the real situation: who we are
but such thoughts - this is a parasite ))) Because the most important parasite is the man, and other no )) And when one begins to deal with pests all sorts of ways... he Is struggling with itself, but I can not admit because to admit it...
Posted: Wed Nov 15, 2017 14:24
by ЛИЛИЯ-Р
con
Кона wrote:at a concentration of opinion on any point of any clouds, this point begins to pulsate and glow, changing brightness depending on the pulsation.
At a concentration not only on the cloud, and on any subject , the point at long observation it generally disappears from view)). Another trick is. You can for example on the picture in the box and preferably of different colors and different sizes . Look raspolozivim look first on the field-the background disappears from all fields)). Look at one of the cells , it rises to the fore , as if pripodnimaet, as in holography to the fore, the rest stays in place .So the levels can be expanded all very interesting work, what kind of cell see on the first level and so on. Can be joined at different angles.
Posted: Wed Nov 15, 2017 19:24
by ЛИЛИЯ-Р
Кона wrote: In it there will be nothing familiar, it feels like it's the alien sky alien planet. At first it will be only a fleeting perception, then the picture will change rapidly, "flicker", but in the end, "alien sky" will be the only and frighteningly real.
Posted: Thu Nov 16, 2017 22:55
by Хорошо
Кона wrote:I Have this periodically obtained. Experience strong, you don't forget.
view this, not as "look" and like the attention
Posted: Thu Nov 16, 2017 23:44
by сол
What is the awakening?
=Happiness, which is counting on the misfortune that fear is the anticipation of non-existent. Of these anxieties and hopes woven all the familiar personal life in the mental matrix where the mind flees from the Ghost of failures to success. If only until old age to hope for the best.This is called unawareness.
=When you realize that hope with the hopeless inseparable, then, and fed up with drama. And attachment are released in a natural way. Begin to see that seriously you can only rely on the unknown.
In thinking there is no real supports. The thought has not kept pace with life. There is only this moment. The rest is a dream. And it will end. Awareness of the precariousness of all "possessions" takes you through the stress of loss. The recognition of a loss opens the lightness of being.
=Money, things, society in these features, no problem. The problem occurs when the opportunities become attached, believe in their guaranteed rights to a specific future.
=When talking about the illusory nature of hope, many believe that all generally makes sense. Including active movement through life; I would say that pointless emotional expectations for specific scenarios. And if you feel the senselessness of motion, no consciousness can not see — only apathy and despondency.
= Real awareness comes from the energy of the live motion. Then in practice we see how shaky all the achievements and attainments. And yet they delight like a rainbow, suddenly arose in the sky — it is not, and enthusiastically greeted her, letting go. To let new...
Then less get the idea, if true something is wrong. It does not lead to passivity. Still improve, alter and trample. But without the despair and lingering hope for the best.
I. Satorin (which I only saw today, but 100% of similar articles, where a glimpse of ran) http://progressman.ru/
Posted: Tue Dec 19, 2017 21:56
by Слайдер
Shadow rules the world:
Posted: Wed Dec 20, 2017 0:06
by Мела
Too gloomy of course, but!
I guess they want it to be so
Quite Chernushka
That way, there are more options
That's it
Posted: Wed Jan 17, 2018 15:41
by Мела
The simple truth
Posted: Thu Feb 08, 2018 14:49
by Слайдер
Hacking the brain:
Posted: Sat Feb 10, 2018 19:51
by Aura
Cool paranoid-ekzestentsialno science fiction)
Posted: Wed Feb 14, 2018 14:31
by Гуфест
Slider,thanks for the movie,tell you personally managed to find the geometry to see God.Or where to find this geometry?
The magic of biochemistry or biochemistry magic
Posted: Wed Feb 27, 2019 11:33
by Андрей Аксайский
The old-timers tell me, pliz, what resources now is the Creator of the topic "in passing"(Igor)? Thank you
Posted: Sat Mar 23, 2019 22:28
by Создатель
Hello people! here you have only so many cleverly written and I tried to ask on the forum of rejuvenation but there's a campaign I stalling me son you recorded said to ask here are as crazy as you can tell . I do eye revival it's great all the good stuff but I a month ago started to run down my spine like a chill and very very very nice .a strange tingling as if the ball bursts tingling in the knee and they run away from there in the shoulder that is generally in the throat! in short the most unexpected places in a body of steel springs and needles as if to draw attention to them then they turn into a wave, ie for example the brush elbow chest head Yes in principle though where you can run Volano and in any direction.Yes, and the wave of tingling very nice level buzz of svoeobrazno .Tell me that and then I feel abnormal, must drink understand Smoking and understand to catch a buzz from creeps like him, perverted or not?
