Line shielding clothing and furnishings EMF ARMOR™
Posted: Mon Jul 20, 2015 15:31
Line of clothing, accessories and products for the home ARMOR EMFshielding from electromagnetic radiation (EMR).
https://mindmachine.ru/catalog/shop/cat ... evice/emf/
Nowadays almost every person, including children, virtually around the clock located in the area of mobile phones, spends a lot of time at the computer, surrounded by many appliances – microwave oven, TV, fridge and even a hair dryer are sources of EMI.
We do not see or feel the radiation, and even used to the constant presence of different emitters so that it is perceived as the norm. It has long been known and proven that AMY, penetrating into the human body, can affect the functionality of the brain and other internal organs, cardiovascular system and even skeletal system. For example, it was observed that the deterioration of health usually occurs in “rush hours” of conversations on mobile phones, when the maximum capacity of the work cell towers, and removal from areas of maximum density of the EMI (for example, outdoors, in the woods, in the mountains) is associated with relaxation and rest.
Many people are having the opportunity to work on the free schedule the best efficiency and concentration at night and early in the morning, when the number of emitters and their activity is minimal. It is an individual observation that may feel almost every. Accurate research data on the influence of different AMY on the functionality of the systems of human body here we do not give, if desired, they can be easily found on the Internet.
But there is another aspect of EMR, which is not so widely covered. The human nervous system is designed to transmit electrical signals from the brain to the periphery of the body and Vice versa and in fact is a powerful antenna that perceives the external electromagnetic oscillations. As a result, AMY is able to influence the activity of the brain and nervous system in General, in particular, on the entire mental, mental, and emotional activities of man. A lot of people experience the inability to effectively manage thought processes or manage their emotional state (as well as various biological rhythms that are directly related to the electrical functioning of the nervous system) is not due to low skills of control and self-regulation, but rather because the electrical activity of their nervous system is exposed to constant, strong and chaotic influence of external AMY.
It is known that in the Soviet era began to develop psychotronic weapons, based on electromagnetic radiation. Science has long been known that electromagnetic radiation of a certain frequency, resonating with the spinal cord can cause electrical surge in the brain of a particular desired frequency. And we can only guess at what level these developments around the world are now. In today's reality, the totality of AMY's daily affecting every person, not just potentially dangerous, a real threat: we live in an artificially created wave medium, the radiation power which is several thousand times higher than natural.
Just recently, in early 2015, in connection with the development of mobile Internet, cellular companies in Metropolitan areas began to actively place a cell tower in the area of residential areas, in areas with high density – almost every 15-20 m. they can observe the inhabitants in any district.
Now, virtually all use water filters or buy bottled water, choose environmentally friendly products, but perhaps even more important to protect yourself and your family from the effects of EMP.
Series of shielding clothing and accessories ARMOR EMF produced using metallic screening material and is designed to significantly reduce (several 1000 times in power) the influence of external AMY. These fabrics are novelty in everyday life, but for a long time have proven themselves in industrial environments with increased radiation.
Shielding metallized fabric composed of fibers of cotton (fabric ECOTEX)/spandex (knitted fabric MSILVER)/polyester (fabric VSILVER indoor), entwined with a very fine metallic wire containing silver that in addition to the protective effect gives products and anti-bacterial effect.
EMS clothing ARMOR is not only a passive protection against the adverse effects of EMI, but the device significantly help on the path of self-development. For example, the use of shielding headgear, becomes noticeable almost immediately (within a few tens of minutes) - it helps to reduce the activity of the internal dialogue, initiated by external AMY, achieving meditative States, allowing you to relax from the chaotic neural activity, concentration of intellectual activities, to manage their emotional States, as well as allows you to effectively get rid of the so-called stress.
For people interested in self-development, conditions caused by decrease in the intensity of EMR, can be a starting point to search for the desired, for example, lucid dreaming or various altered States of consciousness used for deep diving in themselves (including a meditative state).
It is important in the description of the clothing line EMF ARMOR will be noted that in contrast to the known prototype – cap of aluminum foil is a special metallic fabric that provides protection in clothing EMF ARMOR, not shields electromagnetic radiation completely, but significantly (several 1000 times in power) reduces the level in the range of major adverse household electromagnetic radiation, which include:
radiation from mobile phones (300 MHz — 3 GHz, in Russia — 900-1800 MHz)
radiation microwave ovens (2.45 GHZ)
radiation of the computer (system unit — 50 MHz — 1GHz)
radiation wi-fi routers (900 MHz — 5 GHz)
— other.
It is known that there are favorable electromagnetic fields, including the natural field of the Earth (10 Hz), full long the shielding which would be unfavorable for humans.
All fabrics do not require grounding, so without any problems can be used in clothing and accessories.
Evaluation of radio-physical characteristics was carried out in the Institute of Medicine of Labour of Academy of medical Sciences and testing laboratory of the Ministry of Defence of the Russian Federation . The fabric has a health certificate.<
— other.
