Line shielding clothing and furnishings EMF ARMOR™
Reliable protection from the negative effects of electromagnetic fields
ЮрийСт
Been thanked: 1 time
Re: Line shielding clothing and furnishings EMF ARMO
Post by ЮрийСт » Fri Feb 23, 2018 19:57
the Sheet still seems to have that the signal is not "passed"(bottom, not picked up)
Bed sheet with grounding, and it's a difficult situation in an apartment building. Recommendation - the battery is very questionable. Of course you can buy 2 blankets. and one to use as a sheet....
It is unclear why the developer made the sheet other than the blanket. IMHO General harm from domestic NCH radiation night exaggerated - it is not.
User avatar
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Thu Mar 01, 2018 15:11
СтаниФилмТВ wrote:In principle, it is known that massive metal objects absorb surrounding AMY in General, but better when you "resonate" with frequencies of a certain wavelength, especially if these items are grounded. So..if you take a long piece of metal pipe or rebar..and ground it, you probably get a small decrease in the intensity of the background at a little distance from Armaturen.
СтаниФилмТВ wrote: Therefore, the high frequency signal..not that-not sent from the source to the receiver, but rather to say that "signal" at the same time everywhere..and the top and bottom and sides.
And that's how this situation? On this worked atmospheric electricity. And if then the house was built not conformal .....for the safety of the residents, now all the houses are built mostly of the conformal and the angles tend to accept or reflect energy . Every house is grounded, but nevertheless, from this AMY and others... still no escape. And if we match the resonance frequency of the organ , even some Slippers will be)). This screening of the room , and by going to "ultrasonic inspection of the suit" only from AMY.))) and
СтаниФилмТВ wrote:bed Sheet still seems to have that the signal is not "passed"(bottom, not picked up) Completely sealed shielding..not to be expected of course. But if this..still grounded, the effect of "shielding".. several times to increase..)
The sheet has a "crabby" earthing(included).<
ЮрийСт
Post by ЮрийСт » Fri Mar 02, 2018 10:54
My subjective experience of using (from a few days to 10 days)
+ briefs increase the potency
+ Mike gives a sense of calm
+ bandana - the feelings of calm, o K-m wrote on the forum, did not notice
+ bandana + blanket during sleep, sleep becomes a little deeper, the quality of the dreams themselves is not changed.
User avatar
Post by ЛИЛИЯ-Р » Fri Mar 02, 2018 12:22
Wrist Try out sheets, as the bottom from the other units too upset.
ЮрийСт
Post by ЮрийСт » Fri Mar 02, 2018 14:54
try the sheets because the bottom from the other units too upset.
Don't want to mess with earth
ЮрийСт
Post by ЮрийСт » Sun Mar 04, 2018 12:24
Scarf on the neck stimulates the psyche
My opinion is that these effects are not associated with protection from external sources of radiation, but with radiation shielding his own body and reverse effects (due to reflections) on the active points on the body surface (and possibly deep in the body)
If so, it would be interesting to try the mask on the face ( with a cutout for nose and mouth) or even a blindfold, the kind they give in airplanes.
And socks (points on the feet) or insoles. There are insoles Pokal with IR reflection, but IR is more limited IMHO
СтаниФилмТВ
Has thanked: 24 times
Been thanked: 63 times
Post by СтаниФилмТВ » Mon Mar 05, 2018 11:03
ЮрийСт wrote:Scarf on the neck stimulates the psyche
How did it feel..?
ЮрийСт
Post by ЮрийСт » Mon Mar 05, 2018 12:06
A burst of energy, clarification of thought, something like taking ginseng. When you overdose couldn't sleep and had anxiety.
However, I have had an injury of the larynx, possibly connected with it. A similar effect is making me and wearing the company's products Aires throat
Aura
Has thanked: 22 times
Been thanked: 1124 times
Post by Aura » Mon Mar 05, 2018 22:13
ЮрийСт wrote: My opinion is that these effects are not associated with protection from external sources of radiation, but with radiation shielding his own body and reverse effects (due to reflections) on the active points on the body surface (and possibly deep in the body)
In fact, both effects operate simultaneously, and not only them...all about the principles of screening surfaces of the bandage Navigator without modules.
ЮрийСт
Post by ЮрийСт » Mon Mar 05, 2018 22:29
Looked not quite clear what the difference between the actions of the bandage Navigator without modules from bandanas
Aura
Post by Aura » Mon Mar 05, 2018 23:23
If you look structurally, it creates a protective bandana hemisphere, whereas the modules generate energy in the form of this hemisphere, in return with their Hypercomplex codes. Moreover, the bandage consists of a physically closed loop.
ЮрийСт
Post by ЮрийСт » Mon Mar 05, 2018 23:32
Perhaps I inaccurately asked. If there is a bandana - why you need a bandage, if modules not to buy?
Are there differences in the feelings of newinia bandanas and wearing headbands without modules
Aura
Post by Aura » Tue Mar 06, 2018 0:16
ЮрийСт wrote:Perhaps I inaccurately asked. If there is a bandana - why you need a bandage, if modules not to buy?
Of course there are differences, the shielding surface in the form of a hemisphere, or closed loop. Different products, different effects. If you make a choice "or-or", it is all subjective. We must understand that the shield products is more than just a local property, but pererastala internal energy (bio-electricity), which shows different effects at different redistribution.
Расторгуев
Has thanked: 6 times
Been thanked: 6 times
Post by Расторгуев » Sat Jun 01, 2019 18:44
For cowards I have a suggestion, make them no fly.Then to the gym and you can walk along the beach, and the city resort will fit perfectly.
Aura
Post by Aura » Wed Jun 19, 2019 1:46
Rastorguevin this case, you will get a different garment with a different functionality. Shorts.
Locked
