Re: Crystal formula
Posted: Wed Jan 24, 2018 0:06
I'd like to see these stone obelisks from Yakutia,to remove the information apparatus and to conduct a study of the influence on human nature.
MB You're projecting the experience with rohom that should give a very different feeling? The fact that man is essentially the same crystal, only with imperfect structure and sometimes crystals it turns out that in those places where it is developed, we feel the resonance of internal response, because people feel something similar, its structure and its picture of the world, and if the majority of the power chip have on the structures that people in power blocks or imbalances does not feel, it requires considerable time to these pieces of "punch" (but it's these moments that we also develop). Possibly with a citrine You require more in-depth and qualitative look into for attunement with the crystal. Taking the essence, try to remove all thoughts, feelings tonicity, take the essence "on the run" and to consider adoption of essence as the practice of deeply listening to yourself, your body, status, thoughts, subtle feelings and changes.Полиночка wrote:I Use it for 3 weeks. Sprinkled on the tongue 3-4 times a day. But some impulses to change, as was the use of crystal essences Rauchtopaz - no!
What did I do wrong? Maybe you need to talk through before use, properties of citrine or citrine on the conspiracy? Tell me, please!
Who how to effectively...there are several ways to apply the essence directly on the tongue, with a suitable carrier or an external application (in this case, the essence is absorbed not so much skin, how much perceived the subtle bodies so it is important that the area of application, it's all there in the description of the essences). Effective method of application should be individualized, the choice of method depends on the imbalances in the bodies, and the availability of current cleaning processes, from emotional parameters, sensitivity level...Кудесник wrote:On the language of sprinkling should not reduce the effectiveness of the use of the product. It is better to take the ordinary clean water (half a glass-glass) and spray 2 times there. You can then accept. It is better to take boiled and cleansed in another way water (bottled is also fine) and room temperature.
chrysoprase psikey in the mouth 1-2 zilch 3=R\day - clear, invigorating cheers
Yes, crystal essences can "dissolve" the negative structure of the perceived fears, blocks, negative emotions, etc., replacing them harmonious structures, but it is advisable to do this beforehand, because often the negative structures are stable and chronic, the formation of which occurred over several or even many years, and it may take time for a weakening of the bonds that hold them. In General, the duration will depend on the lability of the nervous system, readiness to change and determination/motivation of the person.Полиночка wrote:Aura
Hello, Aura!
I have a question for You: is it possible to use a Crystal formula to not be afraid of exams, and to mobilize all their skills during their delivery?
An outline of the technique for the crystal formula is the same 2 p/day, but it is to say formally, i.e. based on the ideal parameters of the perception of essences. In practice, the formulas used 1 p/day, especially F4000, because it is a powerful energy, setting up a circulation of energy, and a powerful surge of energy always finds a way to the operator in real conditions, especially the rhythm of the city. Therefore, it is recommended to start with 1 p/week., in order to addiction, and then go to reception 2 p/week. And have to take a minimum of 1 hour before and 1.5 hours after food, preferably more.Аура wrote:Aura, Hello. What is the recommended frequency of reception for F4000?
And to pick up students/applicants should also to your taste? Feels like/dislike?Аура wrote:Yes, crystal essences can "dissolve" the negative structure of the perceived fears, blocks, negative emotions, etc., replacing them harmonious structures, but it is advisable to do this beforehand, because often the negative structures are stable and chronic, the formation of which occurred over several or even many years, and it may take time for a weakening of the bonds that hold them. In General, the duration will depend on the lability of the nervous system, readiness to change and determination/motivation of the person.Полиночка wrote:Aura
Hello, Aura!
Yes, crystals are recommended to pick up on feelings is how to choose a human partner, to rely on their own feelings, in practice it is always more effective than the advice of others, but if the feelies this absolutely refuses to work...under the task described, I recommend beryl, emerald, chrysoprase, rock crystal, tourmaline, and better in combination in the form of formulas for this task are compatible, F2000, F4000 F5000 or.Полиночка wrote:And to pick up students/applicants should also to your taste? Feels like/dislike?
Hello, Aura!Аура wrote:
The very phrase “essence crystal” at first glance may seem a little strange. Everyone knows that the production of essences involves dissolving, distillation – that stones can be done. Initially, experiments with the technology of production of essences was conducted on vegetable raw materials. But in the course of observations revealed that the frequency and environmental change on Earth over even the last 5-10 years has led to a significant decrease in the strength of biological components.
In other words, those sources of energy that have successfully sustained the man until recently, now I can't so effectively to perform this function for the reason that their frequency characteristics (7,4 – 8,5 Hz) are below the necessary in modern conditions of man.
Everything works and will work when correctly chosen and done properly breath through the nose,the healing is instantaneous.The problem is that the natural oils in the sale of small ,mainly synthetic,which are harmful to health.And it is difficult to define the naturalness of the oil,this requires expensive equipment.Aromatherapy is a very ancient teaching and has relevance in our days.is it advisable to finish courses aromatechnologies (effect of essential oils on human)
Not quite. Significantly reduced his power, but has not ceased to act. Here's how the crystals more importantly, where are the components. There are places on Earth, for example Peru, where the frequency indices of the space is so high that the vegetable components of this place still have great power.Полиночка wrote:instructions for crystal essences says that herbal infusions have ceased to operate and has lost relevance, because of the increase in the frequency of the noise of the Earth.
Aromatizzata refers to the essential influences and is different from the action of herbs in form of tinctures. The etheric space is actually also has a crystal basis (to be precise, each fragrance has its own structure, geometric shape) and the effect of scents can be roughly compared with the action of the crystal essences. In other words, the frequency of the aromas depends on the structure and not the frequency of vibration of the plant, so the frequency change affects the need for changes in the quality of smells like quality of the space, but does not affect the strength of the impact of odors as such.Полиночка wrote:So the question to You as a specialist: is it worthwhile to finish courses aromatechnologies (effect of essential oils on the person), if that is useful to me personally - I figured it out, but would like to help friends and friends of friends? Or therapeutic effect on the emotions essential oils will soon lose relevance, and it is a waste of time transferring the money?
Day not it is not manifested. But on the dawn several times. First thought is a hallucination, but after developing a few times I wanted to find out. Seen it short emerald glow crystals and plants ( the plants watered with water from RAD2400), the glow of the crystals was shown after exposure of the palm and crystalЛИЛИЯ-Р wrote:that is, with the use of crystal essences ? This was not observed . Photism - (gr. phos – light, opsis – vision) 1. basic optical hallucinations as point flashes of bright light. Synonym: Photopsias; 2. a similar phenomenon may occur in diseases of the retina; 2. version of synesthesia... Zhmurov V. A. Big explanatory dictionary of terms in psychiatry.
But if you take the second option of synesthesia , so you mean the vision of the subtle body (energy), everki herbs , humans and animals...? Day see the outlines of plants blue-green contour, and the glow of the etheric double . What do you see?
Noticed it after applying the essences?ВИТАЛИЙ ГИНЗБУРГ wrote: Day not it is not manifested. But on the dawn several times. First thought is a hallucination
No, after the meditation with crystals chrysoprase. The use of essences yet in the draft), so I decided to ask advice from those who already have experience with the essencesЛИЛИЯ-Р wrote:Noticed it after applying the essences?ВИТАЛИЙ ГИНЗБУРГ wrote: Day not it is not manifested. But on the dawn several times. First thought is a hallucination
ВИТАЛИЙ ГИНЗБУРГ wrote:Dear Aura!
The described effect may occur as a result of the use of cards Alchemy II and some displacement of the spectrum of visual perception in a specific state?
How to develop it ?
If you compare the image with monitor night vision device, it turns out identically ( as you can on the available videos to judge from the network)
