Page 1 of 1
to erase the memory?
Posted: Sun Jun 23, 2013 5:09
by Экко
not found where to post the topic. because here
so, can I erase the memory? when I hear sounds or see items similar to the ones seen THEN I'm not so sickly back then and it's pretty unpleasant. the state is now I think at least partly the result of the memory of what it was. you can block the memories? to remove the length of time out of your life?
Re: to erase the memory?
Posted: Sun Jun 23, 2013 12:58
by Ростислав
on the contrary we need to work and work through those moments of memories that are unpleasant otherwise, then from there the disease vylaziyut
and the Erasure of memory is the path of unawareness
Posted: Sun Jun 23, 2013 19:12
by к-13
You can completely clear the memory lethal dose clonidine and begin to live from scratch, but really easy to process the negative experience. In Your case should be well help NLP technique "collapse anchors" negative anchors already installed, install the left and positive to erase those and other simultaneous call.
Posted: Mon Jun 24, 2013 3:14
by Экко
к-13 wrote:Can completely clear the memory lethal dose clonidine and begin to live from scratch
what is it like? in another incarnation perhaps
EMM.. not very clear.. positive anchors. what and what to install? and then they all erase?
Posted: Mon Jun 24, 2013 3:15
by Экко
and erase (block) memory as possible? can affirmations what?
Posted: Mon Jun 24, 2013 13:31
by к-13
Экко wrote:к-13 wrote:Can completely clear the memory lethal dose clonidine and begin to live from scratch
No, in this... I Personally know a few people who are in the 90s gave to klofelinschica (fashion was a way of robbery - a young lady watering a truck driver or Shuttle in alcohol with the addition of the drug, he cut down for a day almost, come the accomplices, clean it and leave it somewhere on the street. Well, if you woke up and didn't get home - clonidine has a side effect - after a very bad recall, especially short-term Amati, and often the dose is exceeded repeatedly for insurance, and this led to a total blocking of memories - people didn't know who he is, where...), the two still can't remember what was before that day. This was lucky that they found and identified, and would be bummed to death (very fast due to the lack of experience base).
I can advise Google))) I wrote about it here -
viewtopic.php?f=47&t=5272 anchor can be supplied while watching a good Comedy. The technique is simple and readily available for independent use.
You can key Aliyev to work or appliances EMDR Francis Shapiro (they are in fact very similar), it is also very efficient, but more confusing to review.
Posted: Mon Jun 24, 2013 13:33
by к-13
Экко wrote:and erase (block) memory as possible? can affirmations what?
What's the point? It's the experience, give it up stupid. Once finalised, it will be just a colorless memories are indistinguishable from memories of reading the morning newspaper in the most boring day...
Posted: Mon Jun 24, 2013 15:47
by Экко
Aah! right now, I just realized that I have those negative anchors to turn into a positive! or I not correctly understanding? if I understand correctly, it is necessary to understand how to do it!
Posted: Mon Jun 24, 2013 16:51
by Экко
the anchor is nice.. but I'm not sure it's enough. maybe memories will also do its dirty work?
Posted: Mon Jun 24, 2013 17:44
by к-13
Экко wrote:Aah! right now, I just realized that I have those negative anchors to turn into a positive! or I not correctly understanding? if I understand correctly, it is necessary to understand how to do it!
And read the link? Don't need negative anchors to turn in the positive (first, it is quite difficult - when you install will constantly knock state, and second, nothing - anchors transformirovalsya, and negative emotions in the memories will remain - they will always spend the personal energy to pull the attention, fill the inner monologue...), you need to create positive anchors and trigger them simultaneously with a traumatic - and from this negative, and positive will lose charge - it will remain just neutral memories. I used this technique thousands of times (in this case on only a few occasions in the beginning), it always works - if the negative emotions too much, you just need a few positive anchors to kill one negative, but useless, this technique can not be sure.
Posted: Mon Jun 24, 2013 17:45
by к-13
Экко wrote:the anchors is nice.. but I'm not sure it's enough. maybe memories will also do its dirty work?
What is this confidence if you've never tried? Of course, why use one of the most effective (and yet easy) techniques that when you can fantasize about the Erasure of memory, the help from aliens and time travel?)))
Posted: Sat Nov 16, 2013 1:40
by Шломо
Экко wrote:not found where to post the topic. because here
interesting you found some suitable method?
Posted: Thu Nov 21, 2013 3:16
by Витт
Described in some detail the process in the next topic - the Effect of non-thermal (informational) influences of EHF. There is also the author of the quoted material says that this is possible.
Posted: Sun Nov 24, 2013 20:14
by Вячеслав.
Was wondering what theme to choose,chose this.When I was doing "rowing"and was reading at the time about those people who were an example for me...Vyacheslav Ivanovofficially a three-time Olympic champion,not officially...four times!Recently remembered about it,looked online.And I came across this article...
Vyacheslav Ivanov."HE rowed,and"busted"others."
What all I have written,it is difficult to say.Just in the past,and I was lucky enough to stay in the Union...there are so many examples to follow.We are all looking for someone...of course,to study,to learn from the best...to keep up with the times.All this is correct...but it's a shame when after all that...
And please do not accuse,in some kind of uh...narcissism.
Just coincidentally,I, too, Vyacheslav.
Posted: Wed Jan 22, 2014 21:26
by Шломо
I found this book "the Memory man" - Wayne A. M.,though already old Year of release: 1973.
maybe something else will advise on the theme of human associative memory?
