Page 1 of 1
City figvam
Posted: Sat Jan 05, 2013 18:51
by ЗОМБИ
What do you think is better at other equal conditions: apartment in a new brick house on the 7-10 floor, 500 meters from the highway of Federal importance or apartment in monolithic concrete low-rise building in 3 kilometers from the highway of Federal significance.
ie the option to "smog" it is clear that the farther the better, and the parameter wall material? in the monolith much sucks to live (now in socket concrete live)?
Re: City figvam
Posted: Sat Jan 05, 2013 19:27
by Константин.
Let's just say: the Concrete, the monolith is heavily Yin. Will suck the life from any(if special measures are not taken)
Brick - clay-earth. Gives heat out at least some. I lived in the brick apartments, and in the concrete - definitely a Brick a hundred times better!!!
Re: City figvam
Posted: Sat Jan 05, 2013 19:31
by ЗОМБИ
Constantine.
I also like the bricks more wheels... just not hunting in gazenvagen to live... what do you think 500m from the road much worthless, while it is not googled at a minimum distance from roads and the minimum height at which gases from dust at least within the sanitary wonderful
Re: City figvam
Posted: Sat Jan 05, 2013 19:37
by Алексc3000
The wind rose you need to watch.
Re: City figvam
Posted: Sat Jan 05, 2013 19:41
by ЗОМБИ
Алексс3000
got it, thanks, will Google wait
in General, the priest... there to the reservoir is less than a kilometre, the track between the housing and reservoir... net says that the breezes blow here and there... ie, the gases will carry here and there... the wind rose for a particular location is not found
Re: City figvam
Posted: Sat Jan 05, 2013 22:20
by Ланцелот
Something vaguely remember That above the 10th floor something changes in the electromagnetic field. not for the better. Infa from the late 80s.
Re: City figvam
Posted: Sat Jan 05, 2013 23:53
by к-13
Also I vaguely remember that "from the movement at a speed greater than 30km an hour, the chickens stop laying, cows give milk, and people will inevitably go crazy"... When the first steam locomotive ran also said that he is evil and should be banned!
Infa from the mid-nineteenth century
I mean the fact that people have a lot to write...
Dima, you would have to red square asked someone to marry you))) and Put one flat, and the other, stop in the center of the living room, close your eyes, raise your head and eyes under the eyelids up(not much). Follow the sensations and everything will soon become clear. Too many more factors in addition to distance from highway, construction material, and floor of housing affects its properties.
Re: City figvam
Posted: Sun Jan 06, 2013 14:08
by ЗОМБИ
к-13 wrote:on someone to marry you)))
yeah, it would be good to know in advance something
Re: City figvam
Posted: Sun Jan 06, 2013 17:20
by Ланцелот
к-13 wrote:I mean the fact that people have a lot to write...
Of course you can izgolyatsya anything. But the first link in Yandex on request "at what altitude is safe to live" issues
http://news.open.by/health/22625
the higher the better, according to most: cleaner air, less noise, the view is beautiful. However, according to most ecologists, urban development, it is not necessary to get above the 6th floor. The air in the sky is not so clean: after all pipes of large and small companies fumigate any city, and accumulation of harmful substances at a height of 30 m and above can be very significant, especially if the wind is blowing in your direction.
Another invisible enemy, plaguing residents on high floors, - electromagnetic radiation from electrical appliances. Of course, the wiring and the washing machine "kicking" the same and the first and 17th floors. However, reinforced concrete structure does not pass the waves, causing them to circulate around the apartment and giving part of the background on higher floors up to the attic. The higher, the stronger the total background. It is believed that this is why residents of the upper floors "sockets" often suffer headaches and bad mood.
So let comrade Zombie decides where it will be comfortable.
Re: City figvam
Posted: Sun Jan 06, 2013 20:34
by к-13
Ланцелот wrote:of course You can izgolyatsya anything.
Thank you for letting
About coming down on the train crazy chickens at a time on the front page in the papers
Don't believe everything you read on the Internet
Now all is want to end up, and how to do it, if not having started yet another horror story out of the blue? So I'm afraid we're all genetic engineering, end of the world conspiracy of the Jews, the invasion of aliens and other ducks
Ланцелот wrote:the higher the better, according to most: cleaner air, less noise, the view is beautiful. However, in the opinion of the majority of the environmental urban developmentshould not get above the 6th floor.
Who is the author of this pearl about the fantastic variety of environmentalists?
Can thousands of a result of arguments in opposition to both theories. To argue in this matter - grinding water in the grinder.
View of the city down, for example - a great way to distance themselves from everyday problems(look at the fresh Boo-Boo through the lens of the binoculars when the optics removes, you'll understand what I mean).
Ланцелот wrote:the Air in the sky is not so clean: after all pipes of large and small companies fumigate any city, and accumulation of harmful substances at a height of 30 m and above can be very significant, especially if the wind is blowing in your direction.
In addition to the visible smog(actually the products of combustion, which are derived from the lungs with phlegm), there are a pair of heavy metals - the most harmful component of urban air(from the body displayed with great difficulty, for example injections of the same sodium thiosulfate). But she is always on the surface - at the height of the first floor. There are volatile components, which with great speed take the entire available space and on the ground floor and the last of them will be the same(although at the top-skvoznyak - at least some, but the fresh air, and the bottom of zatishok - "drive utility").
Ланцелот wrote:However, a reinforced concrete structure does not pass the waves, causing them to circulate around the apartment and giving part of the background on higher floors up to the attic. The higher, the stronger the total background.
Again the argument of "science fiction"))) And what is the reason of such a strange behavior of electromagnetic waves? Instinct turkeys, the centrifugal force of rotation of the ball, the weight of the air or their sincere desire for a high? I think quite the opposite - the higher from densely populated layer, the fewer sources of spurious sources(electromagnetic and mental)... Sometimes amazed by the knowledge in the curriculum of the stars of journalism
Re: City figvam
Posted: Sun Jan 06, 2013 23:29
by Ланцелот
K-13 though on this occasion the dispute is not?
Re: City figvam
Posted: Mon Jan 07, 2013 1:17
by к-13
Ланцелот wrote:K-13 , though on this occasion the dispute is not?
Why should I argue with You, celebrate what you want, I yesterday Turity met.
6 Jan
Turitsy dedicated tour — one of the ancient Slavs worshiped among animals with magical powers. In the tour is embodied Union Veles and Perun the glory and prosperity of rod Slavic.
Son of Veles and Mokosh, the Tour, like the Greek pan the protector of shepherds, gusla players and buffoons, youthful daring, games, dancing and fun, and groves, and beasts of the forest. In the North of the Tur appears proud deer and the boreal forests of shochetim.
On this day, wondering at all the next year, as the festival closes winter Yuletide. 12th day of Christmas corresponds to 12 month of the year. Divination occur in the evening, after dark. Collect snow to whiten canvas. The snow collected in the evening, thrown into a well, can store water for the whole year.
The Slavs have seen in a holiday Tour of the ancient rite of youthful initiations into manhood when, as the incarnation of a wolf, the young man had to demonstrate hunting skills and military bravery and to fill up your first round. Ancient Slavs took the example of these formidable animals, who did not care for myself, to protect the herd. They tried to teach the younger generation to attack and defend, to show resourcefulness and resilience, endurance, courage, ability to unite for the repulse of enemies, protect the weak and find the weak point of the enemy. Many years tours, wild bulls, served people as a symbol of honor and courage. Of Tur horns made cups and cones, which are appealingly trumpeted in military campaigns, and of particularly large horns made even Luke.
Source:
http://www.calend.ru/holidays/0/0/1567/
© Calend.EN
I and on those occasions did not argue - we both expressed their opinion to the person who needed it. It is necessary to distract in between wax casting, shuffle decks and layouts of runes
Tonight the universe was particularly generous with answers.<
Re: City figvam
Posted: Sun Mar 10, 2013 21:17
by ЗОМБИ
Anyone know what carpets to choose/use to the grass then the chemicals from the carpet evaporating...
(I do not sensu yet... tell me who to marry
Re: City figvam
Posted: Wed Mar 13, 2013 8:24
by Константин.
Only natural materials!
..but what is depicted in these carpets is also important.
