Испытатель wrote:How do you get into multidimensional perception, if the head does not score?
Information is useful only that which can perceive, the rest can be harmful (at this stage of personal evolution) for various reasons, one of the most common is the development of glyuchnosti of perception, or sense when interpreted incorrectly or the author of "gluconate"..... a check is not possible, and the most authoritative authors can also sometimes be mistaken or incorrect to interpret the observed..... Besides this harm even the minimum possible. The fact that (or even fully perceived through contact) to the multidimensionality of the need to pass a certain stage in its development, to obtain necessary skills to enter the turn-of-contact with multi-dimensional objects "touch" required the fearlessness (not just I'm not afraid or I don't care, not afraid of, including death, because I know from experience sensations as it is happening and what is possible in this case to do a skill resuscitation) otherwise, you can get quite noticeable trauma of the subtle bodies - break the cocoon of fear, if at some point did you go fear, paralyzing fear, after the recovery may take a long time, and sometimes more than one life.....
To develop skills in dowsing should be training in dowsing and to gain experience, learn to correspond more or less to interpret the data, i.e. make your own complete library of these reactions of the dowsing tool (frame or pendulum). Better to start with simple data that can be unambiguously interpreted and are easy to check by other methods, thus it is possible to develop the credibility of the information received and to choose the methods of interpretation.
The fact that "how to" let quite a bit, the subconscious mind works for most people, this "how to" may be enough for information retrieval using the tools of dowsing, however there are reasons why it may be better or worse. The fact that the subconscious is working through the mind and when the signal is weak, the subconscious signals of consciousness and the body "clog" the channel. Well, for example, at night (when quiet) you can hear a little rustling at a distance, and near a busy motorway not to hear the cry of a few meters, I think a clear example. To enhance the perception of a signal from the subconscious it is possible to reduce the amplitude of the signal of consciousness, it is useful to maximally calm down (alpha) and dive into yourself for contemplation (theta), and a theta-state (concentration, deconcentration, meditation, visualization, etc.) can help to improve the perception of weak signals, immersion in the space activity signal (meditation), "dissolution" in the background signals that interfere with the reading (deconcentration), focusing on the signal which you want to count (concentration) etc I would recommend disks Andrei Patrushev of this series ("Theta meditation") to receive practical skills of these States (both tools work in the inner world), though it takes time, often not enough (no such simulators is the ability of accumulating another ten years of meditation, this background is another year for the quality of the work skills is not a lot), but "if nothing is done, the results will not be.....".
.....and CD Andrei Patrushev "a journey through the inner worlds", to reduce the number of sources of "noise" and enhance intuition.
Success!
Sincerely, MAG.no<
