Magic plate Mishina
Posted: Thu Oct 21, 2010 12:37
I propose to discuss the option of linking SP with the use of brass plates A. M. Mishin. Sho TSE take:
on the forum http://www.nerealnost.ru/index.php published by the author of the article "Protection from negative radiation."
The article itself, but unfortunately the picture is not copied from me, but after reading it will be clear:
PROTECTION FROM NEGATIVE RADIATIONS
Mishin A. M.
The international club of scientists, St. Petersburg
E-mail: alsvet55@mail.ru
In real space-ether, there are unknown in classical physics, forms of matter and radiation, which occupies the parallel subspaces (worlds). The best proof of this truth are numerous supernatural and therefore sverkhvysokie phenomena as the result of the infiltration of a different physical reality in our World. Currently, the study and reproduction of such phenomena in the laboratory are numerous research teams around the world. Such circumstances be obliged to recognize the birth of a new direction in science - terrestrial ecology, i.e. the negative impact on people of non-traditional radiation and fields [1, 2].
Essential smog can be either artificial (radiation "esoteric" laboratory equipment, and radiation instrumentation original appointments) and of natural origin. In the latter case this is due to the transition of essential processes in cosmic scale (eclipses of the moon and Sun, solar flares, full moon, new moon, etc.). To natural sources of negative radiation include extreme geophysical processes and the anomalous zone.
Innovative technology and first super energy generators generally have a negative impact on human rights. Even a low current (10 µa) laboratory experimental device for the registration of terrestrial radiation cosmic bodies in a few hours cause bouts of a type of motion sickness. It is obvious to security researchers from harmful radiation and essential "smog" is necessary to develop corresponding techniques and tools that can be used to protect weather-sensitive people.
Long-term experience of experimental study of air allowed the author to find a sufficiently effective means of protection. This includes mechanical methods of destruction of essential smog in the laboratory (ringing bells, knocking a fairly solid metal objects). The burning of "combustible" components of smog with a lit candle. However, the most effective method is the information of personal protection. In this case, the information about nontraditional fields and the radiation is recorded on ordinary matter when it goes from liquid to solid phase. Then recorded the information matrix in a special way is transferred to antimetric. With the last copied tablets for oral administration man, "charged" essential the smog. Animatrice pills in the process of annihilation destroy harmful airodynamics vortex structures. After that, the man returns to the normal state of health (it is desirable to leave the lab).
An information protection method based on the achievements of the information (resonance) medicine and open author of the law of etherodynamics. Many medical centers non-traditional methods of treatment using the method of "marajuana" (recording) airodynamics thin structures on a carrier in the form of paraffin in the mode of transition from liquid to solid phase. There are other methods (devices) for storing "homeopathic" matrices, for example, dosage forms. Sometimes used for this purpose is water. However, we will use paraffin, which is for internal acceptance form in the form of tablets on a plate of brass with the most neutral ethereal aura.
The physical essence of the author's way of individual protection is to discover the special properties of the metal plate having a rectangular shape whose length is twice the width. The "magic" plate, cut from a brass sheet with a thickness of 0.8-1.0 mm and a size of 10×20 cm, shown in figure 1. (Perhaps the best results will be when insert size 5×10 inches).
It is clear that the rectangular plate in figure 1 fit like two adjacent to each other square. It turned out that adjacent squares in the essential sense are opposites and open the "window" into the antiworld. (Try to take the edge of the plate with both hands, - after 5-10 minutes You will become very uncomfortable).
Assign the left square number 1 and the right - figure 2. If the center of the square 1, the horizontal arrangement of plates to put paraffin tablet with recorded essential information (essential vortex matrix), in the region of the center of the square 2 formed field animatrice, i.e. the vortex structure of the opposite helicity. In this case, the square of 1 corresponds to the material structure and to the square of the 2 - antiwestern. In other words, a liquid drop of paraffin, frozen in the center of the square 2, will contain information opposite to the source. Swallowing both tablets will be annihilation of the essential fields and get a null result, although the first pill could be harmful information.
The sequence of actions of the experimenter. In close proximity to the radiating element of non-traditional instrument to the square of the writing white paper (without text) of size 10×10 cm in the center with a lit paraffin candle through the tapered groove of the same paper (pressed fingers to the candle) to gently poured into a tablet with a diameter of 10-15 mm convex shape. Wait until the tablet has hardened and cooled to room temperature. Instrument switch off.
Closer to the center of the lab (space) put on the floor bedside table or Desk. On the bedside table put a plastic Cup with a disposable tableware, and it put symmetrically "magic" plate, oriented with the long side (square 2) at 30° to the South East, where there should be Sun or moon. On the left 1 square put a paper square with a large paraffin tablet, which recorded negative information. In the center of a square 2 with lighted candles through the paper groove in the form of a cone with a length of about 30 mm (from the flame) almost touching the drip plate (formed) liquid convex tablet with a diameter of 3-5 mm. This is done fast enough. The vertical profile of the tablets must be in the form of an ellipse with a flat bottom. Wait until the tablet has hardened, cooled, and swallow it with water. If Your body was "charged" with negative radiation during the test the innovative device, animationa swallowed the pill of your field will carry out the annihilation, and Your soreness after 20-30 minutes will disappear. I successfully used this technique for over 10 years.
Paraffin tablet stores the recorded information to several years, and you can make up to 7 pills in the center of the square 2, if the conditions of the experiment unchanged. But the situation in space is constantly changing, this procedure has to be repeated again and again.
The sequence of actions for weather-sensitive people. If You feel unwell in connection with sharp change of weather conditions or phenomena of the cosmic order (the Eclipse of the Sun, moon, etc.), on the nightstand or Desk put a plastic Cup on the paper square 10×10 cm as described above, in the center of the square formed by a large tablet with a diameter of 10-15 mm and wait for it cools. This tablet "remembered" the ethereal atmosphere of the apartment. If you're going to go outside, the better this procedure is done on the loggia or balcony, where essential, the situation is quite different.
In the manner described above, using the "magical" plates make small tablet for oral administration (swallowing). If you change the essential situation and the deterioration of health need to make and take a new tablet. The latter can not swallow, and keep under the tongue, which is not very convenient.
Apparently You guessed that from those described here of the method of individual information protection against harmful radiation to the method of correcting the biofield and treatment of diseased organs is just one step. But that's another topic. At the request of the workers can be published and the author's method of home healing.
LITERATURE
1. Mishin A. M. Unconventional environmental problems. The XXXVII conference "Mathematical modelling in problems of rational use of nature". - Rostov-on-don: Izd-vo yufu, 2009, pp. 121-122.
2. Mishin A. M. the Beginning of higher physics. A collection of articles. - SPb: ANO "STC them. L. T. Tuchkov", 2009. - 270 p.
Linking in the sense of to leave out for curing for example orgone part to attract orgone to the left and vokrugsveta with dragmetallov right?
Mishin A. M.
LITERATURE
