Page 1 of 2
How to see the "aura"
Posted: Fri Sep 19, 2008 14:42
by Владимир Никонов 2
Suddenly I saw the "aura" and that's how it can make any.
Turn on the lamp, I have outdoor. Aim it so it lights in the floor or at an angle down from you. Put your hand under the lamp, close one eye and just squint your eyes and you will see... the flow of the light reflected from the hand.
So any items to put under a lamp and see the streams of light. This is clearly some kind of physical phenomenon - now I will look for his explanations on the Internet.
Viewing experience of "aura" is indescribable!
Posted: Fri Sep 19, 2008 14:58
by Любовь
Really
Then the eye that was closed, saw it all very vague within minutes. Interesting to read the explanation... ehh... in physics I am not strong
But looks nice, maybe it's a reflection of some kind?
Posted: Fri Sep 19, 2008 15:31
by Идущая вперед
partially see the aura a long time... sometimes when the rays of the sun spread across the hand range I see and admire them... if you look absent-minded eyes, I can see stereoscopic images of any complexity (for daily training took six months) it is well visible aura candles on a black background... almost a year arrived in the belief that the aura I blue.... went a month ago in the White clouds - 900 RUB photo of the aura diagnosis and chakra printout of 20 pages of... aura was blue... and her daughter was taking pictures in the ROAD TO self there 450 RUB current one photo... different machines... she has a yellow-orange... photo Kirlian is deprecated and replaced by modern cameras aura and every person can see their energy shell.
I just see 2 layers of your aura is somewhere 3-5 cm from the hands and the photo shows a broad picture including dimmable breakouts if they are available... often the disease is still not manifested physically but her aura is clearly visible...
Posted: Fri Sep 19, 2008 15:36
by Идущая вперед
still forgot to tell. when I look at the sky diffused opinion (as stereo considering), see the so-called karpuskuly light... when I first saw it 2 years ago already began to cry such a strong effect was... now periodicheski admire but happiness from this special don't get as for the very first time... look at the sky - and there in the sky many there are countless number of little points of light darting back and forth... especially in Sunny weather...
Posted: Fri Sep 19, 2008 15:47
Going forward, the sky is you will most likely see the figure of Haidinger - here is a description
http://www.yugzone.ru/articles/polarized-light.htm
Posted: Fri Sep 19, 2008 19:37
by ЗОМБИ
I also in the spring did the photo of the aura. MNU yellowish, almost a meter radius
Another familiar person was shown, if belosero the background without any bright light sources and reflections look at your fingers, pinch them, those grey wisps seen. Rostkoviana the trees look too fithen haze.
Only the color did not work.
Posted: Fri Sep 19, 2008 20:05
by Андрей Кабанков
Идущая вперед wrote:escho forgot to tell you... when you look at the sky diffused opinion (as stereo considering), see the so-called karpuskuly light... when I first saw it 2 years ago already began to cry such a strong effect was... now periodicheski admire but happiness from this special don't get as for the very first time... look at the sky - and there in the sky many there are countless number of little points of light darting back and forth... especially in Sunny weather...
I see the same!) I thought I had something with eyes.)))
Posted: Fri Sep 19, 2008 23:16
by Алексей А
Also saw such a movement.When I was young and kind.Now coarsened and did not see...
Posted: Sat Sep 20, 2008 0:14
by аура?
and the aura - well treated galoperidolom
Posted: Sat Sep 20, 2008 10:17
by Guest
aura?
+ 1. About fenozepam forgotten.
Posted: Sat Sep 20, 2008 10:26
by ЗОМБИ
Posted: Mon Sep 22, 2008 11:18
by Идущая вперед
I also used to be in all didn't believe it... THERE are all SORTS of AURA ENERGY...... lived like everyone went with the flow.... The DAY was OKAY... and then something happened really bad, IT WAS a GREAT TEST of STRENGTH...
then began a yoga practice and self-development... six months could not see stereo... ie to see 1 stereo image it took me half a year of daily training...
today standing on the street the sun came out in the morning... admire the rainbow rays from the sun depart thread to me and I see the whole range of...
Posted: Mon Sep 22, 2008 12:52
by ЗОМБИ
Going forward
Идущая вперед wrote:today standing on the street the sun came out in the morning... admire the rainbow rays from the sun depart thread to me and I see the whole range of...
cool! you pumped stereotactically?
Posted: Wed Sep 24, 2008 12:13
by Идущая вперед
http://www.kaplya.ic.km.ua/links.html but this page taught me a lot and opened my eyes
Posted: Sat Sep 27, 2008 1:49
by ЛИЛИЯ-Р
Андрей Кабанков wrote:I can see it!) I thought I had something with eyes.)))
And there are those who do not see it? Around the fingers for example if you look past them the first little field second little more than a third already far beyond the aisles and the color of each field on your own. If the fingers be kept parallel by connecting between them like a haze and tiny "snowflakes" radiant wusasa around the fingers and rays straina .But if for example thumb and index to send tips to each other except to say compounds of this haze between the fingers of another connection beams and the connection of these radiant"snowflakes" when pumping they increase. Similarly when bodies are close . Especially if you look past them in the dark . Picture of shadow rays and the shimmering "snowflake". As you can see the movement of air currents. and much .
Posted: Sat Sep 27, 2008 1:56
by ЛИЛИЯ-Р
Everything in this world has these fields and the glow and the motion of these fields and rays and all their light. The selection of images in the stereo image is also a little look at the subject a little closer to him and poloy be divided into different levels and at the request of any make in the foreground, next the second and so on. Can all of the common pattern to remove unnecessary color to focus the eye on the color and contour which is necessary. For this we need six months to train. Just a trick of the eye and no effort.
Posted: Mon Sep 29, 2008 13:07
by Ал-е-кс
Yeah! Seen like "balls"! The background has been reduced especially evident. To see this is not difficult as it seems.
But there may be 2 options.
I now see these "balls" - like "droplets" on the cornea. Ie they are purely physical Zealand - projected onto've seen. And "multishot" as I drive through the eyes, maintaining the position relative to each other. And if you blinked, you certainly will have other and in a different quantity. In General, nothing.
And yet, I understand, have option vision certain objects. But who knows, it may turn out that just the same "balls", just someone like wishful thinking.
However, the variation is quite large. Friends generally see the sphere, colored with symbols, signs, different nature...
Here are some "scientific" information on this subject:
"Modern neurophysiology has discovered phosphenes, geometric shapes and images that are subconsciously present in the visual centers of the cerebral cortex and the nervous system. These forms and images available to all people: they are called atopiceskih, that is visible with closed eyes. Their is also observed in the transformed States of consciousness during meditation, ecstasy or hallucinations caused by fatigue, disease and drug use. Geometric shapes corresponding to the letters, often perceived in the early phases of entering into a trance.
...This shows that alphabets, whether they be Hebrew, ancient Greek, Etruscan, Latin, runic, lavrenchenko, Gothic, Westphalian or all of us, the usual Roman typeface, are natural elements of the neural structure of every human being."<
Re: How to see "aura"
Posted: Tue Oct 14, 2008 12:40
by Guest
Никонов Владимир wrote:Suddenly I see "aura" and that's how it can make any.
normal reflection of light
Posted: Sat Oct 18, 2008 23:56
by Я Есмь
People, why are you surprised? interesting, and you can see others, but themselves and their discoveries? As in det.sad!
Posted: Sun Oct 19, 2008 14:57
by Андрей Кабанков
Я Есмь wrote:People, why are you surprised? interesting, and you can see others, but themselves and their discoveries? As in det.sad!
If the person has retained a perception of the world "as in kindergarten",then I think it's great.If the world you are not surprised ,I just wish you...
Posted: Sun Oct 19, 2008 15:10
by Я Есмь
Андрей Кабанков wrote:If the person has retained a perception of the world "as in kindergarten",then I think it's great.If the world you are not surprised ,I just wish you...
Do not worry for me
This is of course great.
Sorry little well.
Posted: Sun Oct 19, 2008 15:14
by Я Есмь
Don't waste on me your energy, the more negative.
Sorry little well.
Posted: Sun Oct 19, 2008 17:01
by Чукча
So small and already so pooped, but....
Posted: Sun Oct 19, 2008 18:29
by Андрей Кабанков
Я Есмь wrote:Андрей Кабанков wrote:If the person has retained a perception of the world "as in kindergarten",then I think it's great.If the world you are not surprised ,I just wish you...
Sorry little well.
Forgiven already).
Just in the 40 years I have kept all the children's interests.And if in kindergarten I spun on the carousel,but now is spinning in an office chair.) In this case, my "adult" colleagues look at me blankly.
In the winter I ride a mountain bike,recently bought his first motorcycle.
That's written in defense of the adult "children",as he is).
Posted: Sun Oct 19, 2008 20:28
by Guest
Андрей Кабанков wrote:have been Forgiven).
itself is the same, just yesterday, my husband hurt for the child, was allergies, but today realized that he's so Makar, me as a mother does. Weird?
Andrew thank you for your mercy.
