Page 1 of 28
The cylinders and unimodularity... does It work?
Posted: Sat Feb 09, 2008 20:45
by Шум
A question for those who already tried in action. Is it possible to use them to control the energy? It is desirable more in detail and separately.
Posted: Sat Feb 09, 2008 21:36
by незарегистрированный
And what is it????????
Posted: Sun Feb 10, 2008 22:15
by МИТРА
I have a Set of "Cylinders of Pharaoh".
It was a struggle to find the True manufacturer of This product and Sifted through a bunch of False information and Fake Sites.
A couple of books collected,but the information is all dug up.In General and decided to buy by mail.Sent quickly,and Supporting pleased.From Decent sheath,and Two DVDs with a Full Explanation of what it's like. At least this,but pleased.
Really can't constantly Use them.Sometimes it is hard them to hold in their hands.(It only at me such Hands hurt).But I think still they work.
In General,while no complaints.If something interesting will happen to write.
Posted: Fri Feb 22, 2008 3:20
by Светлана
МИТРА wrote:I HAVE a Set of "Cylinders of Pharaoh".
And I've never found all of the manufacturer these Rods of the Pharaoh, they still need a device called KARAN, I would really appreciate a reference or information where it can be purchased. Thanks in advance...
Posted: Tue Feb 26, 2008 22:00
by Шум
Expensive especially those for 325000 RUB Here, for example, to take and to pay for them NN-th sum, and they do not work.
And suddenly work?
But check as you do not want.
Posted: Wed Feb 27, 2008 14:40
by Dimas
Noise
And I really want to check,but the toad smothers...
Posted: Thu Feb 28, 2008 0:49
by Guest
Dimas wrote:don't want to advertise anything here,so I will not give references. these cylinders are called "Wands of Horus",the rest of the patent holder referred to as fakes
Not understand what the right and one of You is right?
Posted: Thu Feb 28, 2008 12:38
by Dimas
Guest
And dunno!
Posted: Thu Feb 28, 2008 17:48
by Guest
These cylinders are the Cylinders, they were recreated and researched physicist Vladimir Kovtun from Peter, and all the other cylinders are copies, or even fakes not working. Cylinders Kovtun received a patent as a physiotherapy device. Use for 4 months, power cleans, restores, and configures the cells into a healthy vibration. I have no doubt it was, since I feel his energy, picked up and immediately felt. A strong energy is health and vigor. Only there are a few tips I have: when you start to use the cylinders and the first results don't tell anyone, enjoy myself, but not to the calf's joy )) And one more thing - don't go to sleep with the cylinders and hold the cylinders for the night - a sleepless night is guaranteed.
Posted: Thu Feb 28, 2008 23:06
by Шум
Guest
Why are You a guest?
It is not clear you the person concerned, or not?
We can only guess.
Posted: Fri Feb 29, 2008 10:45
"There are more things in heaven and earth, Horatio, than are dreamed of our sages..." (William Shakespeare).
"It is useless to multiply entities without proper reason" (Occam's razor).
So all my life we hang out in between these two extremes...
One of the possible effects of these cylinders is as follows:
The potential difference (as you know, is the driving force) on both halves of the body (particularly the hands) can reach a value sufficient for detonation of the electric blasting cap. The higher the stress, the more the difference. A simple electrical circuit leads to equalization of the potential difference. The application of different electric potential of metals (e.g. copper and zinc) leads to a more rapid potential equalization. Usually this is accompanied by a shift from sympathetic to parasympathetic tone with associated feelings of drowsiness, heaviness in the limbs, warmth in the limbs. Rapid changes naturally lead to stronger sensations with the illusion of movement "energy".
Posted: Fri Feb 29, 2008 12:56
by Dimas
Andrei Patrushev
So you can just cross handles and all??Or is required to hold copper stick?
Posted: Fri Feb 29, 2008 14:28
Dimas wrote:Andrei Patrushev
You may have noticed that people under stress often hold hands in the castle, rubbing them, jerking myself off his fingers....
You can complete the circuit, as through the hands and through the legs (for example, through the foil). If we are talking about copper sticks, then it is necessary to take one or two hands.
Posted: Fri Feb 29, 2008 15:15
by Александр Лазарев
This is my post "These cylinders are the cylinders of the Pharaoh...". Forgot to log in.
Yes, quite right, in the manual, there are exercises polarity, for potential equalisation in the human body.
And yet, I think they somehow interact with the surrounding space, in particular, with the electromagnetic field of the Earth. For example, I can say quite clearly that the water that stood between the cylinders a few hours changing the taste, tastes like rainwater. In short, still a lot of questions... Ah, would know the truth about this now... )))
Posted: Sun Mar 02, 2008 11:53
Александр Лазарев wrote:This is my post "These cylinders are the cylinders of the Pharaoh...". Forgot to log in.
According to Akimov with his torsion fields, on the side surfaces of the long (length greater than the diameter) of the cylinders are positive (favourable to man) torsion fields, and the ends - on the contrary. If there in the instructions warning that the horse can not put the cylinder end faces on his knees?
Posted: Wed Mar 05, 2008 13:41
by Dimas
Withheld and ordered a supporting
If anything,I'll write about feelings,if anyone is interested.I want to try to keep the cylinders during operation with mindmachine...something tells me that this is unusual
Posted: Wed Mar 05, 2008 15:32
by Евгений Кош
Dimas wrote:Withheld and ordered a supporting
Dima, the main thing that the BOTTOM is not pulled out and the roof blown off
Posted: Thu Mar 06, 2008 19:04
by Саин
Should know that if the copper, the Egyptians were really given in large amounts, the metal zinc, they smelt could not, mankind has learned to do that only millennia later, in the 16th century BC And the cylinders in the hands of stone the pharaohs wrote at the beginning of last century, the great Champollion, decode ancient Egyptian hieroglyphics. Doctor of historical Sciences Vladimir Kulakov has confirmed that these rods cylinders for specialists no mystery do not represent the usual symbols of authority in Ancient, and particularly middle Kingdom. On some images the Egyptian authorities holds a long wand in the other - short. The closest analogues of the rods can serve as the scepter and Orb of the Russian tsars.
On the website of the cylinders of the wonderful properties of these rods are supported by an indication of the alleged unprecedented health of the ancient Egyptian pharaohs. So, Psammetik 1 reigned 51 years, Ramses the Great P - 67 years, Thutmose sh - 54. However, most Egyptian pharaohs ruled not so long. The next Psammetik P sat on the throne for just 6 years, Tutankhamun - 8, and the great reformer Akhenaton - 19 years. And, despite all the magical properties of cylinders, rulers of Ancient Egypt died a long time ago.
Posted: Thu Mar 06, 2008 21:45
Andrei Patrushev In the instructions there is only one exercise in which a copper cylinder placed under the coccyx parallel to the body, and zinc is placed perpendicular to each chakra. And to put the 7th chakra (the crown) is strictly forbidden. Probably the only exercise where I feel nothing.
Dimas I tried it, felt nothing special. There is a special connection there, but when I enter in the alpha without MM with the cylinders, my desires were all fulfilled, and very quickly. And maybe they executed without cylinders. Forum Transferring someone suggested that the cylinders are kind of amplifiers. It's more like the truth, because the cylinders fill and pumped energy channels, the same energy operate of the pyramid.
The man is a prism - it takes energy from the Universe and directs it for the implementation of their intentions. The cylinders are used to clean the energy system of the person (another important food and breathing exercises), and for the training and development of mental abilities is MM. That's why I use cylinders and mindmachines.
Posted: Thu Mar 06, 2008 21:47
Sain Allegedly, at that time, the cylinders were made of gold and silver. The Assumption Of Vladimir Kovtun.
Posted: Thu Mar 06, 2008 22:54
Саин wrote:Ought to know that if the copper, the Egyptians were really given in large amounts, the metal zinc, they smelt could not, mankind has learned to do that only millennia later, in the 16th century BC.
Not sure about Your data. Bronze is an alloy of copper and zinc was known before our era. In nature there is an ore from which to smelt bronze. Thus, its production had to be able to smelt copper and zinc individually....
Posted: Thu Mar 06, 2008 23:51
by Саин
Андрей Патрушев wrote:Саин wrote:Ought to know that if the copper, the Egyptians were really given in large amounts, the metal zinc, they smelt could not, mankind has learned to do that only millennia later, in the 16th century BC.
About 3500 BC in the middle East copper learned to extract from ore, it received a restoration with coal. Copper mines were in Ancient Egypt. It is known that the blocks for the famous pyramid of Cheops was treated with a copper tool.
By 3000 BC in India, Mesopotamia and Greece to produce a more solid bronze to copper to tin. The discovery of bronze could have happened accidentally, but its benefits compared with pure copper quickly brought the alloy in the first place. Thus began the "bronze age".
Posted: Fri Mar 07, 2008 9:19
by Фипыч_нью
Андрей Патрушев wrote:Not sure about Your data. Bronze is an alloy of copper and zinc was known before our era. In nature there is an ore from which to smelt bronze. Thus, its production had to be able to smelt copper and zinc individually....
Something me the forum does not remember.
In fact, the alloy of copper and zinc is brass.
Posted: Fri Mar 07, 2008 11:29
by Guest
IMHO! ( personally, subjectively)
insufficient energy channels has roots purely mental.
without removing these roots try to break through these channels than third-party - IMHO - a dangerous experiment.
Imagine that water-bearing pipe is something clogged.. clean it and feed the same water only under high pressure..
where to squeezed this extra power?
in the best case it is good that the system will survive..
But then the question arises namber two, and from where the garbage usralsa? he wormed? - so were the conditions for its creation ( mentally).
and if the garbage stayed there, so the conditions persist .
So is garbage and will be there again to accumulate.
It turns out - clean pipe of debris all the time, but do not remove the root cause of the accumulation of debris.
One side - effect will be.
on the other hand, looks like a purely symptomatic "treatment".
this is my personal IMHO.. in the here and now.
Posted: Fri Mar 07, 2008 11:31
by Евгений Кош
I wrote this.
as it is not entirely comfortable with the new forum system
