Page 1 of 1
Maybe someone knows anything about the device Cem Tech
Posted: Thu Oct 25, 2007 10:01
by Евгений Кош
Forumyane, can someone faced with this device?
can you give any feedback, opinions?
http://www.domzdor.ru/cemt2.htm
http://webdoska.msk.ru/m49431.html
How to me unknown supersauce "type influenza Viruses at an early stage are destroyed in 30 minutes,".. how it can be close to the truth?
Posted: Sat Oct 27, 2007 15:24
by .
Posted: Mon Dec 03, 2007 15:01
by Александр_
and I liked the device.
however the price !!!
but if it is true what you write about it, I would love to pouchavstvoval in testing.
Posted: Sat Mar 29, 2008 1:28
by Александр-Москва
The device is bought.Coming up is the fourth program lymphatic drainage. Completely stopped chuvstvovat weather, and there was a lightness.
Posted: Sun May 04, 2008 10:07
by Техас
I found some interesting information on this device
http://www.biofoton.ru/cem_tech/08.php
Re: Maybe someone knows something about the device Cem Tech
Posted: Fri Jun 13, 2008 21:30
by Карил
Вся правда о биорезонансной технологии wrote:we want to draw Your attention to another series of devices.
Some "scientists" claim that there is such a machine that is able to assume of Your body the frequency of the parasite and giving it back, kill the bastard! So, for example: Trichinella diagnosed range from 403,85 to 405,75 kHz but to kill her only frequency 404,5 kHz. So what "reads" such a device and that sends back? Draw your own conclusions!
Posted: Sat Jun 14, 2008 10:50
The device may be working, as it is written (in the sense of effect), but the description of it on the site, from the point of view of physiology of sense... Sometimes it happens...
Posted: Fri Jun 20, 2008 22:54
by ЛИЛИЯ-Р
Question to Andrew :messing with the chakras without spices it is dangerous and how to use mm and your drives - you can get energy charging all the chakras because it turns out the lack of energy and creates problems in the body
Posted: Fri Jun 20, 2008 22:57
by ЛИЛИЯ-Р
and another question if bad vision flashing glasses will not aggravate the situation of Alexander to you perhaps this question because you wear glasses.
Posted: Fri Jun 20, 2008 23:40
by Александр_
LILY-P
vision is fine.
I think mm vision is not affected, because we see colors with your eyes closed.
ie the lens is not focused on them.
Talk about everything
Posted: Sat May 29, 2010 10:40
by АлександрЗас
The device works is precisely tested on himself. But as a mystery. Bio-resonance is not likely. I tried to live blood exposed to UHF mode 10 min, bacilli do not die (just after the process of death was observed). But after using the unit the number of corpses increases if you apply the instructions say for three days (comparing the state of the blood before and during treatment). Emerged guess maybe he just charges the virus is a negative charge and that can not prikosatsya to the same negative sarazena the erythrocyte and starving. Generally works but how exactly is unclear.
Posted: Sat May 29, 2010 10:46
by АлександрЗас
By the way the price is normal if you consider the cost of medication Myself for six months on drugs spent more than half the cost of the device and the result was zero. With the device for 3 weeks cured severe allergies. The result of traditional medicine. The General deterioration of life indicators. So you decide to have or not have
Posted: Fri Jun 04, 2010 12:52
by АДЕПТ
Ýòîò ïðèáîð ÿ ðàçáèðàë. È íå òîëüêî ÿ. Ðåàëüíî îí - íå ðàáîòàåò. ÊÂ× åãî â ò ãåíåðàòîðîâ.í. "èçëó÷àòåëÿõ" - íåòó. Òàì ïðîñòî ðåçèñòîð çàëèòûé ãèïñîì. Ðåàëüíî - ëîõîòðîí.
Posted: Sun Jun 06, 2010 1:01
by Guest
АДЕПТ wrote:This device I understand. And not just me. Really he is not working. UHF generators in his so-called "emitters" - no. There's just a resistor in plaster casts. Really - Scam.
Unless the generators in the emitters? As I understand it - the generator on the unit itself. Unconvincing, master Adept.
