FOOD.VEGETARIANISM.
Everything that is not on the other topics can be discussed here. No ads.
Какого питания Вы предерживаетесь?
Веган
2
9%
Лактовегетарианец
0
No votes
Лактоововегетарианец
2
9%
Ем рыбу,но не ем мяса
4
17%
Ем все и не заморачиваюсь
15
65%
Total votes: 23
User avatar
Алексей C
Post by Алексей C » Sun May 03, 2009 21:01
Carilo, and you FS video I do not know where to download? And in the book refer to the video material :)
User avatar
Карил
Been thanked: 1 time
Post by Карил » Sun May 03, 2009 22:07
On the torrents.ru like there is in English.
Why do you need video? At least the first half of the book I read, the technique is learned perfectly and without video. There's nothing complicated. Press, press - op sharp pain, under my arm, especially noticeable - so found a spot.
User avatar
Алексей C
Post by Алексей C » Sun May 03, 2009 22:18
Карил wrote:why do you live? At least the first half of the book I read, the technique is learned perfectly and without video. There's nothing complicated. Press, press - op sharp pain, under my arm, especially noticeable - so found a spot.
Already figured out :)
User avatar
Алексей C
Post by Алексей C » Mon May 04, 2009 15:24
I've tried disc "Allocation of the astral body",the first track-Fokus 10, the body relaxed instantly and faster than alpha.I want to pass the entire course,listening through the day :)
User avatar
Карил
Post by Карил » Mon May 04, 2009 23:31
And I something do not like the sink... :( The program is good, but not attractive... I Havo afraid that's probably what it is.
Сергей_А
Post by Сергей_А » Tue May 05, 2009 2:04
Карил wrote:I Havo afraid that's probably what it is.
And what they fear?
User avatar
Карил
Post by Карил » Wed May 06, 2009 14:40
It is possible that "rollback" in the form of headaches harmful to health.
And when entering the OS, there is a sense of panic. So when oxygen starvation is the same, and yet at the same time and brain cells die. Perhaps when exit to OS, while in a relaxed state, the brain is not enough oxygen, because all are relaxed and the metabolism is slow. Hence the headache and panic...
ЖСЛ
Post by ЖСЛ » Wed May 06, 2009 17:55
Карил wrote:I Have a feeling that I have for two days snapped half of their problems. Plus I'm trying to follow the advice of Tolle. As a effect moments. The buzz from the parlor. :wink: That is of course weaker than five times, occasionally and not for long, but still nice. Feeling that earned. :)
Self-deception. These methods give only the appearance of the result. but it's nice, you can fool yourself - what do I move and get an Ego-thrill :)
when at least one touch on the root of the problem, not the tip of the iceberg - then you will understand. but these techniques do not eliminate the roots. And don't even show(to resolve - must see)
Карил wrote:... Kick and full kick...
I'm in shock... :roll:
In addition, in the mid-twentieth the weight of our physiologists (I. P. Razenkov, 1948) had discovered the fact of eating the man himself. It turned out that the stomach and human intestines recycled not only the food received from the outside, but the proteins secreted in the digestive tract from the internal environment of the body.
Moreover, surprisingly, such secreted in the stomach and intestines internal proteins were very much. The scientists made a comparative calculation of protein intake for the day and found that the ratio of eaten and endogenous (internal) proteins are about the same - 1:1 (G. K. Shlygin, 1997).
This means that the person eats in a day 100 grams of protein actually will get your 100g of animal protein (of himself). Total, get 200 grams of protein a day.
Ie if a vegan does not use animal protein, anyway, he will get a "piece of meat" in the form of 100g of their own endogenous animal proteins. It is provided by nature for just such occasions. Ie mother nature insures its foolish child, as a person and does not allow sharp deficiency of essential amino acids. If a person stops eating meat completely, he still continues to eat itself, meat.
Nonsense. A lot of essential to life items a person receives, feeding bacteria within the digestive tract. Each has its own pharmalogically factory that nutrition is more effective. The only one element of the vitamin B group - you can only get from meat. Critical for women otherwise vegetarians give birth to children with down syndrome.<
ЖСЛ
Post by ЖСЛ » Wed May 06, 2009 18:00
Карил wrote:it is Not excluded that "rollback" in the form of headaches harmful to health.
What current people will come up with to justify your fear and just do nothing :?
Post Reply
