Help to overcome fear!
Everything that is not on the other topics can be discussed here. No ads.
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Re: Help to overcome fear!
Post by мимоходом » Fri Jun 03, 2016 1:30
User avatar
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Fri Jun 03, 2016 1:46
Константинос wrote:So as I can't find it. Give a link, please. Of course I want to find a solution. I started according to the method of the Novel, of course the result is almost zero but still. And besides, I downloaded the book Goloshchapov, A.V., Anxiety, fear and panic attacks. Any opinions?
Well, what else could happen - if you simulate, then the result will be only fun...
Константинос
Has thanked: 5 times
Been thanked: 2 times
Post by Константинос » Fri Jun 03, 2016 1:55
K-13 So I do not imitate. Maybe I just don't quite fully understand the technique. A little but the result is still there and this is shocking. I found this viewtopic.php?t=933 What do you say? Is it worth it to use together with your method?
Вадимас
Post by Вадимас » Fri Jun 17, 2016 16:17
A douche may help.
Post Reply
