Basic session
Post Reply
Has thanked: 134 times
Been thanked: 556 times
Contact:
Basic session
Post by Андрей Патрушев » Sat Mar 12, 2016 10:26
https://yadi.sk/d/tYKkaFCmoKv9E
Sometimes (if you really try) you can overwrite the data on the flash drive Navigator, or the flash may fail.
Алексей Крячко__
Been thanked: 17 times
Re: Basic session
Post by Алексей Крячко__ » Tue Jun 12, 2018 18:40
something is not downloaded at that link.
Given the fact that the session is updated I took them all to the archive. After unpacking the archive and placed the SES folder to the SD card of the device. And there was this session where the last letters of the modifier waveform (r - rectangle, b - bell, as - asymmetric sine, s is sine).
https://yadi.sk/d/agjbmOF73XnPqW
the need for such a store and put the session in a separate folder SES, the content of which is available in the device when you select Workout-> Library, in the fact that there is a need for someone to edit them for themselves (for example, decrease or increase any parameter, volume/brightness, for example to remove noise, etc.)
Post Reply
