[newsletter]Workshop on Mind-Machines (first wave)
Какае варианты наиболее интересны
Poll ended at Thu Feb 21, 2013 0:35
Базовый вариант
3
8%
Альтернативный вариант
16
42%
Базовый формат
5
13%
Расширенный формат
14
37%
Свой вариант
0
No votes
Total votes: 38
User avatar
Has thanked: 31 times
Been thanked: 129 times
Contact:
Re: [mailing list]Workshop on Mind-Machines
Post by к-13 » Sun Jun 16, 2013 23:11
Мадамзолото wrote:Good evening. Accidentally found your website and learned here about mm. very interested. Found this topic, and here to listen to tracks on 1 page reason? :?
And You continue to read - with the end of each stage links to the files were closed. They are only available to those who participate. Participation is free and MM does not require
Умная и красивая wrote:I Agree with you,a lot of information was vague.For this reason, lost interest in this topic.
And You what agree? The first step You personally, I sent in a personal. But if You nedosluhavshy their "lost interest", then You and MM will not help - no one is there to buy it only to make it through the week he slept somewhere on a shelf, not forced.
User avatar
Мадамзолото
Post by Мадамзолото » Sun Jun 16, 2013 23:54
[quote="LILY-R"] in the meantime, you they do not understand, as many simply came nose to move, to show yourself))) Who in the subject he knows about it.[/quote
don't want to answer ignore. If any one of these many will be it is good, but it's the choice of everyone.
User avatar
Мадамзолото
Post by Мадамзолото » Mon Jun 17, 2013 18:24
к-13 wrote: And You continue to read - with the end of each stage links to the files were closed. They are only available to those who participate. Participation is free and MM does not require
K-13 sorry :o apparently did not read :oops: that the links are closed, and how to participate, you still get to participate?
Really want to work out, and I want to buy MM, but this issue I'm studying.
User avatar
Contact:
Post by к-13 » Tue Jun 18, 2013 0:51
I would there to say about the free part, if it is impossible)))
User avatar
ЗОМБИ
Been thanked: 2 times
Post by ЗОМБИ » Tue Jun 18, 2013 22:09
the Most interesting option, when activated at the same time not inconsistent with the anchors - you can get new experience and the specific condition, to obtain which otherwise is extremely difficult.
For example when simultaneous activation of alpha-anchors and anchors from the exercise on balance, it is quite a powerful condition for learning is the present "state of genius," when everything is clear and memory is capable of feats)))
Or the anchor is installed during the viewing of Comedy and the same sync anchor for many it is a real feeling of euphoria comparable to swagger against the background of intoxication. And the anchor for falling asleep at the same time with the alpha anchor is likely to put the experimenter in a state between sleep and wakefulness, where is very easy to fall into a lucid dream.
This, IMHO, it was necessary to put to people longed :)
I have all the anchors mixed up... all scored before the holiday, which starts on Monday 24th of June, took a month... plans to complete training without disruption or tears... as I understand it I have everything, methods and tools... blunted I ripped off the bat and not finish the Delta... it means to them and need to get... and move :)
Understand another point – the anchor should not be requiring continuous, ie... for example, I put the laughter tickling the language of heaven – it is not very convenient... if you do such an anchor it is only specifically, for example, to transfer the SMR as walking or running, activating during the action of these anchors put on the state of the SMR from mindmachine... I think so, not saying anything...
Another tried to fill the same alpha anchor before falling asleep without MM... type according to the method of Silva... damn, he mingled with the non-Delta... now this sucks... now I listen to the alpha session, turn on the anchor to fill, and he's half asleep... the problem is that new is not noticeable kinesthetic anchors can not think of so many... and they are my best work... for example, to keep the image of the alpha anchor in the time of anger is much more difficult than to fold figurku...
Synchroa-anchor of the alphabet has become a sort of cast – ie I tried to play several times in the alphabet for the first time at the Endorphins in the head, heaviness and pressure synchronization is almost gone, and if it appears that heavy for some... but now these feelings are appear spontaneously or when attention to frontal lobe gray pieces of fat... while if you put alpha and synchro anchor-anchor, that turns normal alphabetical sense... from a pure synchro-anchors it is smeared, but there is no gravity as in the game of alphabet... some garbage...
Another bonus... began to happen flash visualization... especially strange to catch them from waking... switching is a dull movie in my head... the so-called cinematography breaks out :) and during the slumber short is good short film pieces of fat... ie look in the case and not just pictures... that is very helpful :)
What else?.... I want to cram into the month of vacation the maximum that you can squeeze out of yourself... maybe what the specifics will be for free graphics??? want OS and euphoria...
by the way, I have a kinesthetic flashbacks from tabletku ie... when the music is catchy I start to run down my spine at the back of my head and the whole body in the end... I have them too from the very beginning of the training trying to anchor to catch – figvam – as soon as the anchor is trying to fill, they cease, and if nothing is done, then run until you let go of the music... such garbage :)
assuming the first week, do alpha, then a week sync, next week beta and maybe sync the last week to try the Delta...
during synchronization, you can probably session Left brain and right brain from the Navigator to alternate...
A novel, maybe I will throw down the Express version of the training... maybe we'll figure out how to push not pihuamo in one month...<
User avatar
Contact:
Post by к-13 » Wed Jun 19, 2013 0:58
Damn, I forgot the newsletter on the forum to spread :evil:
ЗОМБИ wrote:I HAVE all the anchors mixed up...
It happens :? . If being anchored in very deep States, it turns out the imprint is a steady anchor, it is virtually indelible (that's why I batter that you need to master the form of sessions of each phase before proceeding to the anchoring, and use strong natural state and emotions). Conventional anchors work only 10 times, if not always fill. There is another way to make a positive anchoring more persistent is to demonstrate in brain that preserving some concrete anchors for him carries a very big favor (examples and with the help of visualization, for example - it often works much better than the constant filling setiausaha keys, although it is not completely eliminated - nothing is eternal under the Moon, and even more that relies on the stability of the mind :lol:)
ЗОМБИ wrote:I was trying to fill the same alpha anchor before falling asleep without MM... type according to the method of Silva... damn, he mingled with the non-Delta... now this sucks... now I listen to the alpha session, turn on the anchor to fill, and he half asleep...
Superimposed... In NLP in General there are different techniques when multiple States consciously put to one anchor. If needed, collapsing it and refill.
ЗОМБИ wrote:Understand another point – the anchor should not be requiring continuous, ie... for example, I put the laughter tickling the language of heaven – it is not very convenient... if you do such an anchor it is only specifically, for example, to transfer the SMR as walking or running, activating during the action of these anchors put on the state of the SMR from mindmachine... I think so, not saying anything...
Let me tell you a little secret - how did you know it is, but if anyone understands differently, it differently, but also correctly. Anchor - is the patrimony of the brain, he decides, so be it (not like you're trying to sing and want to think, and exactly as in really think).
ЗОМБИ wrote:the problem is that new is not noticeable kinesthetic anchors can not think of so many... and they are my best work... for example, to keep the image of the alpha anchor in the time of anger is much more difficult than to fold figurku...
Yes, some of the fingers 4 dozen of them (and this is on every hand, and many easily can be simultaneously activated). Touching parts of the body (does all the space is practically unlimited), breathing (sharp intake of breath, for example, or a very slow exhale is also quite a good anchor), tension of individual muscles or groups... Is that you just head to think, not want)))
ЗОМБИ wrote:Synchroa-anchor of the alphabet has become a sort of cast – ie I tried to play several times in the alphabet for the first time at the Endorphins in the head, heaviness and pressure synchronization is almost gone, and if it appears that heavy for some... but now these feelings are appear spontaneously or when attention to frontal lobe gray pieces of fat... while if you put alpha and synchro anchor-anchor, that turns normal alphabetical sense... from a pure synchro-anchors it is smeared, but there is no gravity as in the game of alphabet... some garbage...
So, too, overlapped with something... You're in a hurry, can see himself overtake)))
ЗОМБИ wrote:Another bonus... began to happen flash visualization... especially strange to catch them from waking... switching is a dull movie in my head... the so-called cinematography breaks out :) and during the slumber short is good short film pieces of fat... ie look in the case and not just pictures... that is very helpful :)
I'm often so short answer where I don't have enough data - sketches to draw customers, for example, or the sequence of steps in the manufacture specify. As I understand it, sooner or later, this contact with the subconscious we all should open.
ЗОМБИ wrote:What else?.... I want to cram into the month of vacation the maximum that you can squeeze out of yourself... maybe what the specifics will be for free graphics??? want OS and euphoria...
To tell you the carousel for first and grimstalker with glycine for the second?)))
ЗОМБИ wrote:by the way, I have a kinesthetic flashbacks from tabletku... ie. when the music is catchy I start to run down my spine at the back of my head and the whole body in the end... I have them too from the very beginning of the training trying to anchor to catch – figvam – as soon as the anchor is trying to fill, they cease, and if nothing is done, then run until you let go of the music... such garbage :)
Goosebumps, and I often have, especially when trying to quickly with the chakras to work (alternately colored vortices on the second two represent in the right places) or with the flow of work. I have always believed that it is the opinion of the body. Why should it be anchored.
ЗОМБИ wrote:assuming the first week, do alpha
Alpha you can do first thing in the morning, regardless of what the day was going to do.
ЗОМБИ wrote: next week sync, next week beta and maybe sync the last week to try the Delta...
From personal experience I know that the beta and the sync is quite normal train together (break three hours and order, and better in the second half of the day).
ЗОМБИ wrote:During synchronization, you can probably session Left brain and right brain from the Navigator to alternate...
Yes, just put each on a separate anchor (and focus on the fact that it is an anchor on the activity of the hemisphere), then you can try to simultaneously clamp and to the balancing (assuming both are installed properly).
ЗОМБИ wrote:a novel, maybe I will throw down the Express version of the training... maybe we'll figure out how to push not pihuamo in one month...
I imagine something such experiments do not risk to put, and then you're Guinea pig is called. Theoretically at a certain level of experience and the week to meet, but the risk somewhere nakosyachit and generally screw up the entire course - the same diffuse inhibition to catch after attempts to fill the anchor, then it will be very difficult to quickly return to the previous rate of training. I know it myself.
Easier normal pass all the stages, and then only work on the support and donporneone anchors... I 20тиминутный a file with all the frequencies at once at a time, with a normal basis it is sufficient once or twice a week to listen to (just the player) and pass by the main state - changes the type of modulation and type of signal you want the anchor (even if it is weakened), get the necessary condition, deepen and fill - and so for the most part anchors. Remain specific, but they can be in life if you wish to fill (and Wasps to use). All! Anchors is much easier - all the delights of the mind-machine is always and everywhere with us.<
User avatar
ЗОМБИ
Post by ЗОМБИ » Wed Jun 19, 2013 19:53
к-13 wrote:Goosebumps, and I often have, especially when trying to quickly with the chakras to work (alternately colored vortices on the second two represent in the right places) or with the flow of work. I have always believed that it is the opinion of the body. Why should it be anchored.
to mix with the alpha anchor and grab the euphoria is not as drunk :)
(by the way, where's the booze euphoria? high on the satiety state of the pull, if you swallow of beer with fish -- the type we eat-ate already tired, to sleep like, only to pee often want :lol: ... after more strong generally bullish buzz... blue it's a depressant... the whole country is sitting depressants)
the rest... will come up with generally all new anchors is better right now will constitute the initial list of the most convenient and not noticeable...
I still think it may be better (more efficient) to do so:
1. using any funds included in the state, set the anchor H1, filled to the current maximum.
2. then "pour" the condition of the anchor in the H2, by serial play H1->H2.
3. Mixing anchors are made exclusively from a second room e.g. ALPHA2+Синхро2=alpha-Synchro condition. The first room is left only for mono-States.
theoretical question: in reality (not only my case, and the average temperature in the hospital) does paragraph 2, if Yes then will not be affected sequential activation of anchors anchor H1, if H2 is already screw up impurities from the mixed-up condition in which it was used...
item 2: do not use transfusion status from H1 to H2, and doing so -- before use (at the beginning of the session, for example) funds, which were obtained as H1 H1 to activate, then use the tool itself to hold the state without deduction of the anchor, then after a while when you feel the peak state is reached again, activate H1 and after a very short period H2... get two related anchors -- one clean, the other for mixing... just probably after the activation of H2 for the remaining time of the session cannot be activated H1-otherwise he jagadisa impurities...<
User avatar
Contact:
Post by к-13 » Thu Jun 20, 2013 0:08
ЗОМБИ wrote:to mix with the alpha anchor and grab the euphoria is not as drunk :)
6 Aug will be 5 years since I completely abandoned the use of all that has degrees, so I very vaguely remember that there, Yes. From personal experience any euphoria don't remember - there were two aggregate state - or RTI (a La corrugated hose - "well, you all go to sleep"), or T-2000("where to find more of John Connor?").
ЗОМБИ wrote:I still think it may be better (more efficient) to do so:
2. then "pour" the condition of the anchor H2 by sequential playback H1->H2.
That I'm sure have advised already. The rest look at the last response after the third quote.
User avatar
ЗОМБИ
Post by ЗОМБИ » Thu Jun 20, 2013 7:59
I realized... just now realized how to use it in practice :?
yesterday came up with a bunch of anchors in my mouth... except that I still do not understand (and to check damage(mix) anchors not hunting) behave located near the surface of the body -- for example, the left cheek and right cheek (although there is just a different nerve innervation)... or point to the sky... the idea is there innervation from one nerve is and it is not clear whether the mixed state, if the anchors on a single nerve sitting...
in the mouth anchor, I put the sensation of the passage of the pulse through the nerves, ie, very mild pain...
and with classic mudras (just a few pieces)... surely it wouldn't be criminal (for the practice of yoga, which I still get -- I mean use wise for thin games streaming during all practices with the body) if some of them I will obosu alpha... I think even for the benefit of practice... let's see...
but with John Connor now not-extinct :wink:
СветланаС
Has thanked: 1 time
Post by СветланаС » Fri Sep 27, 2013 19:58
Very sorry that no more training. I would like to know how to use sessions for learning a foreign language, teaching poetry, reading smart books. Maybe you could pay attention to this?
User avatar
Contact:
Post by к-13 » Fri Sep 27, 2013 22:59
СветланаС wrote:Very sorry that no more training.
:shock: How?!!! :cry:
Climb onto the step above to navigate through the forum - this entire section is dedicated to one large continuous workshop with MM (without MM), on the upgraded program only take and do... You got the files the first stage, but for some reason again abandoned the practice... Resume classes, get the results, share your achievements in the right topic for You and the workshop continues: who works, moving on, who is involved for show - the more adaptation takes place not... I did neck to pull not going. Why would I waste my life on those who do not need it? :?
Take the example of Ivan (bofara) - one barely speaks Russian, in the workshop joined one of the last, and has proceeded far ahead - already the penultimate stage of storming...
СветланаС wrote:I would Like to know how to use sessions for learning a foreign language, teaching poetry, reading smart books. Maybe you could pay attention to this?
And so I'm paying attention to this matter (almost all my free time), only a few of those who really need it...
Learning a foreign language and the rote learning of rhymes is held in the condition of high productivity (in the workshop we anchor on it put in the fourth step is balancing and synchronization - then it was the second, but many have not mastered immediately these loads).
Read intelligent books best is in alpha (the first two steps here and there), when the brain is open to new information, and the filters of stereotypes and judgment blunted - it is easier to understand and harder to go astray - and what we understand, we are already very hard to forget...
Mind-machine is "crutches" (Walker, trainer) - only to learn to "go" further in life you have without them - and books to read and poems to teach, and sleep, and relax, and invigorated... Only it will have to work hard (as in the cartoon about an ostrich and a vulture better day to lose, then for five minutes to fly).<
Locked
