I should add that Hephaestus is not only a home appliance, it has been successfully used in clinics around the world.
Israel has developed and successfully applied methodology for the treatment of alopecia (hair loss) is a combination of burdock oil and magnetophoresis.
In Yekaterinburg developed and successfully applied the method of treatment periodontal disease is a combination of a special antibacterial gel and magnetophoresis.
In Yekaterinburg for many years until recently (closed as a result of "reorganization"
The efficiency of Hephaestus, compared to other devices electro-magnetic therapy, is determined by the particular pulse shape and constant (for a special program, through the feedback sensor) changing parameters of the pulsed electromagnetic field slozhnosochlenennogo that makes the body get used to this kind of impact.
Usually the body quickly (over 1-2 sessions) to get used to the impact of any electromagnetic fields (even if they change by a simple algorithm) and simply ceases to respond to them. This explains the almost magical effects of the first sessions of most devices, which is used for treatment with magnetic or electromagnetic field, and the rapid decline in the performance in subsequent sessions.
Contraindications:
severe hypotension, systemic blood diseases, anticoagulation, tuberculosis, acute suppurative process of any localization, toxicity and high temperature reaction, Basedow's disease, diencephalic syndrome of early post-infarction period, severe coronary heart disease, the presence of magnetic fields magnetic foreign bodies, uncompensated glaucoma.
CLINICAL APPLICATION: treatment of diseases of the vascular system (lymphedema, lymphatic-venous insufficiency, obliterative endarteritis and obliterating atherosclerosis), diseases of musculoskeletal apparatus (arthritis, of artrose-arthritis, osteochondrosis, post-traumatic States), childhood infections (rhinitis, laryngotracheitis, bronchitis), diseases of the peripheral nervous system (neuritis, radiculitis, of lumboischalgia), diseases of the skin (keratoderma, lichen of various etiologies, neurodermatosis, pruritus, urticaria, acne), diseases of the teeth and oral cavity, gynecological diseases.
The use of psychophysiology for the treatment of stress, recovery after a big physical and mental stress, preventing fatigue in the complex rehabilitation of drug addicts and alcohol dependent people.<
