Structured water
новый Искатель
Re: Structured water
Post by новый Искатель » Mon Jan 18, 2016 15:33
attention ! anyone who has instruments ORP measurement (Redox, EMF, aka the DSI-2) the capacity of the water request to make measurements of water potential from open sources, before any filtering
now (and always at the baptism) on the earth there is a powerful flow SVERKAJUSHEGO radiation, and all the water changes properties. the phenomenon is purely scientific, and the religion here is just "stuck" to the occasion. The earth 2 times a year included in such flow - on Epiphany, and on St. John the Baptist.
if anyone has the devices measure water from boreholes, wells, tap. is there any abnormal changes.
measure TO Emeralds who have it
the values can be here to throw
+ let time measurements
read more about what is actually happening in Baptism
http://vahe-zdorovye.ru/novosti/kreshhenie
Слайдер
Has thanked: 10 times
Been thanked: 24 times
Post by Слайдер » Mon Jan 18, 2016 18:12
Today had a dream that I was standing at the hole in the night and wanna fall - but still not solved. That tomorrow is the Baptism, I did, and forgot. And that it is better to swim at night even never knew.
Reading the material on your link much thought. Thank you.
User avatar
Сергей Ивлев
Has thanked: 109 times
Been thanked: 433 times
Post by Сергей Ивлев » Thu Jan 21, 2016 7:02
I can't think of the name of the new water, which is obtained (see topic below). It surface tension is twice less, ORP and alkalinity is governed by the nozzle during cavitation, the composition of the cluster too, crazy extraction, the properties do not change with boiling and distillation.
It is obtained by many household ways. Stay tuned. From 7 December, began an experiment on the growth of muscle strength without exercise by water. Already squat 55 kg many times, will show, when you get to 100kg.
Ways shake, kick, spin, weak electrification and Wicca information through a multimedia device, flash drive,
the whole thing in 40 different attachments.
Эксперт
Has thanked: 3 times
Been thanked: 4 times
Post by Эксперт » Fri Feb 19, 2016 17:04
As if programmed water?
Take a jar of water, put in a quiet room where nobody goes. Turn next to the attitude Sytina for a week. And then drink. :?
User avatar
кирагуиту
Post by кирагуиту » Wed Mar 16, 2016 18:59
Сергей Ивлев wrote:I can't think of the name of the new water, which is obtained (see topic below). It surface tension is twice less, ORP and alkalinity is governed by the nozzle during cavitation, the composition of the cluster too, crazy extraction, the properties do not change with boiling and distillation.
Dear, sorry for stuffing, but you are here on the forum as if talking to myself. You guys are weird. :?
User avatar
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Tue May 17, 2016 18:39
this book:
mentioned?
IMHO - the best I've seen. on the topic of water watching for about 6 years. here took BSL
User avatar
Post by Шалтай Балтай » Wed May 18, 2016 20:24
in the book - part 2
1st - theoretical, well and clearly written, with links to the research (very many names, and Schauberger, and slim and Emoto - and a lot more who)
2nd - practical that and how exactly you need to do to get the "right" water.
новый Искатель
Post by новый Искатель » Fri Nov 04, 2016 15:29
osmosis, the activator Izumrud-si, ph corrector (new), 2 post-filter
новый Искатель
manual ph corrector
http://ikar.udm.ru/files/pdf/ph-correct.pdf
Specifications
 The maximum capacity, l/day 50
 Minimum analysis of the water from the tank, liters/day 2
 Change ORP (∆ORP), mV** -100 -300...
 Change in pH (∆pH) 1...3
 Consumed El. power (max) W 7
 Resource replacement of the anode, l*** 2000-10000
 Net weight (without water), kg 0,7
 Package dimensions (W x h x d) mm 100×100×400
новый Искатель
Post by новый Искатель » Thu Dec 08, 2016 3:35
a visual video demonstration of activation of water
see the difference in ductility of water (surface tension) and structure
faucet installation osmosis + Izumrud-si + activator
in one case, just osmosis emerald si socket pull
in another case, a socket is inserted, activation is enabled
prior to filming in both cases was done 5 min exercising
just osmosis off from the outlet of emerald C and pH corrector
http://iskateli.info/showthread.php?t=370&page=464
User avatar
Post by Шалтай Балтай » Thu Dec 08, 2016 10:35
teach math part, long-term consumption of water from under activateapp (alkaline low ORP) leads to cancer zobolevany.
this is done in courses.
with the current level of awareness the population such devices can cause more harm than good, alas :?
in nature there are useful and harmful substances, good and bad are only dose
PS
the is aktivatorov two pieces. A good thing, but without mozgoff - threat.
новый Искатель
Post by новый Искатель » Thu Dec 08, 2016 14:04
where to learn the math part ? you can link to an authoritative source
I think your comment on the degree of awareness is the same as the awareness of the population
2009 drink with this water that while cancer is not. need to wait right ?
there is a drug dose is a preventive, if you drink drug as a prophylactic, Yes which can then be
don't need to exceed just value
Шалтай Балтай wrote:teach math part, long-term consumption of water from under activateapp (alkaline low ORP) leads to cancer zobolevany.
PS
User avatar
Post by Шалтай Балтай » Mon Dec 12, 2016 12:44
Good zdraveska, a new Seeker
новый Искатель wrote:where to teach the math portion ? you can link to an authoritative source
Шалтай Балтай wrote:this book:
mentioned?
Runet Sachs. better not to look. hidden tallerova.
новый Искатель wrote:since 2009 drink this water
the same cool. I wrote above
Шалтай Балтай wrote:on the topic of water watching for about 6 years. here took BSL
новый Искатель wrote:is a medicinal dose and have a preventive, if you drink drug as a prophylactic, Yes which can then be
az
in nature harmful or helpful
harmful and useful - only dose.
to comply with the doses need even used the minimum level of osoznanno, to say that a rush with this deficiency ... the trouble, in short.
Вале
Post by Вале » Tue Feb 14, 2017 13:54
Hi all, some years I wasn't here
I then stopped at the Druzyaka Volkov, the Swamps, but not regularly –vinegar podkalivat, dead and rarely drink water.
But melt water to drink regularly!!!?
And now look what started to get old, damn it!- wrinkles, dry skin and throat dryness...
It seems zachislili body!
I think I can start drinking the living water?
Even Mahatma in Agni yoga it is said that the soda right panacea!(thanks to Mahatma for Mahatma Lenin and Stalin)
With Levashov long understood – in short said that it is necessary to alternate -week Dead week Alive
And you have that? I am interested in who regularly uses "Living water" as it affects you health?
And about the wands, made- (copper-goldr.,zinc hotcocoa+small magnet) –that then after 15minutes the heart already feels – what is it?
The use of wands?
Cat health is affected, because it took quite a few years - we can conclude!
хажакян
Post by хажакян » Fri Mar 03, 2017 15:47
PS
I have a source (spring), PH of 7.3 to 7.5 , ORP from about 60-100, drink it from 2012.Water without filter and low salinity up to 550 ТDC .It can also hurt with constant use? :shock: Mother in law within 3 months of drinking this water went through all the joints.And I like the hair darkened.
User avatar
Post by Шалтай Балтай » Sat Mar 04, 2017 16:21
хажакян wrote:I Have a source (the spring),
here is a direct spring? and personally poliziani?
well soon... IMHO
хажакян wrote:It also can harm with constant use? :shock:
it is unlikely :-)
хажакян wrote:ORP from about 60-100
ORP under activators are much lower: -100...-200, in different ways, At BSL, for example -400
хажакян
Post by хажакян » Sat Mar 04, 2017 17:55
Шалтай Балтай wrote:here is a direct spring? and personally poliziani?
well soon... IMHO
This spring lived has no outlet to the surface.Photo of a spring tube structure is available on the website.She lived located at a depth of 10 meters. It was perforated at a depth of 9.6 meters plastic tube of 40 mm with special seal from perched. The water rose is currently up to level 5 meters from the surface Then a small 60 watt pump, it is fed out.Iron in water almost none. The debit of 1.5 liters per minute.
User avatar
Post by Шалтай Балтай » Sat Mar 04, 2017 22:52
huracan
have shareportal admins as spam
хажакян
Post by хажакян » Sat Mar 04, 2017 23:34
Why? I believe that my experience in finding veins will be interesting! And it can be repeated! Or here is considered only the information that increases sales of the various settings on the structuring of water? I even have a device information exposed to water:https://yadi.sk/i/jXtubC2HypSWT
And that you did personally? Just sell other people's devices? Can share your successes?
User avatar
Has thanked: 1 time
Been thanked: 182 times
Post by Андрей Кабанков » Sun Mar 05, 2017 10:16
хажакян wrote:And it can be repeated!
To Yandex money send 1000 rubles
and within days after notification letter
You will receive detailed technical documentation ...
Ready rig You can get in exchange for a donation in the amount of 25 000 rubles
хажакян
Post by хажакян » Sun Mar 05, 2017 11:17
On the website there is a link on how to look for water. I tried it and it worked for me.In addition, you can ask questions, I will answer.I did not pay. Or are you already used to pay for everything, and normal relations do not you know?
Дао
Post by Дао » Mon Mar 27, 2017 0:54
Hello!
No one tried to structure water is the Chinese miracle?
http://www.tyrmalin.ru/collection/izdel ... aniya-vody
Бывший Регент
Post by Бывший Регент » Sun Aug 13, 2017 22:08
Scientists - light. Ignorance, apparently, business...
In the electrolysis are formed hlororganicheskih connection. They are dangerous themselves and upon decomposition form a lot of "Goodies".
And most importantly, what do you this negative ORP? The acidity in the stomach to reduce? Why?
The ozonator will buy and you will be happy. He microorganic destroys impurities and precipitates. Just to let settle or filter.
Костя
Structured water
Post by Костя » Sat Aug 10, 2019 10:17
Михаил_ wrote: ↑
Mon Feb 20, 2012 0:16
tub apparently though too briefly the message believed - shaped chain is mixed, protechnik bath appears in the line below :) sorry, got mixed up.
However, the recommendation remains that the dual-action, proven very positive.
ORP becomes +300 -150 to approximately the volume of a standard bath.
Take with very hot water, about 15 minutes kdeedu slightly to a more tolerable and 40 minutes later - sleeping. Because the body needs the resource to recover. There is in addition the PPR trigger own properties ASD, through the pores of the skin are hitting all the alien in the body more efficiently than through the digestive tract. Well, or maybe not efficiently, but differently.
Just keep in mind that later a deep state of relaxation no less than the hours provided. You can only lie and then slowly and quietly :) But then comes the influx of strength and renewal.
Michael, good.
Do I understand correctly that the whole procedure of bathing lasts 55-60 minutes?
Post Reply
