Good afternoon.
The Help file for the program to create sessions for the Navigator said,
slow modulation of this signal in the form of a triangle with the apex at 0.37 of the period.
Two questions to the developers and maybe to Andrei Patrushev:
* What is the presence of peaks in 0.37 period ?
* Please tell me the vertex for the asymmetric sine ?
Thank you for your work.
Top asymmetric sine
- Разработчик
- Been thanked: 17 times
Re: Top asymmetric sine
In asymmetric sine of the maximum is shifted to a value of 0.63 (1-1/e=0.6321205588286) on the x-axis. modulation asymmetric sine is used only the first half period.
As for vertices from a triangular profile, a slow modulation with a maximum of 0.37 in the period, the 0.37 is the rounded value of this values :
1/e=0.3678794411714
1/e=0.3678794411714
- Has thanked: 134 times
- Been thanked: 556 times
- Contact:
Alex, don't confuse people. In asymmetric sine high as in the slow modulation, shifted to a value of 0.37 on the X-axis from beginning, respectively, of 0.63 from the end is very important.Алексей Крячко__ wrote:In asymmetric sine of the maximum is shifted to a value of 0.63
- Разработчик
here is the beginning of there (0 for X) was in the middle of the period. Attached picture of specification
https://yadi.sk/i/TaxX2Ryc3S3GeW
And Yes, 0.37 from the beginning of the period.
You do not have the required permissions to view the files attached to this post.
Last edited by Алексей Крячко__ on Fri Feb 02, 2018 19:58, edited 2 times in total.
- Contact:
Alexey Kryachko__
Well, it should be easier to explain that few of the users understands that there is the beginning not at the beginning...
