points for "Navigator" with white LEDs
Mind machine Navigator. Support. New session. Software updates.
Post Reply
Алексей Крячко__
Been thanked: 17 times
Post by Алексей Крячко__ » Thu May 02, 2013 21:10
wanted to raise this topic. Because the questions and comments about this was. Actually there are three version points for Pathfinder, but there is an option to release in the same constructive and glasses with led lights with a white glow. The same LEDs in the same form factor, but all three crystals give white light.
Since the device has the ability to put to fill between the flashes "pause", regardless of how the session was programmed by the author, we have the option of working with "white" points even for the sessions in which the filling is instead a "pause" switch to a different color.
I personally tried white points, though photosonix. I liked the white light gives very different images, more vivid.
The device comes with colored glasses, and glasses with white LEDs can be purchased separately.
Who is behind this and who would be interested ?
User avatar
ЗОМБИ
Been thanked: 2 times
Re: points for "Navigator" with white LEDs
Post by ЗОМБИ » Thu May 02, 2013 21:21
the same LEDs in the same form factor, but all three crystals give white light.
i.e. each crystal shines white?
if Yes, then I am for...
Алексей Крячко__
Post by Алексей Крячко__ » Thu May 02, 2013 21:28
so. alteration plat is not required, found these LEDs which will be mounted instead of the tricolor.
I think the samples will be available in may.
User avatar
ЗОМБИ
Post by ЗОМБИ » Thu May 02, 2013 21:32
Alexey Kryachko__
NICE
waiting for :D
Алексей Крячко__
Post by Алексей Крячко__ » Thu May 23, 2013 3:31
So, points began with a white glow.
Structurally all the same, except use fasteners of white color (in colored glasses he's black).
LEDs with white light have a yellow filter, it can be seen in the photo.
but Shine white light
Concerning the settings.
Most sessions will proigryvaetsya normal and with these glasses, regardless of the programmed sessions color. The flashes will always be white. However, in some sessions, instead of turning off the light can transition to the other color, in this case, the flashing will not be felt. Therefore, to work with these glasses it is better to go to the menu
"Training ->additional modes-> color sessions "
and set the option to "Zap." (filling in the interval between the flashes of primary color), the value [pause]
Meaning the light between the flashes is always off, regardless of what is programmed in the session.
Accordingly, when you use colored glasses the option to "Zap." it is better to return to [the author].
User avatar
Has thanked: 1 time
Been thanked: 182 times
Contact:
Post by Андрей Кабанков » Thu May 23, 2013 9:09
Price points 5000 rubles.
Has thanked: 134 times
Been thanked: 556 times
Contact:
Post by Андрей Патрушев » Wed Jun 19, 2013 18:41
Well, here! :ay And I'm purple now! 8)
Алексей Крячко__
Post by Алексей Крячко__ » Fri Jun 21, 2013 0:06
Андрей Патрушев wrote:Well, here! :ay And I'm purple now! 8)
purple is almost blue. Blue vision weaker need more brightness and now to find such LEDs is the question...
White includes the entire spectrum, when the shimmers gives a very strong arkoe images, which is not with colored glasses.
I feel judge
User avatar
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Jun 21, 2013 0:19
Yes, I would and from yellow-orange too, not refused)))
HanSolo
Post by HanSolo » Mon Dec 23, 2013 18:16
Please lay out a video of the colored and white points in different modes.
And yet, these goggles are compatible with InnerPulse?
User avatar
Post by ЛИЛИЯ-Р » Mon Dec 23, 2013 18:28
HanSolo wrote:please Lay out video of the colored and white points in different modes.
Not compatible.
User avatar
Экко
Has thanked: 2 times
Been thanked: 4 times
Contact:
Post by Экко » Wed May 27, 2015 18:06
What is the advantage of 6 channel points is the "old" one - or two-channel?
Contact:
Post by Андрей Патрушев » Wed May 27, 2015 18:08
Алексей Крячко__ wrote:White encompasses the entire spectrum, when the shimmers gives a very strong arkoe images, which is not with colored glasses. I feel judge
It also gives red, the rest just flickering. :?
Contact:
Post by Андрей Патрушев » Wed May 27, 2015 18:23
Экко wrote:what is the advantage of 6 channel points is the "old" one - or two-channel?
The ability to more accurately work with the hemispheres and areas of the brain. For example, studies of oculomotor function, upper hemisphere is associated with visual perception, the middle line with audio, lower hemisphere with kinesthetic. For example, in hypnosis, in the visual cortex is dominated by beta waves in the middle part (there's also the area responsible for the audio-perception and memory) - alpha in the frontal lobes of the Committee... furthermore, the location of the SD gives a much more comfortable experience than at a Central location of SD. At reviews and pictures more interesting and varied and "naglalakbay" faster...
Contact:
Post by Андрей Патрушев » Mon Jun 22, 2015 16:36
Алексей Крячко__ wrote:purple is almost blue. Blue vision weaker need high brightness and now to find such LEDs is the question...
Meditation and altered States - it's just "not a question"... :) I would even say that it is "not a bug, but a feature". :ay - High brightness NOT need.
User avatar
Дарсия
Post by Дарсия » Mon Aug 22, 2016 16:45
A question, can not absolutely in a subject, used the Inner Pulse with red LEDs in the glasses, got fantastic joy by the brightness. Immediate disconnection from the external environment. Bought now the Navigator. And high 30, points on give a brightness. My soul asks directly the brightness more. think about how to take the points with white LEDs. They have the same brightness? what do you think about this?
Contact:
Post by Андрей Патрушев » Mon Aug 22, 2016 17:12
Garcia
The most interesting light red and white glasses. You can try all the colors to put on the red (regardless of what the session recorded) - read the instructions. White sunglasses, of course, provide brightness slightly greater than multicolored.
Алексей Крячко__
Post by Алексей Крячко__ » Sat Oct 15, 2016 17:37
Eyes perceived brightness depends on the shape of the signal. Maximum - if set to "rectangle" can be assessed on the reproduction of the test signal, and choose the desired shape before starting the session.
Post Reply
