New audiostrobe software for Navigator.
Posted: Mon Mar 12, 2012 15:25
To the SD card of the Navigator included extras four audiostrobe program of Dmitry Shumova and drive Angier Satori.
Autostimulation lucid dreams
At the 1st track of the used light and sound stimulation at frequencies of Delta rhythm (2-4 Hz), combined with the sounds of nature. The result will be a quick dip in a deep sleep, which will help you forget about sleeping pills and tranquilizers!
Track 2 recorded specially selected AudioStrobe signals, stimulating the brain stem with the simultaneous relaxation of the body, resulting in vivid dreams, in which it is easy to realize itself.
quit Smoking
This exercise will help You to start a new life — a life without Smoking. It contained verbal instructions, along with AudioStrobe technology, will strengthen this bold intention, at first, and will support in the future. During the exercises You will be given a "key phrase" with which You will gradually learn to first "turn on" a program of recovery from the effects of Smoking, and then to maintain the current level of health and freedom.
the Normalization of appetite
You will learn:
To control attachment to food
Reduce appetite
To be insensitive to the appetizing aromas
To maintain a stable weight
To maintain the optimal balanced diet
Not to notice feelings of hunger
It is necessary to clarify some specific words that sound during exercises, namely:
A. "ten". Is a specific condition caused by AudioStrobe technology, in which the body is deeply relaxed but the mind continues to be awake.
B. "the additional Channel access." — A condition resulting from earlier and with more focus and receptivity of the mind. It is very favorable for the formation of new programs of activity in your body.
Use the AudioStrobe CD until it is well understand all instructions, and most importantly — the key for this exercise, the phrase ("Balance. Pressure"). Then practice without the disk yourself entering into a state of "body asleep/mind awake" (state 10) and pronouncing himself a key phrase, until, until you are sure that it will work.
the Normalization of blood pressure
This exercise will help you:
To remove the harmful effects of high blood pressure
To balance and regulate the activities of the circulatory system
To restore optimal physical performance
To normalize the heart and blood vessels
Ethnic drums
New disc Anjey Satori.
Use of the composition of the disk as the background for "shamanic journeys."<
quit Smoking
You will learn:
Reduce appetite
Ethnic drums
