Page 11 of 11
Re: the help Navigator
Posted: Mon Aug 07, 2017 11:21
by Алексей Крячко__
Юра88 wrote:
PS the connection to the PC do as is written in instruktsii. In the section Utility switch from "Work with PC" then make the cable connection.
you are doing wrong. Need to work external to the instrument.
And to work with a memory card you need to off the device connect the USB cable to connect it all to the computer and then insert the device. Then the contents of the memory card will be available on the computer.
Posted: Sun Oct 22, 2017 1:25
by Ашот Васильевич
Tell me how to Isochronous rhythms in Pathfinder? Which mode must be turned on? There are in Pathfinder, the built-in session with Isochronous rhythms? Thank you.
Posted: Sun Oct 22, 2017 8:55
by Алексей Крячко__
Ашот Васильевич wrote:Tell me how to Isochronous rhythms in Pathfinder? Which mode must be turned on? There are in Pathfinder, the built-in session with Isochronous rhythms? Thank you.
It's likely you'd have to ask Andrei Patrushev, he did the built-in session, so better to know their contents. I'm talking about such rhythms the first time I hear it.
Posted: Sun Oct 22, 2017 11:00
This is the mode Amplitude Modulation "AM". "Isochronous rhythms" is just a commercial name of marketing.
Posted: Sat Oct 28, 2017 0:00
by Ашот Васильевич
Thank you.
Posted: Wed Nov 08, 2017 18:51
by ольгак
Hello! I bought a Navigator three years ago, but yesterday it stopped working all programs, "healing", "Explorer", etc. ((( Major work, and these are not! What do I do? Prompt ,pzhl!!!
Posted: Wed Nov 08, 2017 20:14
by Андрей Кабанков
olgacCheck whether the inserted memory card. These programs are recorded on it.
If it is not there, email me
mindmachine@bk.ru how to clear the fault.
How do you incorporate these programs and what happens.
Posted: Wed Nov 08, 2017 20:22
by ольгак
The card is always inserted,I never learned! Included Explorer yesterday,started playing ,and after five minutes just stopped......
Posted: Wed Nov 08, 2017 20:23
by ольгак
Upset!!!!!!!
Posted: Wed Nov 08, 2017 20:34
by Андрей Кабанков
If you are in Moscow, you can come to the office.
If it is not in the integrity of the information on the map and the issue is not resolved remotely, the device will need to send us for repair.
Since this question requires a discussion on the forum, please write to us by email.
You should not get upset. We can resolve any problem.
Posted: Thu Nov 09, 2017 10:24
by ольгак
Thank you! Later all write))
Posted: Sun Nov 19, 2017 20:44
by Алексей Крячко__
stopped play gate records. Judging by the description of the work that after a while stopped during playback - this can be as the audio codec and the batteries (when voltage level on them is below the critical program itself completes). If you are playing sound on other audio files (which can be run via the menu "Player"->"normal"), then the second.
