Re: Suggestions for improving.
Posted: Fri Dec 08, 2017 19:53
Гуфест wrote:You got a tip,because you seem to like what we create? but you start.
Please note that I've never told anyone that you are an expert in this. I'm not a specialist so an Amateur with little experience. I had an idea, I sold it, making a program and testing it on volunteers, then based on the experience of expanded and improved, and a couple of times after. All))) Nothing else I was not attributed. Who wants to work on this program is absolutely free (only TB first learn, then to me, extreme in their romaponti not to do), who do not want - the Internet is big, there are many options, I forced no one forced and does not lure. And certainly I never came to say publicly thatГуфест wrote:Your cooler each))This is understandable)).And who better Voll?How much do you charge for hypnosis?you a question.For example, Goncharov to introduce him to you is not necessary ,you can arrange for 4 thousand rubles,Mikhail s forum 20thousand session.Everything is relative,whose steeper.))K-13 Even pray for this world monopoly in issledovaniia resonances...
And we are here in Absolutes erect, and I))) You really feature of the interlocutor in the reflection in the monitor, and that really funny...Гуфест wrote:Better <...> nobody in the world knows the influence of frequencies on the human body
Criticism should be constructive, not "This is all wrong information, and only correct, ideologically correct, kosher and exclusive information You can find in our book, which is only today and only for You we are ready to offer only 99.999 R 99коп. The supply is limited, there may not be enough! Bought as a gift a unique senocakli and pants with fleece!". This smacks of Your post, not the tip."I disagree - criticize, criticize - offer, offer - do do - answer!"
Sergei Pavlovich Korolev.
To share someone will be interested,the book ordered through a friend of the doctor from whom you have access.K-13.There is specific information - share, as do the others
I have no access to,and the best and the truth is not even over the hill,British scientists discarded as a scientific personal discovery, a couple of three frequencies,which were already known in the early 20's scientific circles.. In closed faculties at Yale do not study,to the closed libraries of the Vatican, we also think you will not be allowed where there is serious information,for example, listened to the disc and the hair on body started to grow,the skull to elongate,the canines to erupt or as the Ukrainians in the restructuring was the technology of foreign language teaching for two hours but without special injections won't learn it,which cost$100.))And that are here in Absolutes erect
Well, I also wonder Yes there are many who do will be interested.Гуфест wrote:To share someone will be interested,the book ordered through a friend of the doctor from whom you have access.K-13.There is specific information - share, as do the others
the theme is interesting, I vibrators held a small R & d 3-4 years ago. Tried as microvibrator with the Cam and solenoid. No audio signal will not pull. and the scheme of excitation of electromagnetic vibrators is not the same as for dynamics, when the audio signal is fed directly and all. It is necessary to initiate a short pulse. The repetition period of these pulses is determined by our vibration frequencies, and the pulse width associated with its own resonance frequency, which is usually much higher than the operating frequency of the vibration.к-13 wrote: By the way, why not do similar for a Navigator - I'm sure now you can easily find quality microvibrator electromagnetic (without the motors and the eccentrics on the axle), which is enough audio to manage.
The case of the first Navigator was originally meant only installing the membrane keyboard. To install the clock buttons there's just no room. Membrane keyboard, together with a number of flaws still has certain advantages: better protected against external influences, dust and humidity.Дмитрий А. wrote: On the hardware I have basically not have any complaints except for the keyboard. Now I think that this can be done. To buy a new Navigator second version is not an option. Maybe someone could introduce improvements? There has to be something to do, such as installing regular buttons.
Alex, this is not in any way not requirements, but simply suggestions for improvement of the Navigator.Алексей Крячко__ wrote:Dmitri, a part of the proposed requirements has already been done...
I would like the introduction of this feature in the first version of the device. By the way wanted to ask at the same time, my GPS occasionally buggy, switches itself off, for no reason, no reason at all. This happens about once in 5-7 inclusions. What this might be, I don't know.Алексей Крячко__ wrote:part of the proposed requirements are already implemented in the new device. For example, auto-disabling after a specified time.
I agree, there is in sessions, and I use it. But use very inconvenient. Not necessary in my opinion so many modes, there's too many of them, especially with a film keyboard. Sometimes have to the second round to go and what to choose. And most importantly there is the choice of white color, that is the work of all 3 colors.Алексей Крячко__ wrote:Which is already there in the first Pathfinder, for example, in sessions on the go you can change the color applying the mask key K14, before working with sessions you can separately select the color and fill (including to make monocolor).
Yes, it can be adjusted, but you need to stop the session, and to get into the menu. And I suggested to adjust it right during the session.Алексей Крячко__ wrote:volume in a combined and synchronised is regulated just enough to reduce the level of loudness by pressing "down arrow" and (or) to set the ratio of 25-50-75-100% in the setting "audio sync.", and the overall volume level raise.
Well, no, no. Too bad of course, it would be great if you could use Lossless files strobe. Big memory savings would be at virtually the same quality.Алексей Крячко__ wrote:as for playing different types of media files, then use a separate hardware codec, not software, so it strictly controls the ability to play mp3 and wav. The use of a software codec in the project was impossible, since the recording track and the audio stream of the session may have very different bit-rates and it requires first large computing power to gather into a single digital stream, and secondly inevitable distortion that the ear can not be felt, but will lead to the distortion of the spectrum session.
Yes, that would be great! The screen of the Navigator is pretty big. For example I really miss that I can't know the duration of audio files. Through the device now is generally not possible to know. I thought to make the duration in the file name, but refused to do so and so length of the name is strictly limited.Алексей Крячко__ wrote:about the interface and that is displayed on the screen, of course, there is a field for improvement. For example, to increase the number of display characters in the name will appear with the transition to the next version of the file system. This will be done for units both new and old versions.
And I use this. I chose the noise N3 due to the fact that he seemed the most quiet. I wish that he would have been even less, so the volume of noise would be very helpful.Алексей Крячко__ wrote:Some things as turning off the noise in session, I can make a separate setting. Now in version 2.01 for the first Navigator it is possible to change the spectrum of the noise. There will be more to add and its off.
I would love to feel the keyboard from another manufacturer, but I live not in Moscow, and, accordingly, are unable to do it.Алексей Крячко__ wrote:After production of the first Navigator we have some stock keyboards, including from another manufacturer, you'll be the other membrane, and therefore tactile sensation when pressed. But it's all individual! Since the issue of the keyboard rises not for the first time, the office will be samples of keyboards, and anyone can touch and make decision to change or not.
to enter in the first version of this function, this requires hardware support, which were not provided. Therefore, in the apparatus of the first version after some time the device will be switched to low power mode (blinking led). Shutdown can only occur in the event of loss of capacity of batteries. The charging device need be carried out only when a full charge of these batteries. To be protected from sudden shutdown problem with the batteries, if run long session and are at home, it is best to work with this network adapter connected.Дмитрий А. wrote: I would like the introduction of this feature in the first version of the device. By the way wanted to ask at the same time, my GPS occasionally buggy, switches itself off, for no reason, no reason at all. This happens about once in 5-7 inclusions. What this might be, I don't know.
the number of modes, which there are determined the technical requirements and also the needs of its users. I agree that it device is overloaded, but someone will say, on the contrary it lacks some functions. By the white color. In fact, white colored glasses does not work, because the LEDs have different luminescence intensity. The dominant green, less red, even less blue. That's why don't mix all the colors in the sessions. Made of extra white glasses, where there are white LEDs..But use very inconvenient. Not necessary in my opinion so many modes, there's too many of them, especially with a film keyboard. Sometimes have to the second round to go and what to choose. And most importantly there is the choice of white color, that is the work of all 3 colors.
Just in time for the session is governed by the arrow "down"-"up" level output of the player and in the menu you can preset 100% volume for the audio in the sessions that the session will not dominirovali and had great depth adjustment.Yes, it can be adjusted, but you need to stop the session, and to get into the menu. And I suggested to adjust it right during the session.
adjustment of the noise level is hardcoded in the sessions. I remember that Andrei Patrushev once wrote that noise off is not necessary. For me, some sessions would be more comfortable for the perception just without the noise.<And I use this. I chose the noise N3 due to the fact that he seemed the most quiet. I wish that he would have been even less, so the volume of noise would be very helpful.
both formats are compression formats lossless sound, and both are rare and hopeless, they most likely will. Therefore, to apply the device these formats makes no sense. There are basic formats - mp3 (lossy), and wav (the original is lossless) that you can use. In the future, it is possible to add IMA ADPCM, which is much faster and more efficient than flac.Олегус wrote:good day. I would like to ask is there a possibility to make listening to flac and ape?
scratched not the screen and the protective glass. It is made of durable polycarbonate that is designed just for taking all the bumps and scratches. All this can be seen in the light when device is off. However, such glass does not interfere with the display of information on the screen.Константин_ wrote: And the screen is scratched, unfortunately
it is really so. Depends on winding resistance of the headphones and their sensitivity, ie how many volts it is necessary to bring them to the same dB value in sound. In addition, in recent years, you notice a decline in the quality of the headphone cables. The fact that now within the audio has ceased to lay the individual strands in isolation, but simply lay conductors covered with varnish. This allows you to make the cable thin and flexible. However, the paint is even good can crack and break as the cable thing is movable, there is a short between conductors. And some even new cables made by this technology have a measurable leakage current, thus the resistance between the conductors. Because of this, the deterioration of stereo channel separation and power reduction, which goes into the earpiece of the headphones.The sound quality strongly depends on the headphones from the headphone cord
