NAVIGATOR-2. The new firmware 3.10
Mind machine Navigator. Support. New session. Software updates.
Post Reply
Алексей Крячко__
Post by Алексей Крячко__ » Tue Apr 24, 2018 1:25
So, comrades, it's time to upgrade the firmware for the Navigator-2. The current version (3.03), which was recorded in all the released devices were made almost a year ago, it was discovered mistakes, and she made improvements. Turned version 3.10.
the archive with the firmware navig2_v310.bin file f_write.txt
https://yadi.sk/d/oNSKqi_S3UhF4n
Manual for version 3.10 to pdf with color (large amount ~ 9.2 MB )
https://yadi.sk/i/CHQeUNug3UhG3z
Manual for version 3.10 to pdf in black and white (average size ~ 3.94 MB)
https://yadi.sk/i/gXEupl8_3UhGRu
Navigator-2 is stitched with the help of the program navprog3.exe
To write new firmware, do the following :
1. translate the device into the programming mode. From the menu "service" -> "replacement program".
Then to turn it off.
2. Connect to USB and switch the unit on. The screen should be black and should illuminate a white led.
3. The device should be detected by Windows.
4. Follow the programming instructions (link below) to install the driver.
Specify to install the driver link below.
5. To unzip the program for the firmware archive navprog3.zip (link below)
6. To copy one folder to the program contents of the archive with the firmware, including file f_write.txt. link to this archive is the first in the message.
7. start navprog3.exe
Driver resetter
https://yadi.sk/d/WPUrhYON3U4wjG
unzip and specify the contents of this folder during the installation !
The file is a new program for firmware Navigator 2 (referred to as navprog3.exe archived zip) :
sk/d/wiMGZE6d3UhFBs">https://yadi.sk/d/wiMGZE6d3UhFBs
Description programming. It is made even for the first program that is designed for the Navigator-1.
But its essence remains the same, except the check code of the firmware of the Navigator-2. If it is not - will not work.
https://yadi.sk/i/qNad1QPM3LBaPr<
Алексей Крячко__
Re: NAVIGATOR-2. The new firmware 3.10
Post by Алексей Крячко__ » Tue Apr 24, 2018 1:41
About the program for the firmware of the Navigator-2 will say the following. Made this program in order to write to the device, the firmware corresponding to the Navigator-2. What firmware is embedded in the control code that the program checks. It is very simple for protection against "fool" if someone tries to write to the Navigator-2 firmware from the Navigator the first. This is possible as the hardware in both devices is the same. But it will lead to malfunction and possible failure of the machine. Transfer again to the programming mode can only be hardware method.
So IMPORTANT : to see what you have for the device. If Navigator-2 - do not try to "feed" him the firmware from the Navigator first, and Vice versa - also unacceptable, i.e. of the new firmware from the Navigator-2 to record to the Navigator.
In the future this topic will be all about the new firmware for the Navigator-2. For the previous version of device has its own topic where posted firmware.
As for firmware and programs. The Navigator-2 the difference with the previous device using a control code. No special encryption and something else was not done for one simple reason - the possibility of using proprietary software from Atmel for flashing, such as SAM-BA or SAM-PROG. These programs write bin files that control code does not prevent them.
But again, you need to clearly see what kind of device you have in hand and how do you write the firmware.
All firmware for the Navigator-2 start out as "navig2_"
accordingly, all other that were - for the first hardware version of Navigator.
Алексей Крячко__
Post by Алексей Крячко__ » Tue Apr 24, 2018 1:58
So what's new in firmware 3.10, in contrast to 3.03.
1. Fixed a number of errors. The most critical were associated with opening the audio file to accompany the basic sessions, text indexing menu when working in the English language and the preservation of the established forms of modulation for the base sessions.
2. Added 3 the parting of the session :
Mind Healing 2, A_Hypnos and T_Hypnos.
3. Made controlling the spectrum of the noise. Now you can choose from 4 types of noise on the hearing or set to "OFF" - then the noise will be turned off everywhere. Applies to all session and test signal.
4. Made the option to choose 1 or 2 half-life enable to modulate in the form of a sine (sin) and form asymmetric sine (asin). These are two independent settings. The instrument used was only a single half-cycle for these forms of the modulating signal. Now you can include two half-periods, the pacing rate will be automatically adjusted. Apply these settings also for any session where you will use the modulation with these forms, as well as a test signal.
5. Some minor additions introduced. So, for example if you select basic sessions after selecting the session itself via the menu, the cursor is set to automatic Start and is enough again to press enter to start session.
Reworked instructions for working with version 3.10, and also with the product itself, to the end of the user added content.
Константинос
Post by Константинос » Fri Apr 27, 2018 1:58
Please give a more detailed description of this item
2. Added 3 the parting of the session : Mind Healing 2, A_Hypnos and T_Hypnos.
And if possible add full descriptions of the sessions with their capabilities on the official page http://www.mindmachine.ru/photosonix/navigator.htm
Константинос
Post by Константинос » Tue May 01, 2018 12:57
Thank you, what about the other two sessions?
Post by Андрей Патрушев » Tue May 01, 2018 13:15
Konstantinos
Below... :)
Post Reply
