Page 1 of 1
Noopendants and numbers
Posted: Mon Aug 12, 2019 20:30
by Aura
a Little over a year wearing two neocolony 1 level. 2-3 weeks ago felt the need to switch to power. Became much more feel and the world to study and see the blocks and other nuances.
My main question is, why write. Me for the last 5-7 months everywhere and almost every day was looming, the number 108.
What this number could mean (I know its only the Indian Vedas) and why it constantly POPs up in my life?
Good question. We can say that numbers are the universal codes GAIP. Of course, their transcript is including an individual issue but still to understand/to feel/to sense numbers, they should be approached from the standpoint of energy, i.e. to be approached geometrically. Approach geometrically means to understand the nature of numbers or how the numbers appear at all in the field of human consciousness. To understand the numbers actually mean something more than to read them as codes, as the language means to understand the geometry of space. Simply put, everything we see in our world, certain regularities (laws), or the matrix of our world. Regardless of whether you believe that our world was something created or emerged spontaneously, as a result of the big Bang, in it, in particular, in the natural world, there is a certain order, and the number appeared in the conceptual field of the person it is in order to understand this matrix. Even Pythagoras said "All things are numbers". Our DNA is numbers in space. With the advent of the theory of relativity has been scientifically proven that the parameters of the space determine its physical properties. Going back to Your example, you can say that Your current reality manifest certain properties of space. As stated above, the numbers simply are perceived intuitively - for example, 1 is the line point; 2 - the angle of equilibrium; 3 - a triangle, the Trinity, the Trinity, etc. You can certainly look for a transcript of specific number 108, sacred number, the number of balancing...you know it will be a treatise)) Unit - things, beginning, law, energy, stimulation, eight is darkness, in the number, complexity, completeness, zero is a balance, infinity, standing between 1 and 8, equilibrates, balances. Therefore, 108 is a sacred number, is a code of absolute harmony. 108 is the Yin, Yang ...the balance between Yin and Yang. But the essence of the "message" that You are trying to decipher, of course, must be considered individually, that is, in the context of the situation. Universal answer no, just very common. Like for example Tarot cards, which also has a matrix of processes is used, i.e. interpreted in the context of the situation, although there are some of them.
Speaking of numbers, as the parameters space, it is more correct to speak about a certain geometry of numbers. You found a number, 108, it is possible to tell, the word only in the geometry of numbers. What can you say about one word? Everything and nothing. You caught it, because it resonated, because there is a specific internal response. But one word, if you perceive it as code, it is difficult to decipher the whole message. If it is a single number, it is possible to catch only...General direction, and it is vague. A similar situation can therefore be regarded as the situation, then there is the fact that went a particular response, the response space has been synchronized with the space. This is valuable, the fact that the synchronization with the world, you should concentrate on this fact and sensation. To decrypt one number is unproductive in terms of interpretation of the situation, as if to take the same Tarot, the alignment is done on the system of cards, shuffling, not one card. Although if You had a specific request, a clear question, it could be the answer..
Nookular and numbers
Posted: Thu Aug 22, 2019 13:39
by Гуфест
Vision response is a signal which the traffic light indicates an action of the operator. The response appears schem linked is not an easy task, it is necessary to consider, what was the response, rhythm, space, personal rhythm, intention, personal manifestations of the thoughts, actions, change of attitude. Someone will add to this list. Given the above, we have the opportunity to work in the right direction .Happens before the response events which need to remember and take note as the direction.
Posted: Thu Aug 22, 2019 17:28
by Рэмис
And sometimes repair everything, almost every month, and each podryachik something numbers - from the pillars and walls, finishing steps and each of your reference, so easy people passing in the street can see the number say 21 and about a hundred on the street.
Posted: Thu Aug 22, 2019 23:02
by Aura
Рэмис wrote: ↑
This is already the impact on the space. You've never wondered why license plates car signs Moscow are set to 99? :) But I think everything should be on the alphabet 01 Adygea, 95 - Chechnya, and there is a 99 - Moscow :))
