Просто wrote: ↑Tue Jan 01, 2019 12:52
1. Then the question - how to use mantra to spread to the world their intentions, emotions and mental? (probably the intention in the first place)
Techniques for working with individual mantra literally described a page or two above. The basic and the easiest way is to repeat an individual mantra (silently or aloud) as often as possible. Vibration code in the form of a mantra is a particular vibration setting, the more felt and consciously, the less mechanically repeated the mantra, the greater the effect. More advanced techniques allow increasing the “digestibility” of the vibrations of the energy body.
2. If the cut is in rock or wood - what to cut? Only the vibration signature? Signature + is the meaning of intention in the text? Or something else?
It is recommended that only the vibration signature for several reasons. First, a vibration code, a universal and self-sufficient. Secondly, in the process of integration in the space, or if you prefer, in the process of self-development, work is also underway with the staging of intentions also probably the most experienced users of BRM, because they get appropriate feedback of the world. You have to understand that what we create as the intention is only a reflection of our current state, and in the process of moving towards the goal is the development, transformation operator, together with which as a consequence of change and intention. Third, “language” vibration signatures, and intent, expressed even in a dry and mean sense of balance is different, so thus created the Artifact will not be uniform, that is not the system, that is, will work poorly. And fourth, if in General, as one of the foundations of energy-the “magic”, there is no way to realize a specific intention, there is a path entering the state to achieve certain energy-informational characteristics, called “integration” (into space) when implementing the intention at all. Therefore, when creating such artifacts and artifacts in General it is better to nedomajot than complicate things. Simple systems often prove to be more work than complex.
3. You shared intentions, emotions and mental. What is the difference between these categories in terms of setting and achieving goals and desired? What is the difference in the expected impact?
In humans there are three main energy center in the abdomen, chest and head. Derivatives of these centers are the will (the power of intention), feelings and emotions, mental. The difference between them can be described in different ways, frequency or structural, does not matter, difference between emotions and mental need to understand every reasonable person) the Difference in the predicted impacts already described many times in different topics, study the major. To influence the reality – the realization of the desired – synchronous requires some effort (work) of the three centers. The map of Alchemy II there is a special program. In short – the first (in order of development) center is the belly (the center will), then there is no formed intention of any desire will remain a desire. Read more about the intention of the topic fundamentals of energy-magic. Next comes the connection of the stomach with the head (the mental). That is, the stomach is the basic makeup of the earth, the sphere of instincts, the most powerful, but low frequency field, which is managed by the mental (head). In the abdomen is the largest EN. the center, a large cluster of neurons, blood vessels, etc. more about this is in the theme of Psychic workshop. Therefore, the lower EN. the centre is rightly called the “brain”. The easiest way to understand the interaction of “animal” and brain using the analogy of a rider on a horse. Horse – animal, a powerful force, able to carry a “rider” wherever he is you can't walk, strength, energy and speed is not enough. But that horse ran in the right direction and not just randomly running around in search of food and other “animal” pleasures, requires the rider controlling the horse. It Manager, that is, taking into account the needs of the “horses” (without food and water will not get far), and holding the direction – in our analogy, the intention. The third center is the center of human energopodachi, the sphere of emotions and feelings. There are different points of view on the work of the centre and its role in essence is to ensure that it is strong but very short-lived because of their consumption, to feed. In other words, emotions can strongly energize the intention, but it burned a tremendous amount of energy, as well as the emotional center of modern man and so is constantly in a state of reaction, much to energize not really work. This is my personal point of view – the emotional center works best when it is at rest. Any attempts, you know, bright happy or otherwise emocionante on the subject of intentions, in my opinion not particularly visionary, though, and give temporary results. There certainly is still need to understand the difference between emotions and feelings, the latter is the emotional center of modern man has almost forgotten how to generate. Feelings is a good driving force and energopodachi, I would say the main, while man has the structural form of human emotions today, and a short-term measure also harmful to the mental. But it's a subtle distinction and not all are ready to feel, so the emotional center is better to keep the peace, not to low, and use the vibration of the upper center, which the modern man much better developed than the sphere of the senses.
4. And of course, I want details and nuances on the previous question (when will be able to answer more...)
Is to start with one main caveat regarding the work of the vibrating code (and mantras as a way of coding) and implementation intentions with it. The closest verbal nuance describes as “GAAP amenable to soft influences”. In other words, there is no universal algorithm for the implementation of specific intentions but there is a way to enter the state integration space, which provides an implementation intention. Vibration code, and the mantra is one of the most effective ways of integration. Another thing is that integration significantly change the original intent, but that is another nuance, not on integration as such. In the end, no matter how paradoxical it may sound, the main thing that prevents the realization of intentions – a desire, because desire of energy level is a pressure on GAIP and GAIP need to integrate, not to push him. GAIP amenable to soft influences. For example, I hope no one hurt citing the example, he was such a character Dmitry I, who wrote in the subject psychic pendants and cards Chronos, which is so deeply desired that suffered greatly from a lack of desire, and all their actions more and more distant from the final goal, respectively, allocating more energy to your dissatisfaction and suffering. Exactly what “presses” GEIP in response to his pressure. The only advice you can give in this situation is to lighten up) What to do, of course, difficult, because not seeing other sources of energy, the man will release energy as you can (as able, as learned in childhood, in accordance with their own experiences, etc.), because releasing the energy into the surrounding space man, too, in some way integrated into the space, fueled by its own emocionalnom – however, due to the combustion of enormous quantities of energy. There is even a category of people – neurotics that live at the expense of allocating a large amount of emotional energy, because they do not know any other way. So, the vibration code is one of the most effective, we can say literate ways of integration in space. Therefore, the main nuance is to adjust the strength of the desire to maintain a state of integration when working with code and mantra. What is the state of integration – perhaps describe in more detail later. Condition brighter to understand when working with the mantra, than with the vibrating source, because the mantra works on the level of sound vibrations, more “friendly”, that is perceived than with the vibrating source, which already is closer to the software level. Well, as always, everything I write is easier to understand in the course of practice, on their own experience, rather than as intellectual knowledge.
Resonance "Knicks" - to enable it only at bedtime and in the morning off? Or he can spin all day?
Valid permanent inclusion. The fact that the conditions of quality sleep - this day time also. Energy Niks gives a certain specific condition, unless it interferes with basic daily activities, that a valid clock enable.
are There any basic rules for the use of resonances? For example (important for me now) - viral infection (flu) resonances is off? Or Vice versa - to enable the fullest? Or something differently (for example, to turn off any selective resonances)?
The basic principle of one - the wider the range of the energy transmission, the better. And then have physical limitations. The human body - a self-organizing system, though the system is "smart", with a large number of programs firmware and VPU, which the average person does not even suspect
Someone simultaneous absorption of large number of resonances can be associated with unpleasant sensations, because the penetration of the meridians is often not the most pleasant process. You have to understand that the energy of the resonances is not some "metaphorical" energy, but a very specific, tangible, and powerful energy, access to which resonances not only in the terms of modern space. Therefore, resonance is better to include as much as possible, yet allow the physical condition. To manage energy better to include consistently, step by step, to feel each energy as separate. To experience of the body - recommended "all at once". So practical the best path lies somewhere in the middle, although there are individual characteristics that incline to the first or second embodiment. For the same disease condition. You can enable all at once, this may be extreme, but effective, or the second option is to disable everything except the soft energies, to allow the body to recover slowly, then return to loads.
As you can see, a single option no, all individually. It is important to understand the General principle: energy burden in the General principles almost indistinguishable from physical activity. Imagine, you come for the first time in the gym. You need to take the maximum lifting weight, but without injury. It is known that muscles do not grow under normal daily load - thus only supported the current status. Muscles grow at significant scales, leading to microtraumas in muscles, due to the splice which takes place the muscle growth, but without significant injuries. With energonaladka the same. A package of connected resonances is a flow of energy passing through our energy system, or giving a strain on our "energy anatomy". If we want to have at their disposal a greater amount of energy, i.e. to increase the flow of energy is needed "technical tools" that can handle the additional "load". "Hardware" refers to the ordinary physical systems, so there may be temporary, unpleasant physical sensations, but without overloading.
And the second principle, synchronization of incoming energy with an integral body (individual resource). Since the energy channels in our energy mix are interrelated, that is collected in some "chips", it is necessary to set the flow of balance and harmony between the different streams, that is, to muster up the energy body into a single structure responsible for the integral body - information resource of our body and consciousness. These energetic communications are not something abstract on a physical level program integrity provided by a certain activity ligament-tendon apparatus, a constant gentle stretching in the normal state, including at rest, but at the level closer to the information, that is, the nervous system, communication is provided by the activity of the baroreceptors, for example, and other receptors of the sympathetic and parasympathetic nervous system.<
