Noopendant "The Armor"
Posted: Thu Jun 18, 2015 23:22
Noopendant level I "The Armor" includes:
I. a Package of basic programs (questions and discussion here http://www.mindmachine.ru/forum/viewtop ... =35&t=5791)
II. The package of specialized programs
Changing the clock frequency ver 3_1
Frequency protection ver 4
Stealth ver 2_2
Shield ver 1_2
Jump ver 2_2_1
Protective package access to information channels ver 5_1
Increase immunity software ver 3_2_1
Social marker ver 3_1
Grey camouflage ver 1_3
Protection against disconnection of power supply ver 2_1_2
Protection from blocking software packages of IP operator ver 3
Protective package from breaking and making changes to firmware ver 2_2_2
Anti-parasite ver 6_2
Frequency filter ver 2_2
Mirrored protection ver. 2_3
Navigation capabilities ver 11
Some specialized security software, the most essential and unique:
1. Protective package “Change of clock frequency”. When the program first turns on a warning system, that is, the operator is given the opportunity to notice and resolve the effects independently, but are created with certain “improved” conditions, compared to source of exposure. This stage is usually perceived as increased awareness and intuition, a sense of “dives” and the perception of reality in slow motion. The energy level is approximately the following: negative momentum operator slows down when approaching the external sphere, can virtually stop and the operator serves a certain “alarms”.
2. Protective package “frequency protection” works on the principle of a temporary departure from the channel on which the impact occurs. The most natural, simple, easy and beautiful way, but does not always work. That is, any impact occurs at specific frequencies, and if the program notices the impact on a certain frequency level, the operator temporarily switches to another range, and the effect is just passing by.
3. Protective package “Stealth”. Any impact is only possible through certain areas of sparseness (in the aura, consciousness, integral box, with different sides can be viewed). Usually “pickup” negative effects using some of the data about operator that allow the impact to send in need a weak point. At this stage the program works by substituting some of the data (usually through an information copy) so that the impact of “lost orientation”. The operator is almost not felt. The package includes specialized programs for the protection of the fundamental energy of the nodes, including the program “the cap of invisibility” and “axis of life” - specialized protection from attacks directed at the brain and spinal cord of the operator.
4. Protective package “Shield”. The package works by sealing those areas, which are presumably being exposed. The operator is perceived as a sense of readiness, increase energy levels, can occur elements of psychological study.
5. Protective package the “Jump”. Is activated only in the most serious cases, for example when there is an imminent threat to the life and health of the operator. Made the jump to another variant the line for the operator is the most energy-intensive option, but it works almost 100%. The operator can be seen as a rapid, often uncontrollable event stream. May cause temporary disable some other programs.
6. Protective package access to information channels. Package includes universal protection against information read-out and the copy protection, that is, the attempts of recreating an information copy for the purpose of further amending it, directly on the software level.
7. The protection package from infovisual – “Software immunity”. One of the most important packages, owing to the universal prevalence of infovisual in the modern world.
8. Protective package “Social marker”. Protection from exposure that occurs with levels, where one program controls from a group of people. These impacts occur at specialized universal markers and not directed at a specific person, a group of people. Basically it is a program generic, national, professional, etc. different levels of social inclusion. The package works by temporarily infobrokerage of a marker, therefore, focused on the impact temporarily “sees” of the operator that are included in this level, and excludes it from its sphere of influence.
9. Protective package “Gray camouflage” works with an information copy sent to the...protection of the operator. Sometimes their thoughts and actions man gets into areas where there are strict laws or “information rules”. Not knowing these laws, the operator may receive at least a “flick on the nose” until serious negative consequences. Typically, such situations occur in the creative, enterprising, fearless, independent-minded people, individuals who stand out from the system and sometimes the system easier to eliminate one element than to rebuild it the system itself. Defenses will not be able to neutralize such a powerful impact completely (this is not necessary because these laws also exist for a reason), but can significantly flatten them out by masking some “exceptional” data under “normal”. The package has successfully been triggered several times for the same area, but on further repetitions, the degree of protection is significantly lost.
10. Protection from disconnection of energy supply. Disconnection of energy supply of one or another of the required operator software package is one of the most subtle and sophisticated of ways negative impact. Most often the consequences of such attacks are felt as a sense of apathy, fatigue, melancholy, insecurity, associated with channel lock firmware SOUP. Not practically identified on their own because the built-in security mechanisms of the firmware – built-in protection of the subconscious – in this case, not exposed to direct immediate threat. The package uses some 4D function II level.
11. Protection from blocking software packages integrated field operator. This protection is stopping the packets, that is, protection from interference in the utility, specifying the cycles of transformations.
12. Protective package from breaking and making changes in the firmware is protection directly from attempts to reprogram the automation operator (the so-called “brainwashing”, etc.)
13. Protective package “Anti-parasite” protects from connecting to the operator, third-party structures with the aim of connecting to energy supply operator.
14. Some superior base packages: frequency filter ver. 1_4_2 mirror protection ver. 1_3, navigation capabilities ver. 8.
III. Group domain IV. Individual domain level I
Comments and explanations to neocolony “Armor”: it is important that any permanent protection also prevents and harmonious interaction with space, blocks of positive and necessary exchange of energy and information of the operator with the surrounding world. Security software neocolony not operate continuously, but is activated as needed each batch, starting from the minimum level to the maximum with a high level of risk. Under the “necessity” refers to a particular type of impact, which may occur at the level of matter, firmware, or solely software. Most often, any impact is not standard, any exposure is unique and happens at different levels simultaneously, so it is often activated several security packages at the same time.
Another feature of the complex of protective “Armor” that simultaneously with the protective packet triggered the alert system and alarm, that is, the operator always knows about the upcoming, even the most hidden and disguised attack, and has the ability to mobilize its own protective resources, combining them with software capabilities neocolony..
