GreatШура wrote:I know only one wisdom, than things easier, the more likely it is that the truth, and the truth. And everything is some complex terms are operating and do not explain.
Noopendant "The Armor"
Aura
- Разработчик
- Has thanked: 22 times
- Been thanked: 1124 times
It is necessary to immediately understand the work of the forum and answers here. Not quite right to consider this as the format of the operator's question, the answer of the developer. The products themselves give a more clear and powerful answers than the developers, and if a person is looking for the answer of the developer, it may be different reasons. As previously explained, it is impossible here to reduce to a common reference, to which any operator has access at any time. I'm not a walking storehouse of knowledge of energy-informational nature, which anyone can join if you wish. Sometimes I just perform the function of a universal BRM
Then absorb the Truth and the Truth is simple and without complex terms. So far, except the desire to feed your ego in the form of demands personal attention of the developer, nothing. I could now start the long and detailed reply to each question, if the function was different from that described above. You gave a lot of detailed and competent answers, but You need not they, personally, attention and energy. A little earlier took over the Cornucopia, even though he started according to the above-described work, so if you can (which of course is unlikely) to keep the naturally occurring wave of indignation and anger from my response, it is better to begin study with other products. Somehow, when I want the simple truth, and the truth
Re: Already in sale - nookular "Armor"
It's not a pendant that effect, I always ask a lot of questions and hard-nosed and I'm not small, to the attention of the forum created for dialogue and including, to ask questions.
Certainly not the pendant. Your Ego is wanting,ALL at ONCE,, . And the main way that You described. Otherwise you will not understand what to do, where to go. You bought a product super complicated and require simple words to describe its effect on You. But RI with each user works individually,in their own way. Well, who is ableШура wrote:It's not a pendant that effect, I always ask a lot of questions and hard-nosed and I'm not small, to the attention of the forum created for dialogue and including, to ask questions.
Aura
- Разработчик
Overall, the creation of a certain theoretical Glossary about the use of products SAM pondered. Not planned, but was consideredАртфан wrote: You bought a product super complicated and require simple words to describe its effect on You.
I'll start again with a brain
Let me explain
Most interesting is that even if our "fish" - the inhabitant of the aquatic environment, would be able to perceive another space with the help of periscope, you would not see the source of vibrations of another dimension. Because even we, the inhabitants of this space, don't see it
That way, if there were more videos like about the program Balance plus, then I would less questions asked, everything is perfectly told and described)
Damn, I didn't write the technical part and the description of the pendant RI.
Aura
- Разработчик
Шура wrote:That way, if there were more videos like about the program Balance plus, then I would less questions asked, everything is perfectly told and described)
It happens that we ask the same questions or continue to broadcast the same information after receiving the response. In my opinion, it means that the person did not take the desired frequency, it can not be taken at current settings or do not want to perceive it, because there were other problems than declared. The first shows unwillingness to change, the second operation of the virtual mass parameters, from which there is dependence, the third the need to rethink the forces that make us ask certain questions and their goals.Аура wrote:In General, the creation of a certain theoretical Glossary about the use of products SAM pondered. Not planned, but was consideredYes, there is a common theoretical base, such as what is GEIP, domain, EOM, space, rytmeposten, frequency, space, etc. on the other hand, there is a clear understanding that the development of a software process in a theoretical base is just the law of conservation of energy always reduces the chances of its actual practical application.
The description of the pendant is its "stuffing", the list of specialized programs, access to which is possible using neocolony. Available in the relevant subject. What is meant by "technical part"?Шура wrote:Damn, didn't write the technical part and the description of the pendant RI.
