Wishing Machine
Communication for those wishing to do something with their hands.
Post Reply
Дмитрый
Wishing Machine
Post by Дмитрый » Fri Mar 22, 2019 18:42
Hello.
There are many such devices.T.e many variations.
But the Main Principle is this:
maybe somebody already eksperimentirovat in this direction?
Дмитрый
Wishing Machine
Post by Дмитрый » Fri Mar 22, 2019 18:58
The famous Charles Cosimano,too, have a similar diagram
димыч
Has thanked: 7 times
Been thanked: 16 times
Wishing Machine
Post by димыч » Fri Mar 22, 2019 21:02
Primitive radionic? Try to tell... There are materials in Russian?
User avatar
Has thanked: 31 times
Been thanked: 129 times
Contact:
Wishing Machine
Post by к-13 » Sat Mar 23, 2019 1:58
Primitive radionic?
Household debilizm. Antenna for VHF (high frequency) is connected to the amplifier low frequency (audio range) that is connected to the contact plate. And all penny. Unless the battery is drawn dear))) Like in the author's opinion this should work? What feature reduces contact with the trend? Sound vibrations converted into an electrical signal? The amplifier in the pictures anything else to strengthen the will not. And even if you can, then the received signal is absolutely useless to apply on this antenna (Yes to any useless, though low-frequency radio communications, and has a very long antenna, but there are frequency orders of magnitude greater, otherwise the attenuation in the atmosphere reduces everything to zero). It's like pancakes from the hard drive in the laser drive trying to read or a bulldog with a rhinoceros cross...
димыч
Wishing Machine
Post by димыч » Sat Mar 23, 2019 8:49
Somewhere I saw a statistical study that visitors to the metro which happiness has rubbed the nose of the dog statue at one of the stations were more often in trouble than luck)) can large bronze statues in a crowded electric fields the space to be certain manifestation desires?
User avatar
Contact:
Wishing Machine
Post by к-13 » Sat Mar 23, 2019 10:23
A dog's nose is still normal)))
This is called "ritual magic"))) In psychology - activities that increase confidence. The main thing that the conscience does not counteracted)))
Although I like to pretty stupid to do my own confidence is dependent on some external lotions, and even battery powered...
Дмитрый
Wishing Machine
Post by Дмитрый » Sat Mar 23, 2019 14:12
In Russian it seems to be not really found.Life itself is not new and sits at the heart of radionic-psionic devices.For example there is such modification
detailed information from these guyshttp://www.berkanapath.com/radionics/337/ .
Here the principle is also in generation tn solarnych waves and things can of course change the input of the experiment.As for anten in very many radionic and psionic devices they used. az
Post Reply
