Angle grinder + diamond discЛанцелот wrote:In the circular saw?
But the spark is not a fountain like metal, and small, only at the site of contact, more like electric.
Oh yeah, I forgot, finally the regiment SP arrived. There are minor bugs, but the cake is formed, the resin is hardened, the socket is not filled, Mobius a call.Igor wrote:That would begin to experiment with ergonom need a starting point, something to compare your success or failure.
And this point I think I will have SP. Gather according to the classical scheme of the crystal-organic-Moebius-spiral, the filler will take the steel balls or washcloth. When the first results can already try to change something.
This is how it should look:
The photo shows that the smaller the particles, the better the field. Particularly revealing photo of gold, as used dust. And it looks like. the effect appears PAL the surface better than in the body. This is evident in light keike, which is obtained from the bevel side faces. It is even conceivable that the thickness is not particularly affect the quality and important Tolok ploschadt surface. IMHO.Igor wrote:Here different types of orgonite kirilian shoot a photograph and it turns out they have it pretty informative.
Did a lot of thinking and came to the conclusion that all the same and...Свами Доупаду wrote:- Interesting idea about the last one, but entropy-and here ?
So, SP and Radionics are positioned as devices of influence on reality. I.e., when in reality there is uncertainty of the outcome of the situation, SP or radionic effect so that the situation is resolved necessary/desired. I.e. there is a direct influence on the information entropy.ВИКИПЕДИЯ wrote:Entropy (from al-Greek. ἐντροπία "rotate" "turning") in the natural Sciences — a measure of disorder of a system consisting of many elements. In particular, in statistical physics — a measure of the probability of realization of a macroscopic state in information theory — measure of uncertainty of any experience (test) which can have different outcomes, and hence the amount of information;
He has long run the observations in this direction, notice that when the device is in active mode (applied on the coil with affirmation) comes what is calm, but it is necessary to turn the appliance off and then starts his work, so I try to include the device only at night. I have affirmations written on your PDA, using it and reproduce them, I noticed that at the right time PDA hangs as if turned off by itself when enough.Igor wrote:In the passive mode harmonizes the cake, this is manifested in a large number ve resolved in my favour small domestic situations, but in active mode is unpredictable.
That is only done and just zelinkova through the photo, it's certainly an experience but not on myself, such as conduct experiments, I assume while link wasn't afraid, although those things long ago, doing here linking to material objects and they begin to fail, to fall apart or behave unpredictable, although there is also another way as desired, such results are also encouraging so the effect is, they need to learn to control and direct in the right direction, and for this you need to understand how it works but it a little information and those who receive the results of share do not want, I think that not everything went smoothly and they also.Igor wrote:In active mode, used different session, and as link's old passport photo.
By the way, Yes, my player too, he is cut down, although the battery charge for work still missing.Алексc3000 wrote: I Have affirmations written on your PDA, using it and reproduce them, I noticed that at the right time PDA hangs as if turned off by itself when enough.
Without link the action SP will only be in physical contact with him, as well as the effect of my not very powerful SP, and it is difficult to detect, without a link it is generally not feasible IMHO.Алексc3000 wrote:That's just made and just zelinkova through the photo, it's certainly an experience but not on myself, such as conduct experiments
Actually I'm not a supporter of active "pushing" of reality (IMHO it's a risk) and your SP I created with only one purpose - to form around a calm Bay, to stabilize the space around them.Алексc3000 wrote:they need to learn to control and direct in the right direction, but it needs to understand the principles of
By the way Your experience just for the "burst" of reality, and I do think it can be dangerous. You cannot take something without giving something in return, and in this case the price is not known.<Алексc3000 wrote:Igor, I want to offer to conduct an experiment on the mental control of the device, maybe someone else will try and write here about the results both positive and negative, take the cake in the hands of the base on the right hand, left hand hold the device from the side, straight ahead, concentrate, and create a thought-form desire to someone specific of your friends say called, this condition is sufficient to hold well at least for a minute and see what happens after that and could not succeed one times do not stop in case of failure , don't forget to talk about the results.
Well this is all just experiments at the moment its 100% efficiency only proved the single crystal quartz of natural origin.Георгий Финогей wrote:Americans stacklayout processed quartz pebbles or processed Dragoman... and even diamond are found in different products
Actually these things and Radionics not only for these purposes, and do, I think to try all the same costs that would even understand what it is you think You have the first time it happens?, the method proposed is one of many, the point was in getting collective experience for understanding of the processes when using the data devices and from the obtained statistics it would be possible to create a proven algorithm of actions for later use for example for beginners in this matter and by this experience not hurt.Igor wrote:by the Way Your experience just for the "burst" of reality, and I do think it can be dangerous. You cannot take something without giving something in return, and in this case the price is not known.
I tried the other day to do the filter puck under your SP. Because my SP no spiral, just crystal organic-Mobius, and it works, feels unstable, and sometimes unpredictable. The benefit of a weak happened. So that is resolve decided to make the puck-lining under SP, because in my opinion DOR(and maybe something else) drawn from the bottom part, and POR comes out from the top.
So, long thought what materials to use, I decided to try schungite crumbs and sea salt (in the complex). Did the fill at the beginning of the pieces of shungite medium size, and on top of flaky sea salt. All safely frozen and removed. So now the test results:
The other day I blew in the machine throat, well, I think exactly the hospital will have to go, so I think maybe the test at the same time hold... Put the puck under SP, included hours on the 8th session on well-being (AFAIK 90 Hz), after short-circuit Mobius, links were not, and in the morning I was very surprised my health is much better, and the next day my throat and all passed. Well this is all very subjective and requires verification by someone else, and so the result(if it was he) impressed me.
Now, about feelings, if before my SP was unstable or unpredictable(like the old sneezing motor), now it is very smooth and stable. I have the feeling that this is another SP! The washer is not removed, the experiment continues...
Welcome.Igor wrote:s.s. with the advent of cake constantly feel not passing the "com" in the area of Vishuddha, even in passive mode, is this normal?
